Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 12/12/08, 07:21 PM   #1
muskrat
muskrat's Avatar
Stocker front locker
Reading, Pa
removing body
Folks, I scored a replacement steel tub from an arizona early bronco. Good score compared to what I'm working with. I need to pull the original body and have searched the forum and can't find a step by step on what parts need to be pulled etc. Does anyone have a step by step list of what needs to be disconnected or removed. Looks like brake lines from master cylinder, throttle, brake and clutch linkages, hoses and cables for heater, pull the steering column?
Need some help please. Thanks.
1974 Sport, LUBR, 2.5" WH lift, 1" body lift, Tom's Chevy disks, power steering. rebuilt 302 with Edelbrock intake carb and cam, NP435/dana 20, BC Broncos Headers and exhaust, Aussie locker front, JB Fab twin sticked, Moab Mike full cage, special paint code black on black. 30x9.5x15's.
muskrat is offline
Old 12/12/08, 08:01 PM   #2
siderbox
siderbox's Avatar
hold my beer, watch this
Gardner KS
Sounds like good list.
I just took mine off a few weeks ago.
This is what I did.
all clutch linkage
radiator
radiator hoses
heater hoses
throttle linkage
fuel line
brake lines
steering shaft from gear box up to wheel
trans shifter
transfer shifter
wiring to rear lights
all body/interior - seats, top, doors, windshield, tail gate
fuel filler hoses
body mount bolts - not too much unbolting on my rusted bolts. More hot wrench
What did I forget to put on here?
Light travels faster than sound. That's why some people appear bright until you hear them speak.
66 HalfCab
siderbox is offline
Old 12/12/08, 08:08 PM   #3
SC74
SC74's Avatar
Greenville, SC
e-brake cables.
While you are this far I recommend going back with new body bushings too. Good Luck
'74 Grocery Getter, '73 Buggy Project
Carolina Broncos Member
My Build Thread
SC74 is offline
Old 12/12/08, 10:49 PM   #4
bax
bax's Avatar
smokin 37's
Melbourne.
Hey Siderbox, I like your lifting fixture. Very good idea.
1971 U15 Ol'blue 5.0/4r70w/205/ 4,11. 1968 U15 - EFI 408C/C6/205/4.88/37's/hi9/ARB's/hydro-boost/full cage/4wdisk/PS/powerasswipe/bla-bla-bla!
bax is offline
Old 12/13/08, 07:44 AM   #5
muskrat
muskrat's Avatar
Reading, Pa
This is what I did.
all clutch linkage
radiator
radiator hoses
heater hoses
throttle linkage
fuel line
brake lines
trans shifter
transfer shifter
fuel filler hoses
Thanks for the reply. Now I have some direction!! Can you cut the body mount bolts with a sawzaw? I don't have access to a torch.
muskrat is offline
Old 12/13/08, 07:45 AM   #6
muskrat
muskrat's Avatar
Reading, Pa
Thanks for the list. Can you cut the body mount bolts with a sawzaw? I don't have access to a torch.
Thanks.
muskrat is offline
Old 12/13/08, 07:55 AM   #7
pmctighe
x2 more pics of it please!
pmctighe is offline
Old 12/13/08, 07:58 AM   #8
Johnny
Johnny's Avatar
Yes you can cut the body mounts with a sawzaw.. that what I did on a few of them... but on the others, I just used a ratchet and a cheaterpipe.. tighten, tighten, snap!
Johnny is offline
Old 12/13/08, 11:15 AM   #9
bax
bax's Avatar
smokin 37's
Melbourne.
Drill the heads off the body mount bolts. It is the fastest way I have ever removed a body. Mess with what is left after the body is off.
bax is offline
Old 12/13/08, 11:51 AM   #10
Dan's73
Dan's73's Avatar
Valley o'the Sun
that's a good idea, Bax.....so simple yet so elegant!
Dan's73 is offline
Old 12/13/08, 05:09 PM   #11
bax
bax's Avatar
smokin 37's
Melbourne.
It works really good. Not my idea. I got it off this site from someone else.
bax is offline
Old 12/13/08, 06:20 PM   #12
Wyflyer
Wyflyer's Avatar
Brighton, Colorado
Every time i read the title of this thread, I think:
"Great, one of the Bronco brothers has killed his wife/boss/mother-in-law and is asking advice on how to get rid of the body".
"not a project for dreamers it does take some work to build a car"-Craigslist Bronco for sale
Wyflyer is online now
Old 12/14/08, 03:59 PM   #13
siderbox
siderbox's Avatar
Gardner KS
I used 1/4" x 2 1/2" angle as you see. And 1/4" x 2" flat stock under the bed lip, like a big long washer.
Used allthread, spacers, and nuts to attach to the A piller. That made it easer to install, as I was doing it by myself.
Did a few test pulls to get the balance point for the cross bar. Then drilled and bolted it.
You can get by with a small sizes but I'm going to use the angle and flat stock for a inside perimeter bed rail for my other truck.
66 HalfCab
siderbox is offline
Thread Tools
Page generated in 0.39693 seconds with 57 queries
