Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 05/25/09, 05:53 AM   #1
Ethansdad73
Ethansdad73's Avatar
someone play a country song backward so i can get everything i have lost back...
Melbourne, FL
backfire thru the carb ...solved
Ok i have had this happen once in a while and because the bronco sat for the last 4 years with out running i thought that it may have bad gas in it. I have now run both tanks 2x. (12/24) I still have this problem. It runs fine for a while then is feels like its missing and then "foomp" backfires thru the carb. My 302 has new plugs, new painless rewire, and new edelbrock carb, new cap and rotor, wires have very few hours on them, but are at least 8 yrs old I do also run headman heders. I am in FL and I do drive in the beautiful weather we have down here, it only been in the mid 80s +/- this last week so. I do feel that my bronco runs a little hot, I still need to get to the parts store and get a 190* stat.
So i know that i could start with new wires and stat, but what could be the issue? Any help would be apreciated, and thanks in advance for your help.
Ethansdad73 is offline
Old 05/25/09, 06:13 AM   #2
6daze
6daze's Avatar
San Diego
It was always a timing issue for me when this happened. Check that first.
6daze is offline
Old 05/25/09, 06:17 AM   #3
Ethansdad73
Melbourne, FL
What is a 302 w/ c4 suposed to run at?
Old 05/25/09, 06:40 AM   #4
TBS-POPS
TBS-POPS's Avatar
ALL my drinking buddies have a severe bronco problem!!
valley springs, ca
Water temp wise,,,,,180*.. A couple of things to check on your backfire,,, timing,, make sure the vacume advance is working,, clean out the carb. Edelbrocks are fussy about the least ammount of crap in them...I love mine but when it gets stuff in it, it will make things run really weird...
WWW.NORCALBRONCOS.COM 72, TBI 302, 435,20,FW44&9,4.56 w/pl&arb,2" & 5.5" on 37's.SOLD Broncoless for now
Broncos are like BOOBS, There always better after they've been worked on..
TBS-POPS is offline
Old 05/25/09, 07:27 AM   #5
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
X2 on the timing. While stock setting is about 6 degrees you can usually run more without issue. Id shoot for 10-12 just get as much as you can without the back fire. Another thing that could cause it is that the engine is not fully warmed up and the choke is still not fully opened so when you try to jump on the throttle it back fires.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 05/25/09, 08:56 AM   #6
markperry
markperry's Avatar
Rock Chalk
Platte City
I had this problem with back firing. Check your fuel pressure, if the engine is not getting enough fuel it will pop and sputter. I have a transparent fuel filter and noticed the fuel flow was very weak, so I went to Oreilly and bought a new fuel pump and replaced the fuel lines and the problem was solved. I saved some money by bending my own fuel lines, the whole project cost 41.00. Now it runs great again!
markperry is offline
Old 05/25/09, 09:04 AM   #7
Steve
Steve's Avatar
GOT MOAB?
Grand Junction, CO
As others have said it's probably a timing issue. It could also be running lean, which is NOT a good thing. Worst case it could be an intake lobe on the cam going flat, but since it's an intermittent thing that's probably not the problem.
69 narrowed 8 inches, locked F&R, big tires, EFI, Atlas, winch, blah, blah, blah
Steve is offline
Old 05/25/09, 09:31 AM   #8
Amac70
ME
Amac70's Avatar
back on the trail
St Helens, Or
One other thing to check is firing order if you have 2 wires switched it will still run but it will back fire through the carb to.
70' 351 efi w/fw d44/9 airlockers f/r,4r70w, oba, other stuff I have given up on spelling and punctuation I just don't care anymore.
Amac70 is offline
Old 05/25/09, 09:48 AM   #9
blubuckaroo
Grease Monkey
blubuckaroo's Avatar
The Ark was built by amateurs, but the Titanic was built by professionals.
Ridgefield WA
After it goes foomp! does it die or does it keep running? Is this at idle or cruising? What kind of ignition set-up?
'77 Ranger/cut F&R/PS/PB/Vintage Air/2" suspension lift/1" body lift/T tie rod conversion/33-1050-15 BFG K02 tires/ 302/ Edelbrock 500 CFM 4 bbl/Aero Tanks/ Hooker Headers/ dual ex/ NV3550/ B&M shifter/ JB FabTwin Sticks/ 4.11s/rear posi.
blubuckaroo is offline
Old 05/25/09, 09:51 AM   #10
broncomitch
broncomitch's Avatar
dont be a sheep in a jeep!
west jordan, utah
your carb could not be sealed properly with the manifold, could very well be timing. dose it happen when it gets hotter? check your points. they go bad easy.
might want to clean the carb. (never know how dirty those tanks where) could be you have a bad valve to.
or a simple gaskit leak. start with timing and go from there.
also look at your plug wires, see if there close or touching a exhaust manifold or getting hot when its running. could be arching on the motor causing it to miss fire or not get enough spark.
1971 bronco sport,mild built 351w,c6,strong box,np205,HP Dana60,srw 14bolt,disc's front and rear,16"rock coil overs,H1's & 44" tires,4.10's,3link front,56" springs,ez wiring,TBI injection,
Build thread
http://classicbroncos.com/forums/sho...d.php?t=196087
broncomitch is offline
Old 05/25/09, 10:04 AM   #11
Ethansdad73
Melbourne, FL
this usally only happens when warm mand have been driving a while
Old 05/25/09, 10:05 AM   #12
Ethansdad73
Melbourne, FL
That was the other thing that was new... the fuel pump and filter... but the carb was an out of box instal so i may be running lean...
Old 05/25/09, 10:13 AM   #13
Ethansdad73
Melbourne, FL
keeps on running thank God! im am usally running at 45-60 on the coast back and forth to my parents or to my inlaws house. At idle you can here a little mis. My ingition is a "SELECT" not sure who makes it... My coil is an excell.
Old 05/25/09, 10:17 AM   #14
Ethansdad73
Melbourne, FL
dose it happen when it gets hotter? yes
check your points. they go bad easy. -- they are new...could they go that quick they are only a month old
might want to clean the carb.... will do this.
getting hot when its running... im runningn headers they are hot...
could be arching on the motor causing it to miss fire or not get enough spark.../ they do cross eachother in a few places...
Old 05/25/09, 10:18 AM   #15
Ethansdad73
Melbourne, FL
While looking at my ingition i saw that my fuel filter is actually right above the manifold. could i be baking my fuel before it gets in the carb?
Thread Tools
Page generated in 0.39293 seconds with 54 queries
