Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 07/17/09, 09:58 AM   #1
dblank
Newbie
Dallas
9 inch ring and pinion set up
Hey guys i hate to ask but i've searched and searched but cant find anything on how to set up my 9inch gears. I shelled the spiders so i figure i'll just up grade gears while i'm at it. Any help would be great. If you live in DFW and wanna help that would be even better.LOL
Thanks Darrell
dblank is offline
Old 07/17/09, 10:26 AM   #2
70_Steve
Old Guy
70_Steve's Avatar
If You're Going to Do It, Over-do It
Phoenix, AZ
Search on Google!!!
This is the article I referred to most when I set up my 9". It's actually pretty easy, if you've got the right tools. You just need an inch/lb torque wrench, and a dial indicator with a magnetic base. And you also need some way of installing the new bearings.
http://www.ford-trucks.com/article/i...ear_Setup.html
'70 Sport, 351W EFI, NV4500, D20 w/Teralows, 4.56s Dana 44 w/Ox and 9" 31 spline Detroit, 35" KM2's, 3 1/2" lift, 2" body lift, 4x4x2 PS, some other stuff I forgot about...
"If it's got tits or tires it's gonna be a problem"
70_Steve is offline
Old 07/17/09, 10:33 AM   #3
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
Might be a good idea to get you a ford shop manual it has all the info you need. On a good note the 9in is probably one of the easiest to setup. On the other hand the D44 is a little more involved have you considered that you will have to change the front gearing also.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 07/17/09, 12:05 PM   #4
dblank
Newbie
Dallas
Thanks guys. Yeah i know i'll have to do the 44 too. Since i shelled it the same day as the 9 inch i'll be repairing that too. with directions i know I can do the 9 but i'll be taking in the 44 probably.
dblank is offline
Old 07/17/09, 12:26 PM   #5
70_Steve
Old Guy
70_Steve's Avatar
Phoenix, AZ
Once you've done the 9", the Dana 44 will seem a lot less intimidating. It's basically the same process to set up the gears (adjust pinion depth, set backlash, check pattern...). It's just that the Dana 44 is an extreme PIA to do what can be done on the 9" in seconds (well, maybe minutes..). Same tools (torque wrench and dial indicator), just a little different process. Oh, and the setup bearings are a must. I made my own out of the old bearings. Here's a link to the Dana setup I used when I set up my Dana 44. Yes, it's a Dana 60, but the setup is identical.
http://pirate4x4.com/tech/billavista/Gear_Setup/
I had only ever set up gears once, and that was 40 years ago on an 8". I had originally planned on letting a shop set up the gears. But when I got quotes of $900 and $1100 to do the setup, I decided that it might be worth my time to attempt the setup myself. I really was amazed at how easy the 9" was to set up. And the experience I got with the 9" carried over to the Dana44 in knowing what to change to get the gear contact pattern correct.
Tip: It's worth the time to get the Dana 44 out from under the Bronco, and do the setup on jackstands!!!
70_Steve is offline
Old 07/17/09, 12:41 PM   #6
dblank
Newbie
Dallas
Thanks lots. After reading i'm guessing i'll have to have a shop do my bearing for me? or is there an easy way to press the old off and install new. I know i can heat the new bearing to install right.?.?
dblank is offline
Old 07/17/09, 01:14 PM   #7
WyleCoyote
WyleCoyote's Avatar
On the Road again!!!
Snohomish, WA
If you have a press, it's a breeze to get the bearings on and off. You might want to invest in a set of bearing removal tools(splitters?).
1974 Frame up resto - 5.0 EFI, AOD, 4.56 Detroit Rear, Auburn Ected front, 35s, 3.5" SL, 1" BL.
The Build is done now - Click here for the build thread!
Live in the Northwest? Join Us at Nortwest Classic Broncos!
WyleCoyote is offline
Old 07/17/09, 01:24 PM   #8
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
While you can heat the bearings to get them on I would be very careful too much heat and you'll weaken the bearings. Its much better to have them pressed on/off or as was said use setup bearings so the new bearings only need to be pressed on once. hopefully. Screw something up and you'll be doing it all again.
broncnaz is offline
Old 07/17/09, 01:25 PM   #9
dblank
Newbie
Dallas
I got the stuff at work so when i get to that point i'll probaly just drive over there and do it. they wont mind i hope. lol
dblank is offline
Old 07/17/09, 02:00 PM   #10
KyleQ
KyleQ's Avatar
1 Ton 74'
Twin Cities
Use the old bearings for setup bearings if possible. Setup bearings are bearing that have had the ID of the race opened up so you can slide them on and off when setting gear lash.
Take your time and make sure to torque down the main cap bolts to listed specs when running your pattern...
74' Bronco -Fi-Tech Injected 357W - Twisted Demon C4- AtlasII 3.8 - D60/D70 - PSC Full Hydro - 5.5" lift - Cage Arms, Coils and Shocks - F-O-A 2.5" Air Bumps - 43" TSL SX on H1 Double Beadlocks
74' Bronco Ranger - Street Build in Progress (351W/ZF5/NP205)
KyleQ is offline
Old 07/17/09, 04:24 PM   #11
RV77
RV77's Avatar
Tried & True Ford Blue
Springfield,IL
eBay: rcen99
Originally Posted by 70_Steve View Post
Search on Google!!!
Good write up,but did you guys notice in set 31 he forgets to mention one important item ?...........Gear Lube !!
RV77 is offline
Old 07/18/09, 06:40 PM   #12
dblank
Newbie
Dallas
Ok read most of the links and one more question for now. When setting the pinion depth if its not right right off do i have to purchase a new crush sleve every time i adjust the pinion shims?
dblank is offline
Old 07/18/09, 10:15 PM   #13
70_Steve
Old Guy
70_Steve's Avatar
Phoenix, AZ
I'm guessing your question is about the 9".
The crush sleeve is for setting pinion bearing preload. One of the first things done is to set up the pinion gear in the pinion assy. with the proper preload. The pinion depth is set by changing shims that go between the pinion assy and the case.
BTW, I would suggest using a solid spacer and shims to set pinion bearing preload, instead of the crush sleeve. Only takes a couple minutes longer to set up, and it's good for life, and for extreme service.
70_Steve is offline
Old 07/19/09, 12:46 PM   #14
dblank
Newbie
Dallas
Perfect. Thanks guys. Now all i have to do is order parts. Ya'll been a tremendous help.
dblank is offline
Old 07/19/09, 02:42 PM   #15
ken75ranger
ken75ranger's Avatar
Troy, NY
eBay: ken_75
One tip I have to add is a 4 prong hub socket fits the spanner nuts on the 9 inch very well.
'75 Ranger- with assorted parts
ken75ranger is offline
Thread Tools
Page generated in 0.33782 seconds with 56 queries
