Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 07/17/09, 07:09 PM   #1
mjmcbride1
mjmcbride1's Avatar
Fayetteville, NC
Gas smell!??!?!
Hey folks. I have seen a thread on this before but am unable to find it again. I have a 69 with a 302. The thing runs great but has an annoying and overwhelming smell of gasoline. Doesnt matter if I drive it hard on the trail or drive 2 miles to the grocery store; when I shut it down and get out, my clothes stink like gasoline......anyone out ther got any advice??!?! Thanks!!!
mjmcbride1 is offline
Old 07/17/09, 07:28 PM   #2
Pa PITT
Pa PITT's Avatar
NP435 BED LINER TOP. BED. BUMPERS. ROCKERS. 4bt P/S. FLOTHRU TAILGATE. 16'' TIR
Stephenville..TX.
do you have that vapor canister behind the driver seat ..are the hoses to it connected ...or are you setting in a pool of gas fumes..
Pa PITT is offline
Old 07/17/09, 07:50 PM   #3
chuck
chuck's Avatar
Ingram, Texas
eBay: bcbroncos
Are you talking about exhause gas or raw unburned gas? Any leaks?
BC Broncos, making Innovative ideas reality.
chuck is offline
Old 07/17/09, 08:36 PM   #4
Viperwolf1
electron whisperer
Viperwolf1's Avatar
It's not dented, it's just been environmentally streamlined!
homelessly wandering
A '69 won't have one. I think they started using sealed caps and vapor recovery in '70.
'74 beater, 5.0 mustang EFI, C4, PS, front discs, twin sticks, 3.5" susp/1" body, 33's, 4.11's, ARBs, Hickey Sidewinder, cobra hydroboost
'70 cruiser, 5.8 explorer EFI, 4R70W, PS, front discs + hydro, twin sticks, 3.5" susp/1" body, 34's, 4.88's, ARB & tru-track
Viperwolf1 is offline
Old 07/18/09, 04:50 AM   #5
stock1970
stock1970's Avatar
Olathe, Kansas
70 is when they started using the vapor recovery system, and my 70 was built in 69 so it doesnt have one either, does it still smell like gas even when the tanks are half emptly, If my tanks are full gas expands and runs down the side of my finder from the fill cap. I would check for leaks at the switch to change from tank to tank and also check all the gas lines to make sure they are not soft and mushy.. I had a leak just off the main tank because of bad line.
1970, 302, 3 on tree, drum brakes, no power anything, original engine trans ect., 62k miles and 1976, 351w, c4, 3.5 sl, 2inch bl, pwr st and brakes, 35 mtz's, twin sticks, arb front and rear, 4.88s, 31 spline yukon,
stock1970 is offline
Old 07/18/09, 09:52 AM   #6
blubuckaroo
Grease Monkey
blubuckaroo's Avatar
The Ark was built by amateurs, but the Titanic was built by professionals.
Ridgefield WA
The tank selector valve is a problem area. A new o-ring will usually fix it but I got tired of pulling the soaked flooring out after it leaked. I replaced it with one of the electric selector valve kits. I got mine from BC for about the same price as a new manual valve.
'77 Ranger/cut F&R/PS/PB/Vintage Air/2" suspension lift/1" body lift/T tie rod conversion/33-1050-15 BFG K02 tires/ 302/ Edelbrock 500 CFM 4 bbl/Aero Tanks/ Hooker Headers/ dual ex/ NV3550/ B&M shifter/ JB FabTwin Sticks/ 4.11s/rear posi.
blubuckaroo is offline
Old 07/18/09, 10:59 AM   #7
mjmcbride1
mjmcbride1's Avatar
Fayetteville, NC
It smells more like exhaust than it does raw gas. I also think that my bronco does not have the vapor system ya'll are talking about. Additionally, I only have 1 tank, so there is no switch. I checked the lines and all looks good. Would bad/faulty gaskets at the headers be an area to check?
Old 07/18/09, 11:20 AM   #8
blubuckaroo
Grease Monkey
Ridgefield WA
If it is exhaust fumes, there could be several reasons. Is the car running rich for some reason like a stuck or leaky needle valve? Stuck choke? Also depending on where your exhaust exits, you could be drafting fumes into the car.
Old 07/18/09, 11:27 AM   #9
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
Yes leaky header gaskets can cause some of it as can any open holes in the firewall.
Usually a good tune up and proper carb jetting can fix the issue. Pull your plugs are they black if so its too rich. You need smaller jets. Timing can also have a effect on how the exhuast smells to little it smells to much it smells might want to play with the timing see if you can reduce the smell and probably make it run a little better to boot 10-12 degrees usually works out about right.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 07/18/09, 11:27 AM   #10
mjmcbride1
mjmcbride1's Avatar
Fayetteville, NC
I certainly believe there are fumes drafting into the cab....Soon as I fire it up and take off down the road, there is a slight hint of exhaust or gas-like smell. It isn't to the point where it makes me nausious or uneasy; however, once the vehicle is off and I step away from it----the stench on my clothes is quite obvious there is some sort of leak somewhere.
Old 07/18/09, 11:31 AM   #11
chuck
chuck's Avatar
Ingram, Texas
eBay: bcbroncos
That is comm. if the exhause exits out the back of the bronco.
chuck is offline
Old 07/18/09, 01:36 PM   #12
mjmcbride1
mjmcbride1's Avatar
Fayetteville, NC
yeah, the exhaust exits out the back end. However, it doesn't matter if the hard top is on or if I go with no top....the same amount of exhaust smell occurs with both. Is there anyway to minimize that smell?
Old 07/18/09, 02:10 PM   #13
nutter3
nutter3's Avatar
kenai, AK
you could have a leak at the carburetor too. long time ago my dads 75 F250 was going through gas like crazy (worse than normal) along with a bad gas smell. The carb would only leak every time the throttle was moved, then it would stop leaking. so you couldnt ever track it down in the static position
nutter3 is offline
Old 07/18/09, 02:29 PM   #14
mjmcbride1
mjmcbride1's Avatar
Fayetteville, NC
nutter3---what was the fix?...did you replace the carb and problem solved?...I am desperate to get this smell resolved. My 3 yr old LOVES to ride in dads bronco but mom doesnt like it with the gas smell so prevalent.....
Old 07/18/09, 06:17 PM   #15
TBS-POPS
TBS-POPS's Avatar
ALL my drinking buddies have a severe bronco problem!!
valley springs, ca
Bronco's are extremely fussy on where the exaust exits from the vehicle.. I switched mine about 5 or 6 times to get rid of the smell. Guys have great sucess with out the rear corner on a 45 deg angle making sure it sticks out a few inches from the body. Broncos have the aerodynamics of a brick and very bad air flow underneath so you have to make sure you get it out into some air flow or it will get sucked back in... Mine runs out the side through the body in front of the rear wheel as seen in my gallery but thats a little extreme for some... Works really well and no more stinky!!
WWW.NORCALBRONCOS.COM 72, TBI 302, 435,20,FW44&9,4.56 w/pl&arb,2" & 5.5" on 37's.SOLD Broncoless for now
Broncos are like BOOBS, There always better after they've been worked on..
TBS-POPS is offline
Thread Tools
Page generated in 0.32728 seconds with 55 queries
