Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 08/13/09, 10:24 AM   #1
texfire
texfire's Avatar
NOT ALL THAT WONDER ARE LOST
LTOWN, TEXAS
Best carb for 302?
Hi all,
Was curious about ya'lls thoughts on carburetors. Which ones would work the best for my 302 (a 4 barrel or 2 barrel) and which ones are absolutely a waste of gas and money... but look nice. And does the intake make that much of a difference and if so why? Thanks in advance!
texfire is offline
Old 08/13/09, 10:33 AM   #2
daveweil1
daveweil1's Avatar
No honey that was always on there
Savannah
I had an edlebrock performer intake and holley 600cfm 4 barrel on my otherwise stock 302. I got good throttle response, decent fuel consumption and it looked good too. You can buy a summit intake/carb/air cleaner combo for a decent price right now.
daveweil1 is offline
Old 08/13/09, 10:50 AM   #3
BUSMC
Newbie
Best carb for 302?
Autolite 2100 or 4100. I went through several carbs and finally went to a factory 4100. Best my rig has ever ran on and off road. I had a Holley Truck Avenger and it just guzzled fuel. I got mine (internal spread board) through Pony Carbs. Pricey but worth it IMO.
BUSMC is offline
Old 08/13/09, 10:58 AM   #4
ep67bro
Bronco Junky
ep67bro's Avatar
I used to have time!
EasternShore, MD
Edlebrock performer intake with a 500 cfm edlebrock carb, or a 500 cfm holley. The stock 2barrel Motorcraft 2100 is a great carb too but wont give you the power of the four barrels. If it is a stock motor there is no need for larger than 500 cfm carb.
67, 289, NP-435, 3.5 lift,1"BL, 35s,custom bumpers, work always in progress. 75 uncut 302 C4 lubr, 70 sport 302 3spd no lift NO RUST!
ep67bro is offline
Old 08/13/09, 11:06 AM   #5
73stallion
BANNED
73stallion's Avatar
Don't look at me in that tone of voice!
Eugene, OR
i have a 470 truck avenger on top of my built 302 and it's plenty. a stock 2 bbl can go everywhere i can though.
73stallion is offline
Old 08/13/09, 01:55 PM   #6
steven1826
carb
I had a 600 Holley and endelbrock and went back to ford 2 barrel. I rarely need to pass anyone on the road.
steven1826 is offline
Old 08/13/09, 03:14 PM   #7
dan73
dan73's Avatar
Chickasha, Oklahoma
X2. I've tried them all. went back to the motorcraft
dan73 is offline
Old 08/13/09, 04:42 PM   #8
thumping
thumping's Avatar
Scratch'n for traction
Jacksboro Tn
X3 and could not be happier...well maybe propane but that's a different thread
thumping is offline
Old 08/13/09, 05:28 PM   #9
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
Any carb is good there are some a little better offroad and easier to tune but basically they are all the same. Unless your putting on headers I wouldnt bother switching intakes and carbs the exhuast side of a SBF needs a lot more help than the intake. It does no good to get more air into the engine if you cant get it out.
Now with that said I'll go to the otherside as I rather like 4v intake and carbs more than 2v stuff.. Stock intakes are just that stock they work for what they are and thats about it. Aftermarket intakes are designed to flow better and give you more power Usually in a slightly higher powerband than stock.
Aftermarket carbs are good because they have more support availible in the form of tuning parts so they tend to be more tuneable than stock carbs. Although the term aftermarket is relative as even most "aftermarket" carbs have been used as a Stock apllication from the factory.
Most people dont tune there carbs. They bolt it on and it doesnt run right so they say its crap. Whick is usually not the case at all its just they didnt take time to tune it. Even a stock carb can benifit from tuning but few people ever do it.
I would look for someone selling a old used setup you can pick them up for way cheap and then go from there. I like edelbrock manifolds and Holley carbs 600 cfm or less.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 08/13/09, 05:36 PM   #10
ken75ranger
ken75ranger's Avatar
Troy, NY
eBay: ken_75
I'd get a Performer manifold(short) and the carb would depend on how you use your Bronco.
Street driving, semi stock engine-stock or Edelbrock are easy to set up.
Off road- stock 2barrel, Holley TA, are easy to set up.
If you don't mind doing a bit more to set up for an off road carb- A holley 600 with vacuum secondaries (tech article in the tech file).Quadrajets can run very good off road too. It does take some time to dial them in.
High hp, high RPM, street/strip - Holley double pumper.
'75 Ranger- with assorted parts
ken75ranger is offline
Old 08/13/09, 06:33 PM   #11
ugly74
Bronco abuser
ugly74's Avatar
Just your basic rock'n'roll redneck
I've used lots of carbs,and overall I'm much happier with a plain jane holley mdl 1850 4v. they can be modded very cheap and easy to run offroad well, with much more power potential than the stock 2v motorcraft/autolite.
as for intakes, right now I have an edelbrock performer 302 (with egr blocked) and it works well. but I've also used a weiand stealth, and really that's the one I prefer.
Common sense seems to've become a rare superpower
ugly74 is offline
Old 08/13/09, 07:04 PM   #12
Ranchtruck
Ranchtruck's Avatar
I'm running a 1.12 primary 4100 on my 302. It's pretty much a 2100 most of the time but if you wind it out the vacuum secondaries open up. Nice how the tone of the motor gets lower and louder when they open up and it won't run out of steam. It runs great, and they're so simple there really isn't much to go wrong with them.
Ranchtruck is offline
Old 08/14/09, 05:18 AM   #13
iwlbcnu
iwlbcnu's Avatar
Broncos Rule!
Barboursville
I tried the 4100 and it still would overflow on steep inclines and flood out, ended up using a Autolite 4300, it's a quadrajet on a holley base basically and was used on the 68-75 Fords. Finally found one from a 68 302 Cougar and love it. Dad flopped my rig on its side the other week and said he had to cut it off.
77, 76, 74/77, 74, 66 #1111 Bronco's, plus parts rigs.
85 Mustang GT, 4 time feature car
86 Mustang GT
66 Cyclone GT, 428, 4spd
iwlbcnu is offline
Old 08/14/09, 05:37 AM   #14
clarrance
clarrance's Avatar
Maryville TN
"x-4" I love the factory carb. Although if you want to become a carb expert go buy a Holley and I promise you you will work on your carb more than you will ever drive your Bronco.
clarrance is offline
Old 08/14/09, 07:41 AM   #15
Ohio Bill
Ohio Bill's Avatar
an all nighter is when you don't have to get up at night to use bath room
Riverside, OH
That's odd i have had great success with my Holley 2bbl
Ohio Bill is offline
Thread Tools
Page generated in 0.45533 seconds with 56 queries
