Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 08/21/09, 11:34 AM   #1
73stallion
BANNED
73stallion's Avatar
Don't look at me in that tone of voice!
Eugene, OR
heater blower resistor
one of my customer's resistor has gone out on his heater blower motor. would it be the same voltage drop as a resistor for an ignition coil?
73stallion is offline
Old 08/21/09, 12:59 PM   #2
blubuckaroo
Grease Monkey
blubuckaroo's Avatar
The Ark was built by amateurs, but the Titanic was built by professionals.
Ridgefield WA
No, it's a different type of resistor, and is designed to reduce current to the fan for different speeds. Usually those blower speed resisters are mounted in the heater duct.
'77 Ranger/cut F&R/PS/PB/Vintage Air/2" suspension lift/1" body lift/T tie rod conversion/33-1050-15 BFG K02 tires/ 302/ Edelbrock 500 CFM 4 bbl/Aero Tanks/ Hooker Headers/ dual ex/ NV3550/ B&M shifter/ JB FabTwin Sticks/ 4.11s/rear posi.
blubuckaroo is offline
Old 08/21/09, 01:32 PM   #3
Steve83
Steve83's Avatar
Fullsize Bronco Guru
Memphis, TN, USA
eBay: untod
An ignition resistor would catch fire if you tried to use it with the blower. But you can use almost ANY blower resistor (any make/model/year) if you have the matching connector, and can make it fit in that duct.
Steve83 is offline
Old 08/21/09, 01:50 PM   #4
73stallion
BANNED
73stallion's Avatar
Eugene, OR
good to know, thanks guys. my knowledge on resistors is minimal unfortunately. anybody have a good used one?
Old 08/21/09, 05:12 PM   #5
Viperwolf1
electron whisperer
Viperwolf1's Avatar
It's not dented, it's just been environmentally streamlined!
homelessly wandering
The blower motor uses more current than the ignition coil so the resistor needs to have a higher wattage capability.
'74 beater, 5.0 mustang EFI, C4, PS, front discs, twin sticks, 3.5" susp/1" body, 33's, 4.11's, ARBs, Hickey Sidewinder, cobra hydroboost
'70 cruiser, 5.8 explorer EFI, 4R70W, PS, front discs + hydro, twin sticks, 3.5" susp/1" body, 34's, 4.88's, ARB & tru-track
Viperwolf1 is offline
Old 08/21/09, 09:14 PM   #6
Steve83
Steve83's Avatar
Memphis, TN, USA
eBay: untod
I bet your local junkyards have a few.
...and more resistance.
Steve83 is offline
Old 08/21/09, 09:34 PM   #7
73stallion
BANNED
73stallion's Avatar
Eugene, OR
well, gotta hit the wrecking yard this week for a new set of visors for the CR-V, so i'll look around for one. thanks again!
Old 08/21/09, 09:45 PM   #8
Viperwolf1
electron whisperer
Viperwolf1's Avatar
Originally Posted by Steve83 View Post
I bet your local junkyards have a few. ...and more resistance.
I bet the resistance is pretty close. Within a couple ohms.
Old 08/21/09, 11:53 PM   #9
Steve83
Steve83's Avatar
Memphis, TN, USA
eBay: untod
Well, it'd have to be since the ig. resistor is only 1.05-1.15 Ohms; the M2 blower resistor is .25; M1 is .55; L is 1.3 , and they're added (so M1 speed uses .8 Ohms; L uses 2.1).
Since the blower draws ~20A, the resistors have to dissipate ~50W of heat.
Steve83 is offline
Old 08/22/09, 12:36 AM   #10
DirtDonk's Avatar
San Jose, CA
Hey Steve, is that last number (50w) correct? I didn't follow each of your numbers and equations, but the rating seems low, since the Mallory ignition ballast resistor is rated at 200 watts.
Is it just that we're talking about current on the one hand, and heat on the other? Or are they one in the same in this case? And if so, would that 200w rating then be sufficient?
I'm not recommending a full-size resistor in place of a true heater-resistor. I'd use a standard heater type, even if only for convenience and safety (with the coils inside the plenum air stream), but it would appear to at least be a functional alternative from an electrical standpoint at least.
Which is why I'm asking.
DirtDonk is offline
Old 08/22/09, 09:41 AM   #11
Steve83
Steve83's Avatar
Memphis, TN, USA
eBay: untod
I did some quick calculations last night, so I might have goofed, but I think it's right. It seems about right.
Current (Amps, "i") isn't heat; it's the flow rate of electrons. Heat (Watts, "W") is power lost/wasted. Voltage (Volts, "V") is the 'pressure' of electricity. Resistance (Ohms, "R") is the 'friction' of electricity. V = R * i ; W = V * i = R * i * i .
My '83 never had a resistor, and I don't remember what was in Frank's '75, so it surprises me that yours is a 200W. If so, it SHOULD work fine, as long as it's in free or forced air (so it can lose that heat), AND your connections can take the heat. If you confine it in a wiring harness or even wrap it with tape, it'll start a fire. That's why all blower resistors are built to go in the airstream, and are bare. Your ig. resistor is probably ceramic-cased, right?
Steve83 is offline
Old 08/22/09, 10:26 AM   #12
73stallion
BANNED
73stallion's Avatar
Eugene, OR
man, you guys lost me a long time ago with amps vs watts, i never did learn that.
Old 08/22/09, 11:13 AM   #13
DirtDonk's Avatar
San Jose, CA
Just wait 'till he starts talking calories then!
DirtDonk is offline
Old 08/22/09, 11:23 AM   #14
DirtDonk's Avatar
San Jose, CA
Did they just regulate it directly in the switch then? Or is there another method of resistance used there? Just curious. Might come in handy someday to know that.
If so, it SHOULD work fine, as long as it's in free or forced air (so it can lose that heat), AND your connections can take the heat. If you confine it in a wiring harness or even wrap it with tape, it'll start a fire. That's why all blower resistors are built to go in the airstream, and are bare.?
Definitely! That's what I was suggesting when I said it might be "less convenient and safe" to mount a non-standard type in anyplace other than the original location. It's just way bigger than a standard heater version. But "could" be used if you did it carefully.
Yep, just a standard resistor and looks like any other one you've seen for the last 50 years or so. May just be "updated" with heavier components. In the text, they seem to be claiming that it's "variable based on ambient temperature", if I'm reading their add-type correctly, but it seems to me that all resistors are temp-variable. Wouldn't they be?
I can send you the image and text from the catalog if you want to check it out or post it here for the others.
DirtDonk is offline
Old 08/22/09, 11:28 AM   #15
73stallion
BANNED
73stallion's Avatar
Eugene, OR
no i know how to count those, i just don't (enter guacamole bacon six dollar burger here).....
Thread Tools
Page generated in 0.32740 seconds with 54 queries
