Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 09/06/09, 07:21 AM   #1
JohnJohn
JohnJohn's Avatar
77 Ranger Frame Off
Leesburg, VA
How to install a Gas Pedal Spring?
I searched the forum and my manuals but canít find a good diagram to show me how to put the gas pedal spring on.
There is a small diagram in Tom's Bronco parts catalog but it is not clear enough for me.
Anyone have a picture of the gas pedal spring installed?
It is the small z shaped spring that holds the gas pedal in place on the rod.
77 Ranger 5 year frame off nut and bolt restoration by me with EFI, 4.11s, Cage 3.5" lift 2" body lift, MTZ 35s on 17" Allied Monster Beadlocks, Duff Long Arms, BC TRO, Kiser Riser, Protofab bumpers, Warn winch. 1970 Trail rig with 37's on Trail Worth Fab H1 beadlocks, long arms, 302, C4.
JohnJohn is offline
Old 09/06/09, 05:08 PM   #2
JohnJohn
JohnJohn's Avatar
77 Ranger Frame Off
Leesburg, VA
After several frustrating attempts I got it on and I am 99% sure it is in the right spot.
What got me was a little tab on the back of the pedal that I thought the spring was using.
If anyone needs a pic I will post one.
JohnJohn is offline
Old 09/07/09, 05:53 AM   #3
Jeepster
syracuse
If I read this right, The spring does not go on the pedal. Its installed up by the carb. It hooks to the carb linkage and top of the intake. Usually to a bracket.
Jeepster is offline
Old 09/07/09, 06:41 AM   #4
JohnJohn
JohnJohn's Avatar
77 Ranger Frame Off
Leesburg, VA
Thanks Jeepster.
There is a spring that goes behind the gas pedal to keep it upright so it does not flap around. It holds on to the pedal rod and springs the pedal forward.
I am sure I got it on right.
JohnJohn is offline
Old 09/07/09, 07:05 AM   #5
bronco loco
It never ends
bronco loco's Avatar
I'm Broke because I own a BronKo
Valley Stream L.I.
I also searched for an install guide for the pedal spring with no luck, it just snapped on back of the pedal, I know it works because the pedal returns when I let go off the gas, made a big difference, I did not like the "flat" pedal feeling.
72 Sport uncut, 2.5 WH front coils 3.5 WH rear leaves pack
98 Explorer drivetrain
bronco loco is offline
Old 09/07/09, 08:13 AM   #6
jesus888
jesus888's Avatar
69 and counting
Atlanta, GA
Take a picture and post it
jesus888 is offline
Old 09/07/09, 12:37 PM   #7
Madgyver
Bronco Madman
Madgyver's Avatar
RADIO FLYER ROCKS
Honolulu,Hawaii
After seeing what the aftermarket or stock had available, I decided to make my own bracket to fit my needs.
I used a 5/16" pushrod from an old engine and welded up a bracket.
Originally Posted by br0nc0xrapt0r View Post
your so full of shit your eyes are brown.
Haha.
Madgyver is offline
Old 09/07/09, 03:52 PM   #8
NicksTrix
NicksTrix's Avatar
Dream Big
Denver, NC
eBay: NicksTrix
here ya go. this might help someone down the road as well.
NicksTrix is offline
Old 09/07/09, 03:55 PM   #9
Tito
CB Fire Starter
Tito's Avatar
The life of Tito is a path of mystery on the way to enlightenment.
Bakersfield, CA
Thanks Nick, I couldnt figure out how the wife's went back on, now if I can find it.....
Tito is offline
Old 09/07/09, 04:13 PM   #10
bronco loco
It never ends
Valley Stream L.I.
that is the way I end up setting mine up.
Old 09/07/09, 04:19 PM   #11
NicksTrix
NicksTrix's Avatar
Dream Big
Denver, NC
eBay: NicksTrix
sure thing tito. those springs are tough to find if you misplace yours. i scavange them when i'm at the upull yard. for some reason you get a truck every now and then that is missing it. the pedal feels wierd without it imop.
i've found a few different styles at the yard. they all do the same thing..
Old 09/07/09, 06:12 PM   #12
bronco loco
It never ends
Valley Stream L.I.
Tom's Bronco parts is where I got mine from: http://www.tomsbroncoparts.com/product.php?id=1038
Old 09/07/09, 06:17 PM   #13
NicksTrix
NicksTrix's Avatar
Dream Big
Denver, NC
eBay: NicksTrix
i found they carried them also later on. still 8 bucks apiece for the little guy.
another reason why it pays to keep track of your parts when you take things apart...
Old 09/08/09, 01:14 AM   #14
Madgyver
Bronco Madman
Madgyver's Avatar
RADIO FLYER ROCKS
Honolulu,Hawaii
My bad.....
I was thinking throttle return spring...duh
Haha.
Madgyver is offline
Old 09/08/09, 07:11 AM   #15
JohnJohn
JohnJohn's Avatar
77 Ranger Frame Off
Leesburg, VA
Thanks Nick!
The one from Toms is not exactly like the original but it works in the same spot.
Now I know what that little tab was for.
JohnJohn is offline
Thread Tools
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.41530 seconds with 59 queries
