Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 10/24/09, 07:47 PM   #1
Greg Bell
Bronco weight reduction
Hey guys,
Has anyone ever spent any effort cutting their Bronco's weight? I know that is generally not a major consideration in trucks but I was just wondering.
Any threads on this that I have missed?
1967 Bronco!
Greg Bell is offline
Old 10/24/09, 07:58 PM   #2
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
Other than removing the hard top, swapping the steel body for a fiberglass one and getting every aluminum part availible to replace cast iron ones. Almost all the other popluar stuff is almost always heavier than what came stock.
Of course you remove the top and then you need a roll cage so weight goes back on.
Not to mention trying to reduce the weight could just get expensive.I think your wallet would be the only thing losing weight.
When it comes down to it I dont think its really worth all the effort.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 10/24/09, 09:48 PM   #3
t.lay
t.lay's Avatar
Grayslake, IL
Seems like just the frame and running gear is around 2,000lbs. Body is pretty simple, so not a lot of places to lose weight - losing the top and doors might shave a couple hundred pounds - a decent cage puts most of that back on. Good bumpers can be over 100lbs per end. Even going glass with no doors or top and you'll still be around 3000lbs. That's pretty light for an EB
Build a man a fire and he'll be warm all day. Set a man on fire and he'll be warm the rest of his life.
t.lay is offline
Old 10/24/09, 10:25 PM   #4
broncotime
broncotime's Avatar
Grapevine, Texas
Ditch the doors, tail gate, hard top, spare tire, aux tank, back seat, steel hood, and swap to a 6 cylinder engine. After that, I guess you could start drilling holes in stuff to lighten it up, but that's a lot of effort for little return.
broncotime is offline
Old 10/25/09, 12:09 AM   #5
av bronco
av bronco's Avatar
If it aint broke then fix it till it is.
Palmdale CA
Just make up for the extra weight with a mean ass motor
av bronco is offline
Old 10/25/09, 04:41 AM   #6
Dan74Bronc
Dan74Bronc's Avatar
Chandler, Az
I'm all for more CID. Makes up for all the trail armor weight.
'74 Bronco Ranger, 351 FITech EFI, ZF 5 speed, 411's and 35's and A/C. Daily driver.
Dan74Bronc is offline
Old 10/25/09, 05:46 AM   #7
DonsBolt
DonsBolt's Avatar
Chestnut Hill, Mass
All alluminum engine, block, heads, intake.
Alluminum pullies
Alluminum radiator
Hight torque mini starter
Replace steel wheels with alluminum wheels
Keep it stock height, as bigger tires and wheels weigh more
If you will never take it off road, gut the front axle, remove front driveshaft, replace the trans with a mustang 5 speed, and ditch the transfer case
1977 Bronco Ford Racing 5 Liter NV3550 456 Gears - 3.5 Suspension 35's
2011 RoushCharged Mustang GT 5.0 675RWHP 10.028@139mph
[COLOR="silver"]
DonsBolt is offline
Old 10/25/09, 06:44 AM   #8
357Bronco
357Bronco's Avatar
I'm really not a jerk...really
New Hampsha
Just to give you an idea of what it takes to shed weight. My Bronco is a glass tub, no tailgate, doors are stripped of all glass and frames,windshield frame is fiberglass and the windshield is lexan. No top, and the seats are racing plastic type. I have no inner front clip, and my radiator support is literally just a radiator support, made out of maybe 8lbs of tubing and mounts. I have no lights, heater, wipers, or bumpers. Aluminum?...radiator, cylinder heads, intake, dash, door panels, trans pan, fuel cell, and all the fuel line fittings. My rear 15x15 rims are less then ten lbs a piece, and the cut paddles are under 30lbs each. Fronts are regular aluminum rims, but the tires are probably 25 or less. I added weight with the cage, harnesses, and some extra bracing on the rear axle, and driveshaft loops. .....3086lbs, without me in it, and maybe 8gallons of race fuel in the cell.
someone go back and get a shit load of dimes
357Bronco is offline
Old 10/25/09, 06:57 AM   #9
nrramse
Albuquerque
I'm curious - what goal are you trying to accomplish by losing the weight? Better quarter mile times? Fuel economy?
The reason I ask is that, in many cases, traction is better if there's more weight on the tires and so if you're into offroading you may not want to lose weight.
Newell
1970 Bronco - mine since '84, 302 bored .040, 500cfm Edelbrock 4bbl on Ford cast iron intake, Pertronix Ignition, 3" Skyjacker Lift, long-tube headers, disc brakes, NP435.
nrramse is offline
Old 10/25/09, 07:02 AM   #10
wildbill
Old Bronco Guy
wildbill's Avatar
Broncos Rule! WildBill's 66
Topeka Kansas USA
Thumbs up
My 68 has had a lot of steel removed from it. cut about 4" from the bottom all around. Front inner fenders are gone coil springs are gone now has leaf (2) no windshield roll cage abour 4" shorter than a stock typ. Has a glass hood and the rear floor pan was removed and a pc. of about 22ga. tin was used. Gas tank gone now has about a 2.5 gal tank. Also no front brakes. Has a 2 speed trans (lenco) and D20. Was set up as a sand drager made to go 300' very fast. Bill
wildbill is offline
Old 10/25/09, 07:08 AM   #11
357Bronco
357Bronco's Avatar
New Hampsha
Newell
If your wondering about mine, sand drags, may go to a shallow mud race, but was built for the drags.
Old 10/25/09, 07:09 AM   #12
357Bronco
357Bronco's Avatar
New Hampsha
I need some pics, didn't realize there was another drag Bronco here.
Old 10/25/09, 07:18 AM   #13
nrramse
Albuquerque
I was thinking of Greg, but it did get me curious to look at your gallery. That Bronco looks like a lot of fun! I like the tow vehicle too - sweet!
Newell
nrramse is offline
Old 10/25/09, 08:27 AM   #14
1WILD69
1WILD69's Avatar
south range
I cut Everything off that didn't need to be there. Took 26" out of the grill and made everything else match up, bare bones with skins. I did it to keep the body out of the trees and rocks but it hasnt worked for me yet
1WILD69 is offline
Old 10/25/09, 08:38 AM   #15
broncomitch
broncomitch's Avatar
dont be a sheep in a jeep!
west jordan, utah
eat less McDonald's and start running
1971 bronco sport,mild built 351w,c6,strong box,np205,HP Dana60,srw 14bolt,disc's front and rear,16"rock coil overs,H1's & 44" tires,4.10's,3link front,56" springs,ez wiring,TBI injection,
Build thread
http://classicbroncos.com/forums/sho...d.php?t=196087
broncomitch is offline
Thread Tools
Page generated in 0.41299 seconds with 58 queries
