Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 12/05/09, 04:03 PM   #1
BroncoinAlaska
BroncoinAlaska's Avatar
San Antonio, TX
EFI Filter Size or CFM Rating
Tunning the EFI setup in the Bronco and have noticed that the cone filter is choaking off the intake and the moter runs much better with the filter off. I have a 5" cone K&N with a 3" inlet. The mustang guy that i took the Bronco too sugested a sheild and a filter that can flow 880 cfm for my application.
The sheild is to keep the air off the filter that is being kicked around the engine bay from the explorer fan.
Here is a breakdown of the EFI parts
Throttle body 70mm
MAF 76mm
Trick Flow Upper and lower Intake
30# injectors red colored
Here is the motor befor it went in:
http://images1f.snapfish.com/2323232...96%3A338nu0mrj
Where can I find a filter with the CFM rating. Looked at K&N's website and no luck. I would pefer a cone filter. Any ideas guys?
1977 Half Cab Ranger - 302 EFI, Explorer Sepintine, 3.5" Duff Monster Suspension, 2" BL, D44 Front 4.56 ARB w/RCV's, Ford 9" Rear 4.56 ARB 31 spline
BroncoinAlaska is offline
Old 12/05/09, 07:46 PM   #2
70_Steve
Old Guy
70_Steve's Avatar
If You're Going to Do It, Over-do It
Phoenix, AZ
Nice looking motor!!!
Your question got me thinking, since I just placed an order for a K&N filter for my 351. I did find a page on K&Ns web site that "helps" in filter selection.
http://www.knfilters.com/filter_facts.htm#SELECT
That page includes a formula to determine how many square inches of filter you need for a given size engine at a max RPM. The example given was a Chebby 350 with a 5500 redline. Their formula determined this engine needs 92.4 square inches of filter.
The 350's close enough to my 351, and I just bought a RU-3620 oval filter. At the time, I selected it based on the "bigger is better" principal. I did the calculations on this filter and came up with 134 square inches. So... I should be good!!!
'70 Sport, 351W EFI, NV4500, D20 w/Teralows, 4.56s Dana 44 w/Ox and 9" 31 spline Detroit, 35" KM2's, 3 1/2" lift, 2" body lift, 4x4x2 PS, some other stuff I forgot about...
"If it's got tits or tires it's gonna be a problem"
70_Steve is offline
Old 12/06/09, 04:44 AM   #3
ransil
ransil's Avatar
Pittsburgh Pa.
Look into AEM filters, no oil..
http://www.aempower.com/
ransil is offline
Old 12/08/09, 01:58 PM   #4
BroncoinAlaska
San Antonio, TX
Anyone have an easy CFM rating on cone filter K&N or AEM?
Thread Tools
Page generated in 0.38997 seconds with 58 queries
