Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 12/14/09, 08:24 AM   #1
BluebroncoNC
BluebroncoNC's Avatar
Asheville, NC
Gvw? Anyone know what thier Bronco weights?
Curious, if someone has gone throught a weight station and can tell me how heavy thier truck is, and if it is steel bodied or fiberglass.
BluebroncoNC is offline
Old 12/14/09, 08:44 AM   #2
feitctaj
FNG
feitctaj's Avatar
68&Iou1
Group W Bench
http://classicbroncos.com/forums/sho...a+bronco+weigh
Just remember kiddies the Bible was Written by folks that KNEW that the World was Flat
feitctaj is offline
Old 12/14/09, 01:19 PM   #3
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
It has been a while so another refresher class in weight codings
GVW Gross Vehcile Weight, the max weight the vehicle is certified to weight with passengers/payload.
GAWR Gross Axle Weight Rating (front and rear), the most weight that axle is rated to weight when you run that single axle over the scales.
Note the GVW is always less then the GAWRs combined. If it were not then you could never reach GVW as you would be exceeding the the GAWRs.
Then there is the GCWR Gross Combined Weight Rating which is the max weight of the vehicle and trailer. Note that the GVW nor the GAWRs can be exceeded when loaded to GCWR.
Now all those ratings. What do they mean? Well they are ratings. For the most part it states that the vehicle will not be damaged as long as you stay under the limits and it complies with the safety standards of the day as the vehicle was originally equipped. Lifted, larger tires are not as originally equipped. You may have tires that have a higher load rating but that does not mean the brakes or wheel bearings are any better.
Now all of this is ratings. Great, you still don't know what they weigh. I have seen people have very stripped versions down around 3300 Lb and loaded trail rigs over 3 tons. I rolled across the scales at the race track at about 2 tons with me in it and little extra on it. The heaviest I rolled across the scales was nearly 5 tons coming off a gravel yard pulling a trailer. It was only 2 miles back to the house and that was over loaded. I pulled a load of wet dirt once at night that I know was way heavier then any of the gravel runs I ever did. Pulling the load was no problem, safe handling and safe braking was another story.
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
“How hard can it be?”-Clarksonius 4th century BC.
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is offline
Old 12/14/09, 01:47 PM   #4
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
Yeah, mine is darn near heavy w/the solid ass front bumper the PO put on there, OMG.. lol
sprdv1 is offline
Old 12/14/09, 03:45 PM   #5
BluebroncoNC
Asheville, NC
Thanks for the thread link.
Must
Learn
To
Search.
>mutters<
Old 12/14/09, 04:48 PM   #6
Larry B
Larry B's Avatar
Medford
4000 lbs close to stock steel body, weighed it a number of times
Larry B is offline
Old 12/14/09, 05:40 PM   #7
Z Bronco
Z Bronco's Avatar
Bend
A LOT! Mine has Hanson front and rear bumpers, Warn 8274 winch, BCB's Belly Pan, 3/16" 4 X 4 sguare tube rockers, NWMP main and aux. tanks..........plus me!
Z Bronco is offline
Old 12/14/09, 08:29 PM   #8
mustangtoby
mustangtoby's Avatar
Jeep rescue vehicle
southwest Colorado
Last time I weighed mine, it was 4400 w/me in it. Since then I've added home made front and rear bumpers, and a winch. Probably added a couple of hundred pounds with that.
(o====o)
I own nothing but Fords, but I'm paying for Chevies and Dodges!
mustangtoby is offline
Old 12/14/09, 08:38 PM   #9
redneck0372
redneck0372's Avatar
Don't any of ya have the guts to play for blood
Lebanon,OR
last time i did mine it was just over 4200 with me in it all steel 6cyl motor and no back seat and im 300lbs
67 Uncut old navy bronco 200 6cly 3speed on the floor
redneck0372 is offline
Old 12/15/09, 12:51 PM   #10
JB Fab
JB Fab's Avatar
The doctor said "if it hurts, don't do it"
Salem, Oregon
Weight 6640lbs 3880 front / 2760 rear (approx 60/40 split)
Can you say "lawn dart"!
JB CUSTOM FABRICATION LLC
www.jbfab.net
JB Fab is offline
Old 12/15/09, 12:56 PM   #11
JB Fab
JB Fab's Avatar
Salem, Oregon
4720lbs fully loaded for a hunting trip.......
www.jbfab.net
JB Fab is offline
Thread Tools
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.31079 seconds with 55 queries
