Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 12/23/09, 07:36 PM   #1
broncoP
broncoP's Avatar
Broncos Rule!
Point Roberts, WA
What is best paint for painting headers
Anyone had any luck painting headers, if so, what kind of paint did you use? I know it has to be for high heat, maybe one works better than another?
broncoP is offline
Old 12/23/09, 09:22 PM   #2
Bradsp8
Bradsp8's Avatar
Williamsburg
Try the high temp paint in a spray can at most auto parts stores. I've also heard that some use the spray paint in the hardware stores for BBQ grills as it can withstand the high temps also.
Bradsp8 is offline
Old 12/23/09, 10:03 PM   #3
Vintage Steel
Vintage Steel's Avatar
Currently Broncoless
Post Falls, ID
I had the ones on my c-10 Chevy powder coated, they came out great.
cost me about $40
I got news for ya'. If the top don't come off, IT'S A STATION WAGON!!!
VOTE FOR CLASSICBRONCOS.com
My little gray mule: build thread
Vintage Steel is offline
Old 12/23/09, 10:04 PM   #4
73stallion
BANNED
73stallion's Avatar
Don't look at me in that tone of voice!
Eugene, OR
i heard about VHT making some good high temp paint for headers.
73stallion is offline
Old 12/23/09, 10:28 PM   #5
sicaz66
sicaz66's Avatar
econo box crusher!
san diego
none. they will ALL burn off. pay for the coated ones or dont waste your time.
sicaz66 is offline
Old 12/23/09, 11:52 PM   #6
Smokeater11
Smokeater11's Avatar
Improvise, Adapt, & Overcome!!!
Auburndale,FL
I had a set sandblasted and then sprayed them with VHT and they looked like they were brand new. They held up pretty well considering they were on a circle track racecar burning 112 octane fuel and bolted to a motor that was all tricked out. I chose to have them sandblasted again after our 18 week race season but it wasn't because they were messed up I was gonna make some changes to them and wanted bare metal to work with. Did the work, cleaned them real good and sprayed them again. Looked like brand new again. If you'll have them sandblasted and then spray them with the VHT it'll stick just fine.
Stupid people pay my mortgage.....
RIP MStark Trail Leader for Heavens Bronco club
Smokeater11 is offline
Old 12/24/09, 01:06 AM   #7
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
Circle track is way different than everyday real world driving in a 4x4. Paint burns off period. While usually the bottom end of the headers may stay looking good the top end near the head will turn white. Now if you paint the headers white then it wont be as noctiecable. There are some ceramic based paints but still unless you prep the headers correctly like sand blasting it wont stay on either.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 12/24/09, 06:40 AM   #8
No Lemon
No Lemon's Avatar
Phoenix
This stuff works great. http://www.columbiacoatings.com/category_s/7.htm
No Lemon is offline
Old 12/24/09, 08:25 AM   #9
JIMS74
JIMS74's Avatar
BRONCOS ARE A SICKNESS!!!
PORTSMOUTH, VA.
I sandblasted a set of old headers that had a flame spray aluma coat on them, and had rusted up pretty good. Painted them with rustoleum 2000 degree high heat silver and it has held up with no flaking or peeling for about 1000 miles in last six months. The paint has stuck well to the sand blasted surface so far.
Jim
JIMS74 is offline
Old 12/24/09, 08:42 AM   #10
74creamsickle
74creamsickle's Avatar
Perkasie.PA
Check out www.eastwood.com under their coatings. They have a paint a buddy of mine used on stock manifolds and they look GREAT !! I'm going to try it on my headers when I get around to it.
1974 Bronco 2 1/2 WH LUBR
1962 Ford Fairlane
1923 Ford Model T
74creamsickle is offline
Old 12/24/09, 09:39 AM   #11
Sac '68 sport
Sac '68 sport's Avatar
Some men are Baptists, others Catholic, my father was an Oldsmobile man
Orangevale
After all the OG paint burned off mine, I "blued" them. Get them hot, a little oil on a rag, hold your breath and start wiping...They got a nice dark blue color and don't show any surface rust at all after 5 years. The paint looked better for the week or so it stuck but the bluing looks much better than flaking paint and rust.
Sac '68 sport is offline
Old 12/24/09, 09:54 AM   #12
Hawkdoc
Hawkdoc's Avatar
Northern Alabama
FLY ARMY
A friend of the family restores antique tractors and he swears by the 2000 degree BBQ paint. Thats all he uses and with great results. Gotta sandblast them first though.
Hawkdoc
Its a work in progress that seems to never end!!
Hawkdoc is offline
Old 12/24/09, 09:56 AM   #13
67ster
Broncos Rule!
Old dirt tracker trick from the 40s-50s, clean the surface by sandblast or chem. stripping , get hot and wipe castor oil on surface , heap big smoke and it might have to be done several times to build a carbon layer but it works .
67ster is offline
Old 12/25/09, 06:15 PM   #14
VT_Don
Registered User
I'm continuely amazed how many people offer suggestions with absolutely no first hand experience.
Having tried nearly every product on the market, the only ones I've had long term success with are, thermal spray and professionally applied ceramic coatings. Lot to be said for TIG welded stainless.
VT_Don is offline
Old 12/25/09, 06:56 PM   #15
RubberTramp
I used the VHT high temp then I wrapped them with header wrap havent had a problem in 8 months with these header that i have on there now!
RubberTramp is offline
Thread Tools
Page generated in 0.34503 seconds with 54 queries
