Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 01/18/10, 06:22 PM   #1
malibubronco
Newbury Park
Original EB Tire Size
What size tires do I look for If I want something close to the
original EB size.? The only tire I have left is the orig. spare
and it just says 15x7. Thanks!!
malibubronco is offline
Old 01/18/10, 06:26 PM   #2
Jonboy69
225 75 15 is probably a current size that is close to the original. I think original size was like a g78 x 15 but not sure what exactly it means. Do you have a stock & uncut bronco you are trying to make 100% correct ? I just removed 235 75 15 tires from my stocker because I wanted to go a bit bigger & more aggresive. I put on BFG 30 x 9.5 x 15 & this is about as big as you can get on a stock/uncut.
Jonboy69 is offline
Old 01/18/10, 07:36 PM   #3
Quick & Dirty
Original tires varied by load rating
E78 x 15
G78 x 15
L78 x 15
7.00 x 15
The 7 x 15 was the heavy duty truck tire, the others were passenger car tires.
Here is a conversion chart from the old bias designations to the modern.
http://www.vintagecarconnection.com/...sion_chart.htm
Quick & Dirty is offline
Old 01/18/10, 07:41 PM   #4
deltarat
deltarat's Avatar
Drew,Ms
E78 x 15
G78 x 15
L78 x 15
7.00 x 15
I believe the 7" was tread width rather than section width as modern tires are measured. 7" = 178mm, so a 225 section width would probably be close.
What height are stock tires? Trying to figure the ratio for 35s back to stock.
It's OK to give out, but NEVER give up.
deltarat is offline
Old 01/18/10, 07:42 PM   #5
blubuckaroo
Grease Monkey
blubuckaroo's Avatar
The Ark was built by amateurs, but the Titanic was built by professionals.
Ridgefield WA
Our '77 came with Firestone G78-15 fiberglass belted tires and it had the 4900 lb package.
'77 Ranger/cut F&R/PS/PB/Vintage Air/2" suspension lift/1" body lift/T tie rod conversion/33-1050-15 BFG K02 tires/ 302/ Edelbrock 500 CFM 4 bbl/Aero Tanks/ Hooker Headers/ dual ex/ NV3550/ B&M shifter/ JB FabTwin Sticks/ 4.11s/rear posi.
blubuckaroo is offline
Old 01/18/10, 07:57 PM   #6
Quick & Dirty
I have the owners manual for my 74, and it lists the E78 for 4300 and 4450, and G78 for 4500 and 4900. I believe the larger sizes were optional.
Here is another conversion chart
http://www.angelfire.com/on/geebjen/tires.html
It lists the E78 as 26.6" the G78 as 27.7"
Diameter of P metrics are easy to calculate. Say 225/75-15
225 is the section width, 75 is the aspect ratio.
225 x .75 = 168.75 this is the height from tread to rim
168.75 x 2 = 337.5mm = 13.29
13.29 + 15 = 28.28"
Old 01/18/10, 08:19 PM   #7
malibubronco
Newbury Park
Thanks for all the great info. Anyone is Thousand Oaks Ca area want to get rid of some stock tires let me know! Thanks again guys!!!
john
Old 01/18/10, 11:38 PM   #8
mlaird
mlaird's Avatar
Houston,TX
nebraska tire has some 7-15 mud tires for $69 right now. that size is almost obsolete with aggressive tread
mlaird is offline
Thread Tools
Page generated in 0.28850 seconds with 54 queries
