Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 03/21/10, 08:50 PM   #1
66fora69er
66fora69er's Avatar
Austin
Radio Antenna
Does anyone have a recomendation on a good replacement for a stock antenna, possibly something rubber like that wont get ripped off on the trail?
Also, the wife bought me a radio for the eb (she's a good girl) and it will be going into my tuffy console. any install advice would be appreciated
66fora69er is offline
Old 03/21/10, 08:53 PM   #2
Wyflyer
Wyflyer's Avatar
Brighton, Colorado
X2, I was wondering the same thing today
"not a project for dreamers it does take some work to build a car"-Craigslist Bronco for sale
Wyflyer is offline
Old 03/21/10, 08:58 PM   #3
gtownky
gtownky's Avatar
I get something everytime I go hunting and sometimes I even fire a shot
Cynthiana,KY
eBay: gtownky
I have been thinking about going with a small boat antenna on mine and fill in the hole the org antenna hole. My pontoon has a small flat antenna that is stuck to the inside if the console with double sided tape. I think it would fit nicely upunder the dash. Its about 12 inches long and half inch wide and a little thicker than folder. Just an idea for ya.
gtownky is offline
Old 03/21/10, 10:31 PM   #4
DirtDonk's Avatar
San Jose, CA
I picked up a Taurus antenna with it's recessed base. Looks like the reverse of a Bronco base. It's a single, solid mast, like most external antennas these days.
Figure if it takes a hit bad enough it'll just bend and I can bend it right back. Don't know how well/easy the base will mount, but I'm going to give it a go.
DirtDonk is offline
Old 03/21/10, 10:35 PM   #5
RustyShackelfor
Centerville, TN
I would base at least some of my selection on how far away from the radio stations you are. The radio stations here are about 50 miles away so I have to use a decent antenna to pick anything up.
I like the isuzu trooper windshield mount antenna and that is what I am planning on going with.
RustyShackelfor is offline
Old 03/21/10, 10:39 PM   #6
Viperwolf1
electron whisperer
Viperwolf1's Avatar
It's not dented, it's just been environmentally streamlined!
homelessly wandering
Can't you just collapse the antenna down when on the trail?
'74 beater, 5.0 mustang EFI, C4, PS, front discs, twin sticks, 3.5" susp/1" body, 33's, 4.11's, ARBs, Hickey Sidewinder, cobra hydroboost
'70 cruiser, 5.8 explorer EFI, 4R70W, PS, front discs + hydro, twin sticks, 3.5" susp/1" body, 34's, 4.88's, ARB & tru-track
Viperwolf1 is offline
Old 03/21/10, 10:42 PM   #7
DirtDonk's Avatar
San Jose, CA
That's a great point. I'm changing mine though because I never liked the overall reception and just wanted to try something more modern and less trouble prone than a multi-sectional mast type.
All my subsequent antennas, were multi-sectional, but didn't retract all the way into the body like the stock one did, so they all had springs. Never had a problem with forgetting to lower it and breaking 'em off, but they couldn't pull in many stations right here in the middle of radio-land central.
DirtDonk is offline
Old 03/22/10, 12:18 AM   #8
admin
Administrator
admin's Avatar
Just your friendly, neighborhood webmaster...
Phoenix, AZ
I followed SACHEM's lead and used one from an Isuzu Trooper. Instead of being fender mounted where it gets ripped off by trees, the Trooper one fits along the edge of the windshield frame. It works great.
Tech article here: http://classicbroncos.com/tech/isuzu-trooper-antennae
http://classicbroncos.com/tech/wp-co...antennae06.jpg
Jon Hanna
webmaster@classicbroncos.com
http://ClassicBroncos.com
'72 Bronco, stock 302 2V, NP435 4 speed, Chevy discs, PS, 3 1/2" susp lift + 2" body lift, 33"x12.50-15 BFG KM2's, 4.11 gears (D44 and Ford 9")
admin is offline
Old 03/22/10, 06:50 AM   #9
Heus33
Heus33's Avatar
You down with HID? Yeah you know me!
Buffalo, NY
I used my stock antenna but ran it under my dash behind the glove box. It doesn't need to be exposed to pick up a signal. Works great for me.
There are other "ribbon" like antennas that you can run inside your windshield above the rear view mirror too but they're a bit pricey.
Heus33 is offline
Old 03/22/10, 07:02 PM   #10
66fora69er
66fora69er's Avatar
Austin
The one that came on my 66 is on a spring base and might survive. And to be honest I havent missed radio when on the trail...havent even had radio up to this point. the antenna is off the truck now and I was debating on whether to weld that hole up or find something to stick in there. Thanks for all of the suggestions
Old 03/22/10, 07:05 PM   #11
66fora69er
66fora69er's Avatar
Austin
Thats a good idea, thanks
Old 03/22/10, 10:22 PM   #12
albino
Newbie
Sacramento area
I run a flexible rubber coated antenna that is about a foot and a half long. These can be found at Kragen. I have never had reception issues with it.
albino is offline
Old 03/23/10, 05:17 AM   #13
74creamsickle
74creamsickle's Avatar
Perkasie.PA
That is the antenna I use. It is up under my dash. It is also an amplified antenna so reception is good. I like the look of the Bronco without an antenna.
1974 Bronco 2 1/2 WH LUBR
1962 Ford Fairlane
1923 Ford Model T
74creamsickle is offline
Old 03/23/10, 05:29 AM   #14
Wyflyer
Wyflyer's Avatar
Brighton, Colorado
Got a pic?
Wyflyer is offline
Old 03/23/10, 10:16 AM   #15
7bronco6
7bronco6's Avatar
"bronc-o" = "broke-o"
PA
I'm using this. Hidden Antenna
1976ish bronco with a 1994ish 5.0
7bronco6 is offline
Thread Tools
Page generated in 0.33133 seconds with 58 queries
