03/28/10, 12:49 PM
#1
Member of WOHVA
Neenah WI
The breaking of my 44 was getting old so I put an 1986 F 350 Dana 60 in the front was my Bronco . We cut 8 inches off the passenger side only . Hubs and Brakes are changed so I can run 5 on 5 1/2 by 15 rims Now it has dam near the same track width as a stock Bronco 44 . I will be putting coilover shocks in it next winter
http://s976.photobucket.com/albums/a...%2060%20build/
Jay
03/28/10, 04:33 PM
#2
Whittier, CA
looks BAD A$$. what years do the easiest Dana 60 installs come from? what should i look for/not look for when searching for my 60?
1972 Bronco, 3.5"sl, 2"bl, 5.0efi, 4r70w, D20, Hydroboost, db, 4x4x2
1979 Toyota Hilux limited edition
03/28/10, 04:34 PM
#3
What size lift are you running?
03/28/10, 06:15 PM
#4
Member of WOHVA
Neenah WI
I am running a 5 1/2 lift . As for the many say the 78-79 D 60's are the best but what I found from the center of the pinion to outside of the steering knuckle is 1/2 inch less than a stock Bronco 44 so no need to cut the drivers side . on 78 to 84 the pinion is move to the center of the housing , 85 to 89 are the same as my 86 . This is a big plus when you run a C6 with a 205 or my case a Stak mini monster T case . Ford D 60's are high pinion too , = better driveshaft angle and more ground clearance. This is a true 4 link , no track bar so the axle stay's in the middle of the truck , not moving from side to side like a stock Bronco does .
The goal was to make the D 60 look stock at first glance . It's more street legal If you have to drive on the street to get to the trail head the cop's will ticket a buggy long before a stock width truck
Jay
03/28/10, 06:42 PM
#5
Member of WOHVA
Neenah WI
03/28/10, 07:20 PM
#6
Bonney lake WA
does anybody know why the 80 to 85 dana 60 is undisierable, just wondering cause one is close to me, for sale. Rhino buggie looks good
03/28/10, 08:17 PM
#7
Member of WOHVA
Neenah WI
I know the steering knuckle is heavier on 78-79 . But looking at a 44 next to the 86 D60 I have , the 60 is huge , and guy's run 44's with the stock Bronco D44 and it live's . A fully built Bronco weights about 2k to 3k less than a stock F350 .
Jay
03/28/10, 08:23 PM
#8
Semper Fi , Devildog!
N.W. Indiana
Pumpkin is in the center of the axle , maybe ..... also
when did they switch from king pins to ball joints , 80 ? I think , which is why the 78 & 79 are most desired.
Originally Posted by mudmagnet63
It must suck not to own a Bronco.
Not enough time, lift ,tires or money.
69 street rig - Exploder EFI - NV3550 coming soon ( Thanks Dr.B !)
68 trail beater - 351w - NP435 - D20 - Dana 60's f&r42's - locker(f) and spooled (r) - much bondo
03/28/10, 09:01 PM
#9
Whittier, CA
that tech article does have a lot of good info, thanks.
03/28/10, 10:55 PM
#10
Bonney lake WA
I know they switch to balljoints in 91 and a half, so it must be the pumpkin.
03/29/10, 08:27 AM
#11
1 Ton 74'
Twin Cities
They are not "undesirable" - I've got a 90' under mine, no difference from my father's 86' either. D60's are just huge, when you see one in person next to a D44 there is no going back. All this 78-79 bullsh!t that flies around making the installs easier is just that -
You CAN fit c wedges on a 80'+ axle, but most people who swap to a D60 will not be using the factory arm setup unless you have exsisting Cage arms, but that is easily fixed by purchasing the weld on brackets that bolt to the arms.
As for balljoints - these axles were designed to survive under a diesel truck, people don't complain about having balljoints in a D44, so what is the big deal about 1 ton balljoints? The only real disadvantage is the lack of easy high-steer. I've got a newer D60 with balljoints and unit bearing's I'm building - changing an axle shaft will be a piece of cake with only 4 nuts and 2 bolts to get the shaft out after the wheel is off... As for the bolt spacing - easily fixed by popping out the studs, drilling your own pattern and popping them back in - there is a lot of room on the flange to either leave the old holes or weld them up, machine flat and put your new pattern of choice back on.
74' Bronco -Fi-Tech Injected 357W - Twisted Demon C4- AtlasII 3.8 - D60/D70 - PSC Full Hydro - 5.5" lift - Cage Arms, Coils and Shocks - F-O-A 2.5" Air Bumps - 43" TSL SX on H1 Double Beadlocks
74' Bronco Ranger - Street Build in Progress (351W/ZF5/NP205)
03/29/10, 02:35 PM
#12
Member of WOHVA
Neenah WI
If you want to run C wedges the leaf spring mount on the driverside would have to be ground off or the C wedge would have to cut to fit . I think the center housing is like 3 inches more to the center of the axle on a 78-79 . I went 4 link so no problems there. This axle has king pins yet , I think 90 was the change to ball joint's
Jay
03/29/10, 03:40 PM
#13
Jackson, NJ
Ford did not put a D60 front from 80-85 in f350'S, they used the TTB D50.
70 Sport 302/T-18/D20-T, BB 31 spl LS 9" w/ yukons, MK VII rear disks, disk D44 w/ lockrite, 3.5" CAGE/Deaver lift, full length headers/duals, 78 col/steer box, stang HB
79 400/C6/205, Mog 404's, 43 SX stickies...
03/29/10, 05:14 PM
#14
Member of WOHVA
Neenah WI
Originally Posted by OX1
Ford did not a D60 front from 80-85 in f350'S, they used the TTB D50.
F250 had TTB F350's have alway had Straight axle's
This link should help http://www.4wdandsportutility.com/te..._60/index.html
Jay
03/29/10, 07:00 PM
#15
Jackson, NJ
Originally Posted by rhinobuggie
From that link...........
"The Dana 50 monobeam front axle went under most Ford 1/2-ton pickups from the early-'80s to present."
Thats funny.......Most FSBers from 80 on up WISH they had solid front D50 instead of the TTB D44.
Anyway, there was NO D60 front from 80-85 in F350's.
http://blueovaltrucks.com/tech/SAS_F-250_F-350.htm
"TK4551 1983-1998 F250 and 1980-1985 F350 with Model 50 Twin Traction Beam IFS Front Axle. "
http://quad4x4.com/Ford%20Front%20Ax...teering%20.htm
http://www.dieselbombers.com/ford-tr...ont-axles.html
http://store.topguncustomz.com/store...03&i=244793832
http://www.offroadunlimited.com/orus...dproduct=11729
"This axle stayed the same until it was replaced by the Dana 50 IFS in 1980. The Dana 60 reappeared in the front during 1985 under the F250 / F350. "
http://77cj.littlekeylime.com/Dana44_2.htm
Page generated in 0.33087 seconds with 56 queries
