Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 04/10/10, 01:23 PM   #1
Evian
Evian's Avatar
Nothing beats having the wind in your hair and that feeling of being free
Algonquin/IL
Can I interchange the fuel filler neck from a 76 to a 77 Bronco?
I am installing quarter panel armor plating on the driver's side. It will cover up my fuel door. I was thinking of installing a flip up gas cap but I need to change the fuel filler neck. I was wondering if a 1966-1976 fuel filler neck would work on my 1977 Bronco's gas tank? Are they the same length? I have a 23 gallon standard rear main fuel tank.
Evian is offline
Old 04/10/10, 02:06 PM   #2
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
They are different the 77 neck is shorter because its receesed into the body hence the filler door. While the early filler necks are longer and may work as you would move its mounting piont to the new panel and with only maybe 1/4" differance the hose should still hook up although you may need a new hose as I think the 77 filler tube is smaller diameter. I think I would just build a door for the panel as well and retain the 77 recessed filler.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 04/10/10, 02:25 PM   #3
Evian
Evian's Avatar
Algonquin/IL
I want the fuel filler neck to bolt to the body just like the 66-76 models. I will be relocating the filler neck to a different spot this summer. Currently I will it have it visible from the wheel well so I can fill the Bronco up. Reason why, I still have to install my Gorilla Wheel Flares. I need to cut my quarters and recut my armor plate. Then I will relocate the gas filler neck. Work..work ....work........If the filler tube is smaller I will use a coupler and a couple of clamps to tie it together. Hopefully it will work.
Evian is offline
Thread Tools
Page generated in 0.26648 seconds with 54 queries
