Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 06/13/10, 06:25 PM   #1
DonaldDouchebag
DonaldDouchebag's Avatar
Nordeast Minneapolis
Saginaw PS pump pressure fitting leaks
I bought this adapter from Wild Horses to attach my stock power steering pressure hose to the back of my Saginaw pump. Now it's leaking. I'm fairly certain the leak is at this adapter. Should there be an o-ring in there someplace? Help!
http://www.wildhorses4x4.com/images/large/2463.jpg
'64 Sears Allstate Scooter
125cc, 4spd, 6 Horsepower
DonaldDouchebag is offline
Old 06/13/10, 07:14 PM   #2
johnsonx
Newbie
Lompoc
On the flare end you shouldn't put anything on the threads. The flare end is just Male to female flare with no thread sealant needed. I can't tell what the other side looks like from your pic.
johnsonx is offline
Old 06/13/10, 08:16 PM   #3
chuck
chuck's Avatar
Ingram, Texas
eBay: bcbroncos
The end of the adapter that we can not see in the picture should have 45* chamfer to match the cone inside the pump. No O-rings or sealent needed. Look closely at the cone inside the pump. It may be damaged.
BC Broncos, making Innovative ideas reality.
chuck is offline
Old 06/13/10, 11:05 PM   #4
JMP
JMP's Avatar
Kirkland, WA
I went through the same issue last month...after replacing it twice, I put some Napa hydrolic Hi Temp sealer on the threads, it stopped the leaking.
Josh
77 - 302, C4.
JMP is offline
Old 06/15/10, 10:15 AM   #5
DonaldDouchebag
Thanks fellas! I'll dive into it a bit deeper tonight.
Old 06/15/10, 11:05 AM   #6
gddyap
gddyap's Avatar
Mtn View, CA
There is a stock application hose that has the correct fittings for a standard thread Saginaw pump and stock Bronco PS box.
Omega power steering p/n 535
Duralast/Edelman/Powercraft 71308
Ford applications:
1965 - 1966 Country Sedan
1965 - 1966 Galaxie
1965 - 1966 Country Squire
1965 - 1966 Galaxie 500
1965 - 1966 Custom
1965 - 1966 LTD
1965 - 1966 Custom 500
1965 - 1966 Ranch Wagon
You can even get it amazon
http://www.amazon.com/Edelmann-71308...6621361&sr=1-4
Should be less than $20 at the local parts store. It's 3/8 male inverted flare by 7/16 male inverted flare. There's a 90* bend on the pump end and a slight bend at the box end. Depending on how close the pump bracket is to the box, you may need to do some trimming. I'll try to remember to take a picture tonight.
gddyap is offline
Old 06/15/10, 09:29 PM   #7
DonaldDouchebag
Ford applications:
1965 - 1966 Galaxie
1965 - 1966 Custom
1965 - 1966 LTD
Awesome information. I'm going to see if I can get one.
Old 06/16/10, 07:33 PM   #8
gddyap
gddyap's Avatar
Mtn View, CA
Here's the hose in my Bronco. 5.0 Econoline serpentine brackets on a 5.8. You can see how close it is to the PS pump bracket but I think just about any hose would be close to that bracket.
http://img202.imageshack.us/img202/2148/img1744s.jpg
http://img46.imageshack.us/img46/7271/img1745u.jpg
http://img517.imageshack.us/img517/6586/img1746xu.jpg
gddyap is offline
Old 06/17/10, 03:55 PM   #9
DonaldDouchebag
Just in case anyone stumbles across this in the future, the Napa part number for the correct hose gddyap was so kind to direct me towards is NPS71145. It runs $22.49.
Autozone has it as part#71308. Their price is $17.99.
Old 06/17/10, 06:01 PM   #10
gddyap
gddyap's Avatar
Mtn View, CA
How did it work out for you?
gddyap is offline
Old 06/19/10, 07:25 PM   #11
DonaldDouchebag
They had to order the part. I should be able to get this thing moving Monday, I hope.
Thread Tools
Page generated in 0.27341 seconds with 54 queries
