Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 07/05/10, 09:40 PM   #1
behemoth
behemoth's Avatar
San Diego
stock oil pressure sender.
All,
What is the resistance range of the stock oil pressure sending unit on the bronco? Also is there a smaller unit with the magic range that can be used instead of the stock unit?
I have a 96 explorer engine with a custom oil filter relocator and I am unable to use the stock one or the mustang extension/angle thing.
I forgot the stock explorer one on the engine and built around it, a yeah stupid but its done.
I also wish to use the stock gauge at this time as well.
Bill
1972 Bright Lime Sport. 93 5.0 EFI, 89 AOD, 4:56 gears, ARB front, Detroit Rear. BC Broncos 5.5 lift, 1" body lift, WCB extended arms. Lots of stuff and no where near done.
behemoth is offline
Old 07/05/10, 10:03 PM   #2
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
I was just thinking of asking nearly the same question but for a completely different use.
My question would have expanded a little to ask if anyone has a good reference sounce for pressure sending units (pressure vs. resistance). I was thinking of reworking the stock oil pressure gauge into an on board air pressure gauge but I want to expand the scale (make new markings).
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
“How hard can it be?”-Clarksonius 4th century BC.
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is offline
Old 07/05/10, 11:21 PM   #3
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
Oil pressure senders should read 24-36 ohms of resistance at 8 psi or less and 8.0 to 17.5 ohms at 90 psi (gauged maxed out).
I've never seen a smaller sending unit that would work although I really havent looked. You may endup having to connect a sending unit to a hose.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 07/06/10, 12:11 AM   #4
Viperwolf1
electron whisperer
Viperwolf1's Avatar
It's not dented, it's just been environmentally streamlined!
homelessly wandering
The oil pressure sender has the same resistance range as the fuel sender and temp sender, 10 ohms at full scale and about 75 ohms at low scale. Mid scale is 23 ohms. The gauge itself has 10-14 ohms of resistance.
I was looking for a different value temp sender recently as I was thinking about making a master warning light circuit. One bright LED bulb that would light up if temp got too high or oil or fuel got too low. I didn't find anything that really fit what I needed.
'74 beater, 5.0 mustang EFI, C4, PS, front discs, twin sticks, 3.5" susp/1" body, 33's, 4.11's, ARBs, Hickey Sidewinder, cobra hydroboost
'70 cruiser, 5.8 explorer EFI, 4R70W, PS, front discs + hydro, twin sticks, 3.5" susp/1" body, 34's, 4.88's, ARB & tru-track
Viperwolf1 is offline
Old 07/06/10, 12:20 AM   #5
oleguy74
calif city ca
behemoth!!! I sent you info on socal eairler.you might get an E-mail too.did not know you were on here too.
oleguy74 is offline
Old 07/06/10, 07:44 AM   #6
Steve83
Steve83's Avatar
Fullsize Bronco Guru
Memphis, TN, USA
eBay: untod
Originally Posted by Viperwolf1 View Post
...I was thinking about making a master warning light circuit.
Ford already built it.
http://www.supermotors.net/getfile/6...l/13module.jpg
But it's designed for the later EFI fuel level input. So you could use it as a temperature & oil pressure warning without much effort, but not low fuel.
Steve83 is offline
Old 07/06/10, 11:47 AM   #7
behemoth
behemoth's Avatar
San Diego
in looking around for some other options there is one by picture that summit sells that looks smaller and should fit fine. Will see tomorrow if it is correct or not. I figure I will run a soft line to the sender and it should be out of the way if the summit one is not smaller.
behemoth is offline
Old 07/06/10, 11:55 AM   #8
DirtDonk's Avatar
San Jose, CA
Post up some pictures when you get it behemoth. Be curious to see not only the new unit, but also your setup and what you've got in the way.
We just did it with an explorer serp setup, but had no issue with the stock tube turned to angle slightly more forward to clear the bracket.
Just using a stock oil filter in this case however, so that wasn't an issue.
Good luck. If all else fails, the tube method might be a good option. I've done it on other engines in the past when a smaller (light type) sender was replaced with a larger (gauge type) sender.
DirtDonk is offline
Old 07/06/10, 08:54 PM   #9
behemoth
behemoth's Avatar
San Diego
The engine is in my other bronco that has an addtional crossmember and rack and pinion steering. The engine came used with a po built oil filter relocator. I just chose to use it as the steeringlines and other stuff was in the way.
The issue is with lines off of the block, I will look at turning it more and moving the lines out of the way.
The smaller oil pressure sender if it is actually what the picture was should work fine.
behemoth is offline
Old 07/07/10, 12:53 PM   #10
Adapt and overcome
Maricopa, AZ
From the looks of it you might be able to get away with a 45° street elbow screwed into the block to reangle the sending unit. Ace hardware generally will carry them when the big boy home centers don't. Think of it as a stubby version of the long stock unit. probably will have to clock it a little to get the sending unit to fill in the spot.
Old 07/07/10, 01:03 PM   #11
70_Steve
Old Guy
70_Steve's Avatar
If You're Going to Do It, Over-do It
Phoenix, AZ
The hole in the block and the stock sending unit are both 1/4"NPT. I had the stock sending unit and an oil pressure safety switch mounted in that location. Use a 2" nipple to a tee, with the sending unit off the side of the tee, and a street elbow out of the end of the tee to mount the switch.
Just determine where the sending unit will fit, then what fittings you need to get it there! I'm getting ready to remount my sending unit, and instead of using the stock extension, I'm probalby going to use that same 2" nipple and a 45°!
'70 Sport, 351W EFI, NV4500, D20 w/Teralows, 4.56s Dana 44 w/Ox and 9" 31 spline Detroit, 35" KM2's, 3 1/2" lift, 2" body lift, 4x4x2 PS, some other stuff I forgot about...
"If it's got tits or tires it's gonna be a problem"
70_Steve is offline
Old 07/07/10, 04:22 PM   #12
behemoth
behemoth's Avatar
San Diego
According to the summit racing page the oil pressure sender smp-sp149 is for a ford bronco with a 289 and the 302, as well as some other newer cars. It is also much smaller than the stock one that I had on the engine originally. Its size is closer to the explorer one and this should work perfectly with no mods or addapters.
behemoth is offline
Old 07/07/10, 11:12 PM   #13
oleguy74
calif city ca
thats what i have.might have a 3"nipple though.put in there in 79 when i broke the stock one putting 351 in.
oleguy74 is offline
Old 07/10/10, 08:36 AM   #14
behemoth
behemoth's Avatar
San Diego
Well the ps149 smaller sender from summit which in their application section says it is for the early bronco with a 289 and 302 appears to be a light sender. The gauge pegs as soon as the key is turned. So back to the smaller adapter fittings I guess.
behemoth is offline
Old 07/10/10, 09:03 AM   #15
Adapt and overcome
Maricopa, AZ
Must be using the same interchange books the parts stores use but forget to ask if it is a gauge or a light.
Thread Tools
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.43397 seconds with 55 queries
