Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 07/11/10, 06:53 PM   #1
SWFLABRONCO
SWFLABRONCO's Avatar
Cape Coral, Fl
C4 and Dana 20 leaks
Finally got the Bronco mechanically sound enough to put it through it's paces before getting it on the road full time. Problem is, when i bring it back in the garage from the ol neighborhood street trials, it'll leave pretty good puddles of gear oil and transmission fluid on the garage floor. I've cleaned the fluids from underneath it after i park it and let it sit 5-10 minutes and it absolutely doesn't leak when it's parked, only immediately after a run. Could the fluid levels be to high and it's expelling the extra? I'm running a Lokar fill tube for the C4 so I don't know if it's the most accurate. Just wondering if this is normal and whether or not I need to drain some fluids or let it happen naturally.There is no real vissble point of where the leaks start except for it coming from the "top" somewhere. Sorry this is long winded.
SWFLABRONCO is offline
Old 07/11/10, 10:56 PM   #2
blubuckaroo
Grease Monkey
blubuckaroo's Avatar
Original Owner
Ridgefield WA
Check the fluid level in the transfer case. If a whole lot of oil comes just a gushing out of the transfer case fill hole, chances are you need to replace the double lipped seal in the transfer case adapter. What happens is the leaky seal lets the transmission leak into the transfer case. The transfer case gets so full , it overflows onto the floor.
'77 Ranger/cut F&R/PS/PB/Vintage Air/2" suspension lift/1" body lift/T tie rod conversion/33-1050-15 BFG K02 tires/ 302/ Edelbrock 500 CFM 4 bbl/Aero Tanks/ Hooker Headers/ dual ex/ NV3550/ B&M shifter/ JB FabTwin Sticks/ 4.11s/rear posi.
blubuckaroo is offline
Old 07/12/10, 06:42 AM   #3
SWFLABRONCO
Cape Coral, Fl
I thought about that and that seal was replaced during the rebuild. The puddles are also seperate gear oil and tranny fluid leaks. The two aren't mixed together like they would be if the tranny was leaking back into the tc. I'll check the fluid level on the tc to be on the safe side though.
Old 07/12/10, 07:42 AM   #4
Justafordguy
Justafordguy's Avatar
Tallahassee, Fl
A C4 will leak out of the top if it is over filled. I'm not sure how you would over fill a D20 unless you added an elbow to the filler hole. I have seen people do this but I'm not sure why.
77 Bronco, 302, 4bbl, Hei, C4, PS, PB, BCB-A/C, 33" KM2s, D44/Lock-Right Chromo axles, 9"/Grizzly locker Yukon axles, Tom Woods driveshafts, 2.5" sl, 1" bl, Bilstein shocks, 1 ton steering, JB-fab twin stick, D20,
2017 F350 CC LB KR FX4
2005 F250 CC FX4
2016 Edge Sport V6 EcoBoost AWD
Justafordguy is offline
Old 07/12/10, 08:18 AM   #5
ep67bro
Bronco Junky
ep67bro's Avatar
I used to have time!
EasternShore, MD
Good luck getting the C4 to stop leaking!!! I had my wifes rebuilt and it still leaks, I have had three differant C4s and all of them have leaked!!!!! Check around the shift linkage a few of mine have leaked from there. And as said sounds like they may be a little over full!
67, 289, NP-435, 3.5 lift,1"BL, 35s,custom bumpers, work always in progress. 75 uncut 302 C4 lubr, 70 sport 302 3spd no lift NO RUST!
ep67bro is offline
Old 07/12/10, 08:26 AM   #6
SWFLABRONCO
Cape Coral, Fl
No elbow on the 20. I'm hoping they are overfull. Both units were completely gone through and rebuilt prior to installing them. I'll drive it for a while and continue to watch what I lose compared to the remaining fluid levels. My hope is that with use, the leaks lessen. I can live with a few drips here or there but the puddles seem a little excessive at the moment.
Old 07/12/10, 01:44 PM   #7
ddm156
ddm156's Avatar
York PA
I am having the same issue right now - my dilemma is I don't know whether to put my money into trying to fix the leaks on the trans or buy a radio and some speakers. I took mine to an ammco in town and they recommend a complete reseal for my transmission, which will come in around $1000. I definitely do have a leak from my shift linkage, which I've tried fixing several times with different size o-rings with no success. I feel your pain. Its pretty embarrassing to have your truck burp oil all over somebodys driveway, especially after we sink all of this time and money into them. I think I might just keep researching and consider resealing myself over the winter.
ddm156 is offline
Old 07/12/10, 01:49 PM   #8
SWFLABRONCO
Cape Coral, Fl
ddm156,
does yours leak continuously or just immediately after running it?
Old 07/12/10, 02:17 PM   #9
Viperwolf1
electron whisperer
Viperwolf1's Avatar
It's not dented, it's just been environmentally streamlined!
homelessly wandering
http://classicbroncos.com/forums/sho...d.php?t=164443
'74 beater, 5.0 mustang EFI, C4, PS, front discs, twin sticks, 3.5" susp/1" body, 33's, 4.11's, ARBs, Hickey Sidewinder, cobra hydroboost
'70 cruiser, 5.8 explorer EFI, 4R70W, PS, front discs + hydro, twin sticks, 3.5" susp/1" body, 34's, 4.88's, ARB & tru-track
Viperwolf1 is offline
Old 07/12/10, 02:57 PM   #10
SWFLABRONCO
Cape Coral, Fl
Thanks Viperwolf,
I thought of this thread and actually looked to see if that was where it was coming from. It didn't appear that it was, but I'll take a better look at it tonight.
Old 07/12/10, 06:21 PM   #11
ddm156
ddm156's Avatar
York PA
I just drip a little after running (from more than one spot) once it cools down it holds the fluid. Did you install all of your seals and let the truck sit a while? I've heard that sometimes that is a bad thing, the seals sit dry too long and crack.
thanks x2 viperwolf, that will come in handy. I have my kickdown removed, so maybe thats part of my problem at the nss.
ddm156 is offline
Thread Tools
Page generated in 0.29666 seconds with 56 queries
