Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 09/30/10, 01:54 AM   #1
krisbassett
krisbassett's Avatar
Working on my dream Bronco as we speak
Soda Springs
Putting a full width axle under an early Bronco?
What all do I need to install a set of full width axles under my Bronco? I assume the rear is pretty straight forward but I'm wondering about getting new wedges for the front and getting them installed properly? Where can I get new wedges and what is the easiest way to find the proper location for them? Also what needs to be done with the track bar mount?
Thanks in advance
Kris
Oh and I'm going to be using the axles out of a 79 Bronco.
krisbassett is offline
Old 09/30/10, 05:05 AM   #2
blazinchuck
blazinchuck's Avatar
"American by birth, Southern by the grace of God"
Johns Is,SC
eBay: chas5937
if you can find a 77 front axle...just cut the wedges off and slid them in. the radius arms i used had the caster built in for a 3.5" lift...so just moved the mounts in board(dont remember how much, its in my build thread) as for the trac bar...i got WH trac bar riser and adjustable trac bar(i did have to shorten my trac bar tho). that all lined up perfect when i installed a TRO chevy1ton. for the rear, I bought the heavy duty spring perches that are longer(to help with axle wrap). good luck...full width rocks!
77 built 306,Trickflow Cam/Alum Heads/dome pistons/10:1comp,nv3550,front4.56/Electrac,rear4.56Posi,duff long arms,3.5" lift,family cage,protofab rear bumper,twin sticked,chromos and 33"MT's"Fat Bottom Girl"
CarolinaBroncosMember/G.D.I.
blazinchuck is offline
Old 09/30/10, 06:02 AM   #3
broncopete78
broncopete78's Avatar
ID
You can't move the wedges on a 79'. The best thing to do if you want to use these axles is to move your spring towers outward. This is easy for some one with some decent fab skills. There are some pictures online that would help. I have all the parts now out of a 78' and will be doing this winter.
broncopete78 is offline
Old 09/30/10, 08:32 AM   #4
Apogee
Apogee's Avatar
Cuz that's how I roll.
Tangent, OR
You can shorten the 78-79 D44 high-pinion Ford axles, the method is just a bit different due to the cast-in c-wedges. Just like installing BCB's wristed axle housing, cut the axle at the seam between the cast c-wedge portion on the long side, shorten the tube, reinstall the cast portion and weld. That's the general idea anyway.
Did you know that 95% of all statistics are made up on the spot?
Apogee is offline
Old 09/30/10, 11:10 AM   #5
krisbassett
Soda Springs
I'm really looking forward to getting wider axles under her!
Old 09/30/10, 11:27 AM   #6
jpalmer
jpalmer's Avatar
MUD IS MY LOCTITE
Boise, ID
I am running '78s with the cast wedges. I just left the wedges where they were & moved the springs outwards by redrilling the spring cup as mentioned above. It's really simple with basic fab skills.
'67 - LSx/NV4500/NP241, full widths, 4.10s & ARBs, 37" M-16s on 17x9s, M8000, 3.5" sl, 2" bl, ext. arms, 1 ton steering w/ TRO, fully Rhino-lined, hboost, DP dash w/ Autometers, custom bumpers, family cage, WCBRC PS, projectors, LED tails, more.
jpalmer is offline
Old 09/30/10, 11:53 AM   #7
thesnake
thesnake's Avatar
Nebraska
I'm doing this (somewhat slowly) with a 77 with the weld on wedges. From what I have seen and understand, WBC4X4 welds a 2" plate on the frame between the coil towers and the frame which moves the coil's out the 2" to take care of the bow, when they do 78/79 HP44's. At least, this is my understanding. I would recommend checking out their site, they do have some pics and I'm sure if you had further questions, they would be willing to help you.
thesnake is offline
Old 09/30/10, 08:50 PM   #8
dnewman9
So many Broncos so little time!
Lone Tree, CO.
I left everything stock. The coils slant outward some but it has been fine so far?
I am going to swap my brand new 4.11s for a 4.56 or 4.88 axle at some point and when I do that I will look for an early housing and move the wedges in as explained above.
Dennis
1969 Sport WCB Fenders, Buckaroo hood, FW 9/44 Aussie Locked 3.5 lift 32v 4.6 4R70W BUILD THREAD
WANTED: My old U15GLR90650 1973 Blue Half Cab Colorado truck sold in SE Wisconsin (Kenosha?) My first car, reward for info!
dnewman9 is offline
Old 10/01/10, 08:21 AM   #9
broncomitch
broncomitch's Avatar
dont be a sheep in a jeep!
west jordan, utah
you will love them!
1971 bronco sport,mild built 351w,c6,strong box,np205,HP Dana60,srw 14bolt,disc's front and rear,16"rock coil overs,H1's & 44" tires,4.10's,3link front,56" springs,ez wiring,TBI injection,
Build thread
http://classicbroncos.com/forums/sho...d.php?t=196087
broncomitch is offline
Thread Tools
Page generated in 0.27958 seconds with 56 queries
