Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 11/16/10, 04:04 PM   #1
br0nc0xrapt0r
Loves pickles
br0nc0xrapt0r's Avatar
Fueled by Hate, caffeine, and sometimes whiskey.
Kent City MI
Engine losing power cutting out **fixed**
Yesterday it was fine today it starts and idle's/revs fine. but as soon as you put it in gear and take off it cuts out and then surges forward like it's catching up. Its a 351M C6 in a 78 bronco, I changed the fuel filter and tried running it with no air cleaner and no change at all. I want to check the hei dizzy but don't have enough time I gotta go back to work.
any ideas?
SEMPER FIDELIS
69 Exxon Valdez, 37" locked front and rear, Daily driver.
http://classicbroncos.com/forums/sho...d.php?t=163762
WTB pulley cover for 1959 Homelite 9-23
br0nc0xrapt0r is offline
Old 11/16/10, 06:11 PM   #2
cwcorbin
Check for a loose coil wire... Had one of the factory friction connectors get loose on me, and just the wire moving under accel/decel would cause it to stall/start. Felt like the float levels were low, and it was sloshing /starving. Good luck
cwcorbin is offline
Old 11/16/10, 11:19 PM   #3
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
Check to see if the accelerator pump is working. Also check the vacuum line to the modulator and the tranny.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 11/17/10, 10:46 PM   #4
br0nc0xrapt0r
Loves pickles
Kent City MI
Working in the dark still. I may have found about 40 vacuum leaks but no massive improvement, hopefully I'll get the weekend off and I can fix it.
SEMPER FIDELIS
Old 11/18/10, 06:56 AM   #5
markperry
markperry's Avatar
Rock Chalk
Platte City
HEI has no coil Well not the kind I think your talking about?
1976 ,351, 33's, c4, 411 gears, Hydroboost, Twin Sticks. Detroit locker, LS D44, 2.5 SL,Champion radiator. Rampage soft top, Tom's Bronco bucket seats.
3g alternator. FITECH, Family cage.
VOTE FOR CLASSIC BRONCOS:
http://top4x4sites.com/cgi-bin/arp/r...cgi?id=oldford
markperry is offline
Old 11/19/10, 11:10 AM   #6
br0nc0xrapt0r
Loves pickles
Kent City MI
Is it possible that the mech fuel pump is dying? it now doesnt even want to rev but still idles fine.
SEMPER FIDELIS
Old 11/19/10, 11:34 AM   #7
Explorer
Explorer's Avatar
Raphine, Virginia
eBay: gfw1985
Entirely possible. Most compression testers will read fuel pressure too.
66 half cab 203ci I6, Classic Inlines aluminum head and intake, DSII, Holley 390 cfm 4V, Isky cam, Keith Black flat top pistons, ARP studs, balanced, 9.7:1 compression
55 F100 build in progress
Explorer is offline
Old 11/21/10, 07:18 AM   #8
airbur
airbur's Avatar
Castle Pines, CO
I just had a similar issue...I went through and replaced all the plugs and wires and it's disappeared for now. Sounds like you've already covered that though.
1970 w/427W Injected Stroker
airbur is offline
Old 11/21/10, 12:49 PM   #9
garberz
garberz's Avatar
Clear me a path...
Conejo Valley, Ca.
I've seen symptoms where it idles but won't rev, turned out to be a bad coil. The coil had enough strength to idle but couldn't handle the demand of current for increasing RPM's. Coils are cheap, good to carry a spare also.
Mark
EFI, OBDII, 5.0, C4, AtlasII 3.8. 4.56's, Detroit's, 35's, Duff Long Arms, 5.5" coils w/adjustable mounts. 3" suspension lift.
garberz is offline
Old 11/21/10, 04:10 PM   #10
br0nc0xrapt0r
Loves pickles
Kent City MI
Mark
I'm really scared of that since it's an HEI unit. I replaced the fuel pump with little to no improvement and also checked cap and rotor things seem to be in order.
SEMPER FIDELIS
Old 11/21/10, 05:13 PM   #11
br0nc0xrapt0r
Loves pickles
Kent City MI
is there a way to have the coil tested?
SEMPER FIDELIS
Old 11/21/10, 08:35 PM   #12
garberz
garberz's Avatar
Clear me a path...
Conejo Valley, Ca.
At this point, I would just buy another one and see if it solves your problem. If it doesn't, at least now you have a spare.
garberz is offline
Old 11/21/10, 09:02 PM   #13
br0nc0xrapt0r
Loves pickles
Kent City MI
Touche but I am trying to sell said bronco, it eats up too much funding for the 69. I don't really want to but another dizzy and find out thats not the problem. what else could it be?
SEMPER FIDELIS
Old 11/21/10, 09:16 PM   #14
DirtDonk's Avatar
San Jose, CA
Should be a spec for testing the coil with an ohm meter. Maybe someone here knows what the GM spec is?
Is it a standard coil as far as you know, or is it an updated aftermarket one? What brand is the distributor?
DirtDonk is online now
Old 11/21/10, 09:36 PM   #15
br0nc0xrapt0r
Loves pickles
Kent City MI
No clear markings on it, this is what it looks like. Perhaps it's an ebay special.
SEMPER FIDELIS
Thread Tools
Page generated in 0.32336 seconds with 57 queries
