Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 11/21/10, 03:49 PM   #1
Blue71
Blue71's Avatar
Broncos Rule!
Johnson City, TN
Backfiring trough the carb?
'70 Bronco with an aftermarket carburated 1987 302 motor. Someone has put an Edelbrock intake and an Edelbrock 4bbl on it. It ran and idled good a few days ago after purchasing it, but now it will barely idle. Id did set for a while bu it has new ethanol free gas in the tank and a new fuel filter. When you try and rev it up...it backfires through the the carb and runs rough then dies. Sometimes shoots a small flame or two out of the carb too. Wahoo!
Guide me.
Thanks,
Blue71
'69 Half Cab
'70 Wagon
'71 Stroppe Baja
'73 Sport
'74 Sport
'75 Wagon
'76 Explorer w/ Four Wheel Pop-up Camper
'77 Wagon
'77 Original Ranger, 76,000 mi
"Yes I Know, But When Do I Get To Drive That Thang"
Blue71 is offline
Old 11/21/10, 03:54 PM   #2
Explorer
Explorer's Avatar
Raphine, Virginia
eBay: gfw1985
Backfire thru carb usually indicates timing. May need to adjust to the new gas mix.
66 half cab 203ci I6, Classic Inlines aluminum head and intake, DSII, Holley 390 cfm 4V, Isky cam, Keith Black flat top pistons, ARP studs, balanced, 9.7:1 compression
55 F100 build in progress
Explorer is offline
Old 11/21/10, 04:52 PM   #3
SDlivin
SDlivin's Avatar
San Diego
X2 on timing.
when I changed my cam / intake, it took me quite a bit to get the correct timing down. when it was incorrect, I would get the backfire through the carb etc....
Not sure on the gas though...
Check timing and Vacuum.
Should have around 8-12 BTDC for timing at idle, and 15-20 vacuum pressure @ idle.
Results, may vary accordingly....
-Robert
Mostly '70 bronco. 351w, gt40 heads, msd 6al, expl serp, chevy disc front, manual 3 spd, d20, 3.5" SL, 2" BL, 35" mt, l/s rear and front, d44, .......
SDlivin is offline
Old 11/21/10, 06:43 PM   #4
77bronco_ed
77bronco_ed's Avatar
Michigan
If after checking and setting timing if this happens again it could be timing belt?
77 Bronco-All glass
77 Bronco streetrod project begins...
77bronco_ed is offline
Old 11/21/10, 09:38 PM   #5
oldiron
oldiron's Avatar
Gaze upon the light and see that it is blue.
Chattanooga
No timing belts on 302's.
Other options for backfiring through carb:
Waaayy to lean, check for fuel enrichment (power valve on a holley)
Vacuum leak (could also explain the rough idle)
Burnt valve (could also explain the rough idle) easy to check with a vacuum guage.
Clogged fuel filter (again, causing poor idle quality and overly lean condition)
Need more info to be more accurate, such as how long did it set, driven much. etc,etc.
Greg
'72 Wagon 302/3spd Seapine Green Poly
oldiron is offline
Old 11/21/10, 09:55 PM   #6
El Kabong
El Kabong's Avatar
Driving stuff Henry built
Pasadena, CA
Also double check the firing order & condition of the wires. Reversed wires or crossfiring can cause backfiring by lighting the mixture while the intake valve is open.
-Rough 73, cut, 400, np435, d20, 35s. Workin' on it.
-90 xlt, 351w, e4od, bw1356, 35s.
El Kabong is a cartoon horse from when I was a kid in the the 60s. No bong was used in the selection of this user name.
El Kabong is offline
Old 11/21/10, 09:58 PM   #7
DirtDonk's Avatar
San Jose, CA
And speaking of ignition, are you sure you're getting enough current to the ignition? I ask because you're running into all those other wiring issues right now.
DirtDonk is offline
Old 11/21/10, 10:19 PM   #8
Blue71
Blue71's Avatar
Broncos Rule!
Johnson City, TN
Hey Paul..Me? Wiring problems? .I should be fine on the current. This is on another Bronco that I picked up a few days ago. Its a '70. That '75 is the booger with the starting issue we talked about before. Will double check though.
Thanks,
Andy
'69 Half Cab
'70 Wagon
'71 Stroppe Baja
'73 Sport
'74 Sport
'75 Wagon
'77 Wagon
Blue71 is offline
Old 11/21/10, 10:25 PM   #9
bax
Giant Member
bax's Avatar
smokin 37's
Melbourne.
Do I need to come pick it up from you?
1971 U15 Ol'blue 5.0/4r70w/205/ 4,11. 1968 U15 - EFI 408C/C6/205/4.88/37's/hi9/ARB's/hydro-boost/full cage/4wdisk/PS/powerasswipe/bla-bla-bla!
bax is offline
Old 11/21/10, 10:25 PM   #10
Blue71
Blue71's Avatar
Broncos Rule!
Johnson City, TN
This Bronco sat for a few months. But ran fine for the past several days. Really strong 302 and idled well. Just the last day or so its giving these problems.
El Kabong- Firing order should be fine since it ran great a few days ago and nothing has been changed. Will check condition of wares again, but looked in good shape, even on the ends.
Oldiron- Might possibly be a valve. It did set a few months so will go back and double check fuel filter. If I can get her to idle..will check vacuum too.
Would there be any reason that the timing would be off since the other day? Haven't messed with it since it ran good. Might have jumped time possibly??? Really seems more like a carb issue. It is like it almost loads up or something.
'69 Half Cab
'70 Wagon
'71 Stroppe Baja
'73 Sport
'74 Sport
'75 Wagon
'77 Wagon
Blue71 is offline
Old 11/21/10, 10:30 PM   #11
Blue71
Blue71's Avatar
Broncos Rule!
Johnson City, TN
Bax..drive up and help me fix this baby
Andy
'69 Half Cab
'70 Wagon
'71 Stroppe Baja
'73 Sport
'74 Sport
'75 Wagon
'77 Wagon
Blue71 is offline
Old 11/21/10, 11:55 PM   #12
gumbydood
A broken valve spring might also cause this problem... i had some serious backfiring/misfiring issues with a broken intake valve spring, and it could be a "fine" one day and "bad" the next. Just a thought...
gumbydood is offline
Old 11/22/10, 03:58 PM   #13
Blue71
Blue71's Avatar
Broncos Rule!
Johnson City, TN
Ok...I did get it runng bnetter today. Found a vacuum hose off behind the Carb on a vacuum tree fitting on the manifold. There was also another open port on a back there as well on that same tree. Doesn't appear to go to anything. Vacuum advance vacuum hose is in good shape and it comes off the front of the carb. Can't see any more vacuum leaks. Now she will idle fine. Revs up pretty nice and strong too. I took her for a spin, and first run was pretty good with a small bit of back firing from the carb, but not to bad and she ran strong. The next run down the street...it started out strong in the throttle, but would fall on her face in the mid range. Also seemed to fall on her face while pulling up hills too. Tried this several times and same thing happens. Timing seems to be pretty close too according to throttle response and starting. Brought her back in the garage and reved her up hard and no bumbles now. Just seems to do it mainly when driving.
Thanks,
Blue71
'69 Half Cab
'70 Wagon
'71 Stroppe Baja
'73 Sport
'74 Sport
'75 Wagon
'77 Wagon
Blue71 is offline
Thread Tools
Page generated in 0.30795 seconds with 54 queries
