 Bronco FAQ New
 Vendor Forum New
Bronco Auctions
Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Tech
Thread Tools
Old 11/26/10, 12:59 PM   #1
addicted
addicted's Avatar
Let em hang
Broussard, Louisiana
Spindle bearing
I tore down my D44 the other day and noticed that there is a needle bearing inside the spindle. I never saw them before and I cant seem to find them in any vendor catalog. Im replacing all my seals and I would like to replace these too. Anybody know where I can get these and how easy or hard they are to replace. Thanks!
Curiosity killed the cat. But for a while there, I was a suspect.
addicted is offline   Reply With Quote
Old 11/26/10, 01:06 PM   #2
DirtDonk's Avatar
San Jose, CA
SBK-1 is one of the common numbers for a kit with the bearing and the small seal(s) in it.
Some brands use just BK-1, but something like that should get you in the ballpark.
DirtDonk is offline   Reply With Quote
Old 11/26/10, 01:08 PM   #3
broncodriver99
broncodriver99's Avatar
Glen Allen, VA
They are easy to replace with a slide hammer and a socket. Wild Horses has some new bushings that replace the bearings and are supposed to last longer. May be worth a look.
'73 in progress. 302, 3 On the Floor, 2.5" Suspension, 33's, 3.50:1
broncodriver99 is offline   Reply With Quote
Old 11/26/10, 01:09 PM   #4
DirtDonk's Avatar
San Jose, CA
Oh, and do a search on it too, for the different methods of removal/installation, and relative amounts of hair pulled for each.
In my opinion, if they look like they're in good shape after a good cleaning, you're ahead of the game by just re-lubing them and leaving them in. If they're bad, replace them, but if they're still good, don't give yourself fits by trying to put new ones in there.
They're only in use while in 4wd, so don't get as much wear as other units do. They do get a lot of weather-wear however. Especially if not kept lubed.
I may be over-playing the drama a bit, but I've never had an easy time doing that job.
Good luck.
Old 11/26/10, 01:32 PM   #5
addicted
addicted's Avatar
Let em hang
Thanks guys. I got ahead of myself and asked before I searched. Replacing them sounds fun. Lol. Im putting in new axles so I dont want old crusty bearing riding on my new shafts.
Old 11/26/10, 03:10 PM   #6
DirtDonk's Avatar
San Jose, CA
Since I have a spindle-luber, I don't have to do this, but when you're putting the spindles back on, I would pack grease in there pretty good. During installation the axle will push excess grease out the front, which you can then use for the wheel bearings.
This way though, the spindle is fairly full of good clean grease, and will keep your axle shafts and bearings more or less rust and gunk-free for years.
Old 11/26/10, 04:07 PM   #7
frenchy
frenchy's Avatar
Goshen,Indiana
you know I've never had any trouble replacing spindle bearings, done alot of them through the years. I use a brass punch with a lip on the end you would hit with the hammer. Drive it out and then use a press to install new one. HTH someone
frenchy
frenchy is offline   Reply With Quote
Old 11/26/10, 08:21 PM   #8
DirtDonk's Avatar
San Jose, CA
Originally Posted by frenchy View Post
you know I've never had any trouble replacing spindle bearings. HTH someone
Yes it does! Now we know where to go when we need some replaced.
Hey, spindle bearing replacement party at frenchy's!!!
Old 11/28/10, 05:01 AM   #9
turbotim2
turbotim2's Avatar
I just replaced mine and ended up using an old rear spring bolt with the nut put on it backwards. The lip of the nut will catch the bearing, hit it with a hammer and they came right out.
"I can hire one-half of the working class to kill the other half." - Jay Gould
turbotim2 is offline   Reply With Quote
Thread Tools
Bulletin Board Software by: vB ulletin
Copyright ©2000 - 2013, Jel soft Enter prises Ltd.
Copyright © 1996-2013 All rights reserved. Privacy Statement
