Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 12/21/10, 09:26 PM   #1
3.8SC Bronco
3.8SC Bronco's Avatar
I sometimes fix things by accident
Elkhart
Door hinge backer plates ?
Started tearing my 71 down this week and all was going well until I took off the pass. door, the lower hinge backer plate fell. What holds them in place and how do I get to the one that fell ?
3.8SC Bronco is offline
Old 12/21/10, 09:57 PM   #2
NicksTrix
NicksTrix's Avatar
Dream Big
Denver, NC
eBay: NicksTrix
cut open the door post from the back side to retrieve it and repair it. a bit of sheetmetal "cagework" holds it in place.
NicksTrix is offline
Old 12/21/10, 10:33 PM   #3
shamu
Lucky as the day is long.
shamu's Avatar
Sachse,Tx
I did this once. if you can get the plate to move up high enough use a long sheet metal screw from the back side to push the plate. good luck.
Hopper
shamu is offline
Old 12/22/10, 07:26 AM   #4
frenchy
frenchy's Avatar
Goshen,Indiana
I see your from elkhart, is this bronco at dans body shop on US 33. If so I would like to come over and see it.
Mike
frenchy is offline
Old 12/22/10, 07:54 AM   #5
Explorer
Explorer's Avatar
Raphine, Virginia
eBay: gfw1985
Just a tip when taking the hinges loose. Cut three pieces of all thread rod and screw back into holes. Hinge will slide off without loosing the plate and will slide back on when replacing. Remove all thread and replace with one bolt at a time.
66 half cab 203ci I6, Classic Inlines aluminum head and intake, DSII, Holley 390 cfm 4V, Isky cam, Keith Black flat top pistons, ARP studs, balanced, 9.7:1 compression
55 F100 build in progress
Explorer is offline
Old 12/22/10, 08:45 AM   #6
3.8SC Bronco
Elkhart
Thanks for the info Nicks, I'll have to cut the post to get the plate out. Maybe I should ask ? before I do anything else Shamu or Explorer's idea would have saved me a patch job. Frenchy I'm Dennis with the red 71 that stopped by your house a couple weeks ago,decided to do a frame off but keep it stock for now.
Old 12/22/10, 09:54 AM   #7
frenchy
frenchy's Avatar
Goshen,Indiana
Quess I'm gonna have to write that down so I don't forget Well then we have another new one around, we'll have to go check it out!! Good luck with your resto you have a fine one to start with I think.
frenchy
frenchy is offline
Old 12/22/10, 07:45 PM   #8
hmh800
Eagle, CO
You may be able to avoid cutting the backside of the hinge post if you have one of those magnet on a stick things. With mine I can reach down and grab it, pull it up and hold on with a piece of all-thread.
hmh800 is offline
Old 12/23/10, 06:21 AM   #9
Dbarnes72
Dbarnes72's Avatar
Eastern Wa.
If you buff the door post before you cut it, you might see the spot welds where the shelf used to be attached for holding the plates from falling. Might not do you any good since it already fell, but if you need to go into the others for any reason, it will get you on the right side. Useless tip of the day....
Dbarnes72 is offline
Thread Tools
Page generated in 0.38921 seconds with 56 queries
