It's Luber time so show off your uncut Bronco
mini73
You make them or where did you get them? I wonder how those would look on an uncut
I did them myself. Mine is an uncut. I wanted bigger tires but did not want to cut mine. That's why I put the 5 1/2 sl on it.
bc1974
Hey mini73, I have about same lift n about to buy tires. Did u have to move the axle back to fit tire size?
mini73
No. Don't need it but eventually I will move the axle back.
mini73
Took almost all the plastic dip off and sprayed it with primer to get ready to do outside body work. Not much to do to the outside from the looks of it. Did not do a lot of sanding but I know I got to do some more. I guess since mine had the ranger trim I need to sand all the protective film sticker off the bottom. Other than that and some body work on the front right fender it looks good. Next to get is a paint sprayer. I'm done with the spray cans! Lol. I kind of like the rusty primer look.
marcussly27
I'm in the midst of a LUBR Coyote Restoration. Looks like 33x10.5 on stock steelies will fit with a 2.5 SL and 1 BL? Is the BL even needed? Thanks!
mpboxer
Queen Creek, AZ
1" BL - technically a LUBR?
New Stock Height WH Suspension and 1" WH Body Lift, 30x9.5 Tires
Seattle Rob
Took these pictures yesterday to celebrate finally "finishing" my Bronco. Come home and discover that my spare tire carrier is pulling away and ripping the top of my custom bumper. So much for "finished"
chuckyb
Awesome! I have been looking and looking for a ride with 1 BL only and no suspension lift, finally found it on page 91 :) Looks great!
RT9
1" BL, stock (old) suspension. My new springs bumped it up about another inch.
Sent from my SM-G860P using Tapatalk
