 Bronco FAQ New
 Vendor Forum New
Bronco Auctions
Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Tech
Thread Tools
Old 03/07/11, 11:01 AM   #1
John Marinan
Durango CO.
eBay: 1690johnm
Antenna
My antenna is shot. I have a new bezel set, but I don't have the actual antenna. Have any of you guys used anything else to replace the antenna part? Maybe just an aftermarket unit that fits?
John Marinan is online now   Reply With Quote
Old 03/07/11, 12:11 PM   #2
phred
phred's Avatar
"can't you say something righteous and hopeful for a change"
atlanta
eBay: brizance
I installed an aftermarket power antenna in the stock location. Works great.
phred is offline   Reply With Quote
Old 03/07/11, 12:22 PM   #3
jedblake
jedblake's Avatar
66 Roadster
Las Vegas, NV
Picked up an aftermarket at Pep-Boys and mated it to the bezel. Take your bezel w/ you and you'll see the one that fits. I'm running an aftermarket CD deck and the reception is pretty good.
Jed
jedblake is offline   Reply With Quote
Old 03/07/11, 12:54 PM   #4
HollywoodC
No Worries!
The Woodlands, TX
jedblake, I did exactly what you said, I either suck at matching pieces or it wasnt ment to be because my antenna set up didnt work.
phred, do you have a part number, place i can find the antenna you mentioned?
HollywoodC is offline   Reply With Quote
Old 03/07/11, 01:11 PM   #5
moe d
moe d's Avatar
Um, what were we talking about?
chicago, il
i used the pep boy's telescoping antenna.. works good when all the way up but works like crap when collapsed..
Thats what she said! lol..
moe d is offline   Reply With Quote
Old 03/07/11, 01:11 PM   #6
phred
phred's Avatar
atlanta
eBay: brizance
No, it was a replacement universal antenna. I did not try to use the stock bezel as mine was pitted badly.
Old 03/07/11, 07:19 PM   #7
Steve83
Steve83's Avatar
Fullsize Bronco Guru
Memphis, TN, USA
eBay: untod
I put a junkyard Crown Vic power antenna (box body) in Frank's, and it works fine. The only trick is to cut a rubber hose so the bottom matches the fender shape to fill in between the paint & the antenna mounting nut.
Down . . . Up
The dash switch came from an aero body CV/GM.
Steve83 is offline   Reply With Quote
Old 03/07/11, 09:07 PM   #8
PAPITT
PAPITT's Avatar
NP435 BED LINER TOP. BED. BUMPERS. ROCKERS. 4bt P/S. FLOTHRU TAILGATE. 16'' TIR
Stephenville..TX.
I used and aftermarket one made by PM or Peterson it's a Black rubber about 18 inches and works great in the trees.
............R. I. P. H. D. May 2nd 1999
PAPITT is offline   Reply With Quote
Old 05/04/11, 03:31 PM   #9
DirtDonk's Avatar
San Jose, CA
Just came across this yesterday, so thought I'd bring this subject back up.
While looking through my most recent Peterson Manufacturing catalog, I came across part #95031 Ford replacement antenna. From their description:
"32: single mast polished stainless steel mast
Direct replacement for '73 to '91 Bronco...
Then it goes on to list several years of LTD, Capri, Crown Vic, Continental, T-bird and Cougar.
Not sure about the cars, and it does also say "fits any vehicle with flat surface that fits a Ford-style base, which is strange, but in the picture it's totally an EB angled flange base. Looks like it should work perfectly.
The main difference I see between it and a factory EB model, is the lack of the underneath bracing that bolts to the body for added support.
Might be worth finding a PM distributor though, and taking a closer look.
Haven't checked out the website yet, but in case someone's interested, it's www.pmlights.com
'71 Wagon, 3.5" lift, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers.
Soon to be 5.0 w/ NV3550 and NP241 and whatever other parts are stuffed in the cab, storage room and garage, waiting to be installed.
www.wildhorses4x4.com
DirtDonk is offline   Reply With Quote
Old 05/04/11, 03:36 PM   #10
DirtDonk's Avatar
San Jose, CA
Well. looks like I should have done my due-diligence. Even though the catalog pic is the spittin' image of an early Bronco antenna, if you go to the website it shows the standard seventies/eighties Ford car and truck antenna.
Hmmm, wonder if it comes with two bases?
Oh well, they probably meant "73-'91 Truck" and "78-'91 Bronco" and not just Bronco.
Rats! Thought we had a winna!
Old 05/04/11, 09:24 PM   #11
John Marinan
Durango CO.
eBay: 1690johnm
I have a base that looks like the bronco sloped base. It is looks to be the right base but it does not fit the fender in any configuration. It came with 2 black plastic spacers. , supposed to be NOS.
I'm thinking I may have a replacement fender that someone drilled for an antenna. I bought an auto parts antenna. It fits mostly.
I'm just not sure what's going on with this.
thanks
John
Old 05/04/11, 10:27 PM   #12
Steve83
Steve83's Avatar
Memphis, TN, USA
eBay: untod
'80-96 F-series & Broncos use the same antenna, all the way inside the cowl.
Old 05/05/11, 02:06 PM   #13
larryejoh
larryejoh's Avatar
Clarksville, TN
I took one from a 90 Taurus and grind down the chrome base to match the fender. It closely resembles the stock base. I went with the fixed mast or go could go with the power version.
larryejoh is online now   Reply With Quote
Thread Tools
Bulletin Board Software by: vB ulletin
Copyright ©2000 - 2013, Jel soft Enter prises Ltd.
Copyright © 1996-2013 All rights reserved. Privacy Statement
