Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 03/16/11, 01:50 AM   #1
taipeichris
taipeichris's Avatar
"Some men are born great, some men achieve greatness & some men drive Broncos"
Los Angeles, CA
Cool How far does a CB radio reach?
Hi Guys,
So I've never used a CB before and would like to ask you for some basic advice.
So here are my questions:
1. How far of a distance does a CB work from?
2. What brands are good OR what brands should I stay away from?
3. Does size matter? I'm referring to the antenna!
4. Hand held CBs or in dash?
After the disaster in Japan my family and I have been working on revising our emergency earthquake plans and we're considering keeping CBs in the cars, especially since cell service might be down.
Thank you in advance as always for your great info!
Chris
taipeichris is offline
Old 03/16/11, 02:52 AM   #2
Ratch
Ratch's Avatar
Goodlettsville, TN.
Originally Posted by taipeichris View Post
Hi Guys,
Chris
An out of the box CB radio is good for 5-15 miles depending on antenna, terrain, atmospheric conditions, and amount of traffic on the channel. If you have it tuned, it can reach quite a bit farther.
Cobra and Uniden are both considered top of the line as far as commonly available brands.
Antenna choice is important, and having your radio tuned to the antenna is critical if you want to maximize the performance. Back in the day, I had a $20 wall mart Roadmaster 40 channel that I had tuned to a 102" steel whip that would walk all over an out of the box Cobra LTD Classic. I do not want to advise anyone to do anything illegal but there are amplifiers that can greatly extend range. But the FCC really frowns on it. Don't ask me how I know
Hand held CB's are ok if you want to flag down a passing trucker for roadside assistance, but for disaster communication I wouldn't expect much.
If you are serious about this I would suggest getting a HAM radio license. HAM operators have always been involved in providing communication support of disaster relief efforts. I am not a HAM operator, but I used to hang out with a few. Google turned this up. http://www.arrl.org/
Hope that helps you out.
'76 Sport project. '76 driver 5.0 Explorer EFI C4
Ratch is offline
Old 03/16/11, 05:59 AM   #3
englewoodcowboy
Lick Creek Restorations
englewoodcowboy's Avatar
"The Duck"
Ceres, VA
A CB out of the box reaching 5 miles is only in ideal conditions. There are still alot of devices that emit or transmit an AM frequency which kills the effective distance. The absolute best antenna you can get for any of them is a 102" stainless whip. This is a true quarter wave non loaded antenna, but the antenna is only as good as its base. The best location is in the center of a roof so as you have seen guys mount them on bumpers, the side of the vehicle to keep height down, it downplays the true power of the antenna but even mounting it low on your vehicle it will be much better than someone running a fiberglass loaded antenna. Now I have not heard or seen an FCC officer in over 20 years... that being said does not mean they do not exist out there but most truckers typically run a 10 meter radio re-tuned to run CB (Citizens Band). A10 meter will push out 50 watts compared to a CB which is only supposed to run 12 watts. (A tuned CB will push 20 - 25 watts but eventuall will burn out the secondarys due to the excessive heat). The other feature when a 10 meter is reconfigured to CB, it basically becomes a side band radio allowing you to choose frequencys just off of the normal 40 CB is allowed to run. Its outlaw radio and alot do it. For emergency purposes though, I would look into a outlaw radio for long distance comm. With that radio you will be able to hit some HAM frequencys and these are the true emergency comm guys. Ham will literally talk around the world on good nights that they can achieve skip.
BoxWood Green Poly '73 (o===o) 347 Stroker, FiTech Go EFI, Explorer Serp, 2.5" WH SL w/Bilsteins, AOD, Hydroboost PB, TrueTrac LS Rear, 4.88 gears, 35" BFG ATKO2, F150 Front Disc Brake, Factory PS, Family Cage ctsy Nick's Trix, AC, Stereo System, PWR Windows, Locks & Steps My Build.
englewoodcowboy is offline
Old 03/16/11, 07:23 AM   #4
.94 OR
.94 OR's Avatar
Willamette Valley
Any input on SWR meters to adjust the antenna? I use a CB in my work truck and it isn't doing what I think it should.
1967 Body over 1971.5 Frame and running gear, 3.5" lift, all stock except what's not
.94 OR is offline
Old 03/16/11, 07:42 AM   #5
Wyflyer
Wyflyer's Avatar
Brighton, Colorado
I always thought Chuck Norris should have built his own brand...
"not a project for dreamers it does take some work to build a car"-Craigslist Bronco for sale
Wyflyer is offline
Old 03/16/11, 09:18 AM   #6
BroncoDawg
BroncoDawg's Avatar
God Bless America
Bishop, CA
Wouldn't put much faith in CB for disaters as they don't have much reach even when matched to the antenna. Out of the box they only put out 5 watts and if they reach 5 miles you're doing well.
The tall steel whip antennas work the best, but they are dangerous for trail rigs to use as anyone standing near your rig in tough terrain is in danger of getting hit by them. That's why you don't see them much anymore. Put a 4 footer in the center of your roof for best performance.
Got my ham license a while back and no comparison in the performance and range and only keep a cb since so many still use them on the trail.
No matter where you go, there you are!
1977,EFI 5.0 HO,C4,Klune,37" MTR/ 75 Bronco yard art/ 79 F350 4x4 / 99 F350 crewcab 7.3 4x4
BroncoDawg is offline
Old 03/16/11, 09:22 AM   #7
73stallion
BANNED
73stallion's Avatar
Don't look at me in that tone of voice!
Eugene, OR
Ratch is right about HAM radio, me and my daughter are operators. a lot of 2 meter, 220, and 440 frequencies use repeater towers, and almost all of them are on battery backup in case the power goes out. there's a few local repeaters that are tied world wide, i've talked to many different countries.
HF is even better, no repeaters needed because the signal uses skip to get out. little more for the equipment and you need a bigger antenna, but more chance of getting contact.
CB all depends on where you are. where we are with all the hills, maybe a few miles. on the other hand i was driving across utah a few years ago and i was talking to someone 40 miles away. of course my CB was pushing 45 watts.
73stallion is offline
Old 03/16/11, 09:39 AM   #8
NYLES
NYLES's Avatar
YOU WANNA WHAT?
FREE RUN, MS
adj swr as low as posiable
'69, 306 EFI'ed, ZF, DANA 44, 4 WHEEL DISC'S, ASTROBOOST, 3.5"SUSPENSION LIFT, 2"BODY LIFT, GLASS BODY, 37" ON MRW, 5.13's GRZZ/GRIZZ , MOSER, STONE CRUSHER, POWER STEERING, BAILIE BILT, DURABACK, RJM
NYLES is offline
Old 03/16/11, 09:52 AM   #9
Pokey71
Pokey71's Avatar
Im From Pirate
PBB
eBay: For-Be
Also to fine tune the antenna,
The extra wire from the antenna to the CB needs to be pinched. Loop the excess and zip tie the middle so it looks like a bow. Don't ask why but it works. I have been told my many people that this helps.
{o===o}
---> Go East Marines--->
Pokey71 is offline
Old 03/16/11, 05:17 PM   #10
taipeichris
Los Angeles, CA
Hi Guys,
Interesting... what do the police use? Ignorant question but are ham radios portable?
Thanks and please keep the info flowing!
Chris
Old 03/16/11, 05:37 PM   #11
NYLES
NYLES's Avatar
YOU WANNA WHAT?
FREE RUN, MS
how far are you wanting to talk? diff ways to do it but a range here would be good
NYLES is offline
Old 03/16/11, 06:11 PM   #12
mortimersnerd
mortimersnerd's Avatar
Hi Guys,
Chris
You can get handheld ham radios, but they're not as powerful, just like handheld CB radios.
mortimersnerd is offline
Old 03/16/11, 06:19 PM   #13
mortimersnerd
Hi Guys,
Chris
Old 03/16/11, 06:22 PM   #14
NicksTrix
NicksTrix's Avatar
Dream Big
Denver, NC
eBay: NicksTrix
breaker breaker, you got a copy on the one niner? 'com on
NicksTrix is offline
Old 03/16/11, 06:35 PM   #15
epicadventure
Newbie
epicadventure's Avatar
Bigger the blob, the better the job
Woodburn, KY
It has to do with inductance. If you figure eight the extra, it cancels it out.
1975 with a 302, ZF 5 spd, NP205 and onboard air (under construction)
epicadventure is offline
Thread Tools
Page generated in 0.43801 seconds with 59 queries
