Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 03/21/11, 08:59 AM   #1
treetopflyer
Newbie
Yuma
Rear axle pinion off-set
Hey guys, looking at cutting down a Dana 60 out of a E350 van. My question is "what is the rear pinion off-set"?, i.e. is the pinion directly behind the Dana 20 rear output or off to the right or left...NOTE: don't let the differential housing fool you...the pinion itself is not in the center of the "3rd member".
Is there an issue if the driveshaft angles left or right or must it be parallel to the frames/ 90* to the face of the transfer case rear output.
I don't have the body off of my truck to get accurate measurements and can’t find a diagram that shows the information I’m looking for. Hope I explained this clearly enough? A pictures worth a thousand words.
'69 EB, '98 VW Jetta TDi, '01 VW NB TDi
treetopflyer is offline
Old 03/29/11, 10:28 AM   #2
treetopflyer
Newbie
Yuma
stock rear axle dimensions
All right guys...this has been posed for 8 days and no bites. Let me pose this another way. To make my donor REAR Dana 60 axle, B.O.M 606522-3, fit my69 EB (58"WMS-WMS), I'll have to cut both sides down. If I just cut down the long side, the differential will not be centered. I tried to measure the stock ford 9", but I couldn't get accurate measurements with the body still on the frame. I can't tell if the stock rear driveshaft runs straight back to the rear pinion OR if it's angled left or right, and if so how much?
Clear as mud? I thought so...if the rear D/S does angle left or right I'd like to know the dimensions so I can cut my new axle to match or even correct the offset so the T-case output and the rear pinion yoke are in line.
Anybody got the body off their EB with the 9" still under it? Could you drop a few plumb lines and get some measurements? You know the old adage “measure twice, cut once”
Old 03/29/11, 10:44 AM   #3
Explorer
Explorer's Avatar
Raphine, Virginia
eBay: gfw1985
I'm at the perfect point to measure for you except for one thing, my third member is out being repaired. Hopefully someone will help you this time.
66 half cab 203ci I6, Classic Inlines aluminum head and intake, DSII, Holley 390 cfm 4V, Isky cam, Keith Black flat top pistons, ARP studs, balanced, 9.7:1 compression
55 F100 build in progress
Explorer is offline
Old 03/29/11, 11:19 AM   #4
treetopflyer
Newbie
Yuma
Explorer...thanks man! I'm not in a rush (weeks not days). If you don't mind following up with this That would help me a bunch.
P.S. did I make my request clear? Sometimes I type in what I think is great detail, but it doesn't make sense to anyone but me!
Old 03/29/11, 12:51 PM   #5
Explorer
Explorer's Avatar
Raphine, Virginia
eBay: gfw1985
I should have it back long before then. If it helps any, the center of the Dana20 output shaft is offset 2" towards the passenger side.
Explorer is offline
Old 03/29/11, 01:28 PM   #6
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
I have layed out a few drivetrains in the past. as much as you think the driveshaft points straight back at the axle, it doesn't. I was amazed to find out how croocked some engines sit in the frame. Pull a straight line from the center of the pinion to the center of the damper on the engine and nothing lines up. Not sure if the Bronco follows this.
I have sen a Jeep with an axle swap. Dana 18 T-case with offset rear output and AMC20 rear end with centered pumpkin. Driveshaft was at a funny sideways angle and the owner drove it without issues.
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
“How hard can it be?”-Clarksonius 4th century BC.
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is offline
Old 03/29/11, 01:36 PM   #7
treetopflyer
Newbie
Yuma
Explorer, thanks...I did see the XFER case is offset, but couldn't get a accurate reference for measurement. I tried to get a straight edge between/ across the frame rails but with the dual exhaust and plumbing, no luck...keep me in mind when you get your diff. back and installed.
Old 03/29/11, 01:45 PM   #8
treetopflyer
Newbie
Yuma
Broncobowsher...That's what I've seen (jeeps), some D/S's not only slope down (as all D/S's do) but also angle side to side. I agree that it shouldn't be an issue (+- an inch or so), but I'm no Driveshaft guru and was curious about compound angles. I still need a left to right measurement so I can get my dana 60 cut soon.
Thanks guys
Old 03/29/11, 05:02 PM   #9
TBS-POPS
TBS-POPS's Avatar
ALL my drinking buddies have a severe bronco problem!!
valley springs, ca
Just cut it so the housing is centered. thats the way a full width nine inch is. the pinion IS off to the pass side.
WWW.NORCALBRONCOS.COM 72, TBI 302, 435,20,FW44&9,4.56 w/pl&arb,2" & 5.5" on 37's.SOLD Broncoless for now
Broncos are like BOOBS, There always better after they've been worked on..
TBS-POPS is offline
Old 03/29/11, 05:09 PM   #10
siderbox
siderbox's Avatar
hold my beer, watch this
Gardner KS
I'm with Broncobowsher. I too have set more than a few 'one off' chassis.
The pinion angle is WAY more important than the offset.
You can put the offset just about anywhere you want.
Have you ever looked under a LandRover?
Light travels faster than sound. That's why some people appear bright until you hear them speak.
66 HalfCab
siderbox is offline
Old 03/29/11, 05:20 PM   #11
broncodriver99
broncodriver99's Avatar
Glen Allen, VA
I'm getting 10-7/8 from inside pass frame rail 12-5/8 from drivers.
'73 in progress. 302, 3 On the Floor, Stock HD Suspension, 31's, 4.11:1
broncodriver99 is online now
Old 03/29/11, 05:21 PM   #12
treetopflyer
Newbie
Yuma
Roger that on pinion angle...but is there a plus or minus to moving the rear diff. to one side or the other... (Light goes off)...unless I built it to match the FRONT offset...think about clearing a rock or obstacle...both diff's would be aligned and you choose a line that wouldn't smash them...thoughts, criticism, cheers? Did I mention that I love this site? well I do...group hug and kumbaya to all.
Old 03/29/11, 05:22 PM   #13
broncodriver99
Glen Allen, VA
My D20 output shaft measures right at 10" from pass. rail.
Old 03/30/11, 07:24 AM   #14
Steve83
Steve83's Avatar
Fullsize Bronco Guru
Memphis, TN, USA
eBay: untod
Read this & you'll be a driveshaft guru:
http://www.supermotors.net/getfile/8...nglesguide.jpg
Steve83 is offline
Old 03/30/11, 08:11 AM   #15
treetopflyer
Newbie
Yuma
Thumbs up
Steve83...U da man!
Thanks for the diagrams. That made things much clearer. I also liked the recommended balancing speed of 3000rpm vs. 500rpm and how the factory marks the high & low balance points of a given shaft to retain proper balance and orientation during assembly. Good questions to ask when searching for a driveshaft builder. Anyone ask this of Tom Woods or Jesse at High angle? Those two seem to have the best reputation on this forum.
Thread Tools
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.32625 seconds with 56 queries
