Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 04/03/11, 09:23 PM   #1
jperry1290
jperry1290's Avatar
NorCal
Replacement Gas Tank
So I am sucking a little junk up from my rear tank. Before I drop it I was looking at finding a good replacement that will fit. The 23 gal tanks are nice but a little pricey. Any tanks that can be used from other vehicles? What about mounting a fuel cell underneath and having the fill tube in the bed? Looking for bigger tank
jperry1290 is offline
Old 04/03/11, 09:31 PM   #2
vintage bronco
Hagerstown,Md
Why not try a stock replacement from TOM BRONCO
http://www.tomsbroncoparts.com/produ...ord-bronco-new
vintage bronco is offline
Old 04/03/11, 09:59 PM   #3
buckintone
buckintone's Avatar
I been to the puppet show, I seen the strings!!!
Carlsbad
You could always use that po15 tank repair reseal stuff, works good
buckintone is offline
Old 04/03/11, 10:24 PM   #4
73stallion
BANNED
73stallion's Avatar
Don't look at me in that tone of voice!
Eugene, OR
you comin down for fab fords next weekend? could always come down friday or stay til monday, aero tanks is a few miles east in san bernardino, their 23 gallon tank is a lot cheaper and works just as well.
73stallion is offline
Old 04/04/11, 08:48 AM   #5
jperry1290
jperry1290's Avatar
NorCal
cant make it down to So Cal. The bronco doesnt run without a carb and a dirty fuel tank
Old 04/04/11, 09:33 AM   #6
ep67bro
Bronco Junky
ep67bro's Avatar
I used to have time!
EasternShore, MD
clean the stock tank. A little muratic acid and some time will make the tank like new inside. Then get some tank sealer and it will last another 40 years!
67, 289, NP-435, 3.5 lift,1"BL, 35s,custom bumpers, work always in progress. Wifes 73, 302, c4, 2,5" lift 33s driver,
ep67bro is offline
Old 04/04/11, 04:02 PM   #7
Chief Master Sergeant
Retired U.S. Air Force
Chief Master Sergeant's Avatar
The Green Machine
Spokane, Washington
I just went through the same problem and just replaced my stock tank with a new stock tank from Tom's and new stainless fuel line kit from BC Broncos. Although I had some issues, of my own making, I am really happy with the end results.
1972, 302, NP435, 4x4x2 Rockcrawler Power Steering, Chevy Disk Power Front Brakes, WH 2 1/2" Suspension Lift, WH 2" Body Lift, Tub Lined w/Bullhide, 35s
1967, 289, Floor Shifter, 4x4x2 Rockcrawler Power Steering, WH 1" Body Lift, 33s, Chevy Disk Front Brakes, Hydroboost, WH 2 1/2" Suspension Lift
Chief Master Sergeant is offline
Old 04/11/11, 10:59 AM   #8
jperry1290
jperry1290's Avatar
NorCal
to the top
Old 04/11/11, 12:00 PM   #9
rustbucket
Jackson, MS
Not all fuel cells are DOT approved, so you might want to check that before buying. Also, the replacement tanks are angled at the back so you don't smash it when your out wheeling in the rocks. Most fuel cells are rectangular. Although some of the 23 gallon replacement tanks are a bit costly, I think the hassle factor makes it worth it.
1973 Wagon, '94 5.8L MAF EFI, GT-40, C4, 3.5" Duff Ultimate Suspension, 33" General Grabber (Red Letter), 4.11's.
rustbucket is offline
Thread Tools
Page generated in 0.29598 seconds with 54 queries
