Welcome to the Forums.
Go Back Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 05/05/11, 05:46 AM   #1
Blue71's Avatar
Broncos Rule!
Johnson City, TN
Brake Pedal to hard???
'70 Bronco w/ stock drum brake set-up. I just changed everything in the front brakes, the rears and lines were changed by the previous owner a few months ago along with the M/C. The Bronco did set after his work for several months with no use. Newer M/C from previous owner, brake lines, newer rubber hoses, wheel cylinders, shoes, and hardware. After bleeding the brakes thoroughly ...the pedal is pretty darn hard right at the top. Seems to stop just fine, and not really complaining, but just seems like you can only push it down a an inches or so before its hard. Usually I have around 3" or 4" or more until the brake pedal feels hard. Any ideas, or don't worry about it?
'69 Half Cab
'70 Wagon
'71 Stroppe Baja
'73 Sport
'74 Sport
'75 Wagon
'76 Explorer w/ Four Wheel Pop-up Camper
'77 Wagon
'77 Original Ranger, 76,000 mi
"Yes I Know, But When Do I Get To Drive That Thang"
Blue71 is offline
Old 05/05/11, 06:39 AM   #2
patterdale's Avatar
The avatar reflects light tan color and name of bronco.
Perfect. It means everything is tight and good to go. Manual brakes are not like power brakes in their "feel"
patterdale is offline
Old 05/05/11, 02:55 PM   #3
DirtDonk's Avatar
San Jose, CA
Absolutely. Sounds like what mine was/is when everything is in spec. The only thing I'd add is...
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
DirtDonk is offline
Old 05/05/11, 08:40 PM   #4
deltarat's Avatar
That's the way mine were when I replaced everything new. I added HB since and have some give in it now, but a lot better brakes. Still all drums though.
It just means you did everything right- brakes adjusted and bled well.
It's OK to give out, but NEVER give up.
deltarat is offline
Old 05/05/11, 09:13 PM   #5
Red Head Grease Monkey
thegreatjustino's Avatar
Vroom Vroom
Stockton, CA
Sound like correctly installed/adjusted/bled brakes to me as well. Ya gotta love the rock hard pedal.
'When my Bronco is finished' is only a hypothetical statement.
thegreatjustino is online now Forums > Archives > Bronco Tech - Archives
Thread Tools
Copyright 1996-2018 All rights reserved. Privacy Statement is not affiliated with Ford Motor Company
Page generated in 0.25879 seconds with 54 queries
