Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 06/11/11, 07:16 PM   #1
coachcal
Engine wont shut off!
'74 with a 302.
Recently replaced all cables from battery starter and starter Sylenoid (sp?). I only did this because they looked corroded. I have been driving it for about a week after changing the new parts. Now all of the sudden it will start up fine but will not shut off.
I turn the key to the off position and remove it but it keeps running. Have to disconnect the coil to get it to shut off. Also have to disconnect the battery or the radio would stay on.
Any help?
coachcal is offline
Old 06/11/11, 07:54 PM   #2
Steve83
Steve83's Avatar
Fullsize Bronco Guru
Memphis, TN, USA
eBay: untod
Originally Posted by coachcal View Post
...starter Sylenoid (sp?).
Any help?
Sure! It's spelled "relay".
http://www.supermotors.net/getfile/8...relaytypes.jpg . http://www.supermotors.net/getfile/8...tersolswap.jpg
Your ignition switch is bad, or a hot wire has come loose & shorted to the others. Look at the back of the switch, & this diagram:
http://www.supermotors.net/getfile/8...74apwrdstb.jpg
Steve83 is offline
Old 06/11/11, 08:37 PM   #3
DirtDonk's Avatar
San Jose, CA
I would say also coachcal, that another possibility is that your old relay/solenoid/thingy has gone belly-up and is sending current through the little Brown "I" wire on up to the coil.
It's unusual, but not unheard of.
Otherwise, as Steve says, the most common issue would be a bad ignition switch.
Unfortunately though, as he also said, you need to to some tracking, because any kind of fault or short that lets any voltage get to the Red w/green wire to the coil can keep the engine running.
My thinking was that, since you were messing with the starter relay a couple of weeks ago, that would be where I'd look first. It's also the easiest to diagnose, since all you have to do is pull the Brown wire off and run the engine again. See if it helps.
Good luck. And yeah, sylenoid and cylenoid seem to be the two most common mis-spellings here. So you're in good company.
And "relay" IS easier...
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
www.wildhorses4x4.com
DirtDonk is online now
Old 06/11/11, 08:45 PM   #4
coachcal
I just noticed one more issue. Apparently when I was running one of the battery cables I pulled a wire free from something. It is in the bundle running right behind the RELAY. It is black and white and says "compressor" on it. I haven't had a chance to chase it down to see if I can tell where it goes. I assume the obvious 1st option would be AC compressor.
coachcal is offline
Old 06/11/11, 08:56 PM   #5
DirtDonk's Avatar
San Jose, CA
What wiring harness are you running? None of the factory wires had descriptions on them.
And back to your first issue, I forgot that your radio stays on too. Kind of leads one back to the ignition switch itself again.
A quick test of something like the heater blower might tell you. If it runs with the key off, then you've got power out from the switch still.
If you have a voltmeter though, of course you can tell more things, but the simple tests are fun and rewarding too.
And beat the heck out of turning upside down and inside out under the dash. Any day of the week!
Old 06/12/11, 12:24 AM   #6
Viperwolf1
electron whisperer
Viperwolf1's Avatar
It's not dented, it's just been environmentally streamlined!
homelessly wandering
Don't be corrupting my peeps. If they want to call it a starter solenoid it's a starter solenoid.
'74 beater, 5.0 mustang EFI, C4, PS, front discs, twin sticks, 3.5" susp/1" body, 33's, 4.11's, ARBs, Hickey Sidewinder, cobra hydroboost
'70 cruiser, 5.8 explorer EFI, 4R70W, PS, front discs + hydro, twin sticks, 3.5" susp/1" body, 34's, 4.88's, ARB & tru-track
Viperwolf1 is offline
Old 06/12/11, 12:45 AM   #7
DirtDonk's Avatar
San Jose, CA
It's a fiendish thingy. One of many on a Bronco.
Old 06/12/11, 06:46 AM   #8
JLBachs
JLBachs's Avatar
Vincennes, IN
Had experience with this last week. The solenoid was bad and current was going from the tan wire on the "I" post on the solenoid to the coil. You should be able to confirm this by disconnecting the tan wire. The solenoid is relatively inexpensive and replacing offers the opportunity to uprade to the new style if you like that sort of thing.
JLBachs is offline
Old 06/12/11, 11:03 AM   #9
Steve83
Steve83's Avatar
Memphis, TN, USA
eBay: untod
I guess the Abraham Lincoln sheep riddle would be moot...
Steve83 is offline
Old 06/12/11, 09:18 PM   #10
nosaj2k
nosaj2k's Avatar
Green River, WY
Funny, I was having the opposite problem just the other day
Sure I'm satisfied. You would be too, if you're looking for dead-end, low paying dirty work.
nosaj2k is offline
Thread Tools
Page generated in 0.32345 seconds with 56 queries
