Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 06/15/11, 03:54 PM   #1
BoureeOne
BoureeOne's Avatar
Baton Rouge, La
Mexican 302 Engine Block????
I have read that my block may be either a Holman Moody Block, or a Mexican Block.
C8AM-6015*B
I have also read that if it is the Mexican Block, then I have gotten very lucky. It is in my 1966. PO told me the engine was out of a 1980 Mustang, but I think he was really off. I know the C8 means the engine is a 1968 Block. I will be looking later tonight to see if the words " hecho mexico " are stamped in the lifter valley. Anyone have any thoughts???
Thanks,
Scott
BoureeOne is online now
Old 06/15/11, 04:09 PM   #2
73azbronco
Too much time on my hands
73azbronco's Avatar
Aridzona
C8AM is a mexican ID.
73 Explorer , 347stroker, NV4500 D20, Quadrajet spreadbore with manual altitude compensation, 4.1 ARB, Moser CTM Currie, 78 FSB disks, 76 Tbird calipers. 3.5 WH suspension lift, 2" Body lift for NV clearance.
Build here:http://classicbroncos.com/forums/sho...69#post1759569
73azbronco is offline
Old 06/15/11, 10:34 PM   #3
shamu
Lucky as the day is long.
shamu's Avatar
Sachse,Tx
You do not have to pull the intake to verify that you have a mexico 302. Google mexico 302 and look for the boss that sticks out of the block on the passenger side just above the oil pressure line. Give me a minute and I find the link. I have one but my p/s pump hides the boss.
Hopper
shamu is offline
Old 06/15/11, 10:38 PM   #4
shamu
shamu's Avatar
Sachse,Tx
try this link
http://images.search.yahoo.com/searc...20mexico%20302
Hopper
shamu is offline
Old 06/16/11, 12:23 AM   #5
BoureeOne
BoureeOne's Avatar
Baton Rouge, La
Lifter valley does say "hecho en Mexico". My understanding these blocks had thicker castings and maybe a better crank. Anyone have any more info about the Mexican 302 engines?
Old 06/16/11, 01:01 AM   #6
ren71
SoCal
supposedly has higher nickel content, but people have weighed them and the difference is negligible from a standard 302. IIRC the main caps are a little beefier than standard ones though but they're still not 4 bolt mains.
I gave one away a few years back to a friend. In a bronco application with relatively low hp requirements there's really no need for it. If I were you I'd sell it to someone who buys into all the hype about them and use the profits for more useful bronco parts, like a locker or something.
ren71 is offline
Old 06/16/11, 05:22 AM   #7
kayakersteve
kayakersteve's Avatar
1974 Bronco
Western NY State
The only thing I know for sure is that Mexican Tequila is superior to other countries! So, You must have gotten real lucky if that is the case!
See Ya! SteveB
kayakersteve is offline
Old 06/16/11, 10:26 AM   #8
John Marinan
Durango CO.
eBay: 1690johnm
They are thicker, and the main caps are the same as a HiPo.
John Marinan is offline
Old 06/16/11, 10:43 AM   #9
BoureeOne
BoureeOne's Avatar
Baton Rouge, La
Are there any problems with components fitting on this block? I will be having the engine and heads rebuilt. Mostly stock with a mild cam. Have performer 2121 intake, Edelbrock 1404 500cfm carb, Mallory Unilite ignition. Will there be any issues that I might not be thinking about?
Old 06/16/11, 12:29 PM   #10
blubuckaroo
Grease Monkey
blubuckaroo's Avatar
The Ark was built by amateurs, but the Titanic was built by professionals.
Ridgefield WA
All your accessories will work.
The engine was actually an order boo-boo. Ford engineers were concerned about quality and strength of a product from that foundary and requested the heavier main webs. Someone else requested the higher nickel content for the same reason. Both orders were sent to the foundary. The rest is racer legend.
'77 Ranger/cut F&R/PS/PB/Vintage Air/2" suspension lift/1" body lift/T tie rod conversion/33-1050-15 BFG K02 tires/ 302/ Edelbrock 500 CFM 4 bbl/Aero Tanks/ Hooker Headers/ dual ex/ NV3550/ B&M shifter/ JB FabTwin Sticks/ 4.11s/rear posi.
blubuckaroo is offline
Old 06/16/11, 01:12 PM   #11
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
I remember some story about Ford wanting to start 302 production in Mexico. They sent down some patterns and the local foundry made a few engines. Total garbage. The foundery didn't control the material process, patterns were not set up right, etc. Well there was a deadline to get production up and running. So they threw everything at it. Figuring that the metal was crap they tweaked the molds to beef them up (hipo caps for example) and they also told the foundery to get it right or they would go elsewhere. So the foundery realizing they would loose a nice contract got there act together and went to better iron. It all came together, the blocks were good, better then american blocks. Production started and they never bothered to go back and cheapen the castings up.
So they are good blocks. those trying to make high HP with a junkyard block want them. Not really anything a Bronco really needs. If you have it, use it. If you are selling it, it might be worth an extra $50. They are the easier to find version of the 289 hipo block and cost less. But you didn't find a boss 302 block, those are much different and really worth a lot more.
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
“How hard can it be?”-Clarksonius 4th century BC.
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is offline
Old 06/16/11, 01:16 PM   #12
BoureeOne
BoureeOne's Avatar
Baton Rouge, La
The dates on the block say it was made in 68. The heads say 69. There is also an engine sticker on the glove box saying this came out of a 69 mustang. It ran pretty good when I took it out. I have the orig intake and two barrel. Wonder if there is any interest in those? Also have the ford valve covers, Dist and Coil and the stock exhaust manifolds. I will list them when I get pics.
Old 06/16/11, 01:21 PM   #13
BoureeOne
BoureeOne's Avatar
Baton Rouge, La
Did any of the Boss 302's come out of Mexico? If so, how can you identify them?
Old 06/16/11, 04:32 PM   #14
BoureeOne
BoureeOne's Avatar
Baton Rouge, La
Sticker on Glove Box
Bureau of Automotive Repair
Engine Indentification
Vin No. L1C73221
Year 1969
MFG Ford
Size 302
Anyone know how I can search the Vin No. It makes sense, because the Engine Code says it was made in 68 and the heads were made in 69. It is a Mexican Cast Block. Just trying to track down what it came out of. It is in my 1966 EB that I bought 2 months ago.
Old 06/16/11, 04:53 PM   #15
Adapt and overcome
Maricopa, AZ
No boss 302s came out of Mexico.
You can tell them becuase they are worth there weight in gold. Considering they only made a few thousand of them you won't just find one. 4-bolt mains and screw in freeze plugs, also the heads look like they came off a cleavland.
Thread Tools
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.40080 seconds with 54 queries
