torque converter
joshua
Bolts r not lining up with flex plate. They are in quarter inch from were they bolt. Brand new converter and tranny was rebuilt and trans guy got the converter. Flexplate is 164 tooth
joshua
joshua
He rebuilt 4 or 5 months ago. Hopefully that doesn't come into it
73azbronco
are these bolts sequenced as in they have to be lined up one way to bolt them else wise they don't match? so, have you tried spinning the c4 all the way around?
joshua
joshua
if they just simply didn't line up but they off. Left to right oppesed to being up or down if that makes any sence
73azbronco
well then, it looks from the photo you have the smaller torque converter, vipwerwolf will be here to save the day any minute.
broncnaz
Ford had 2 bolt patterns for the 164 tooth flexplate. 10.5 and 11.4 sounds like you got a 10.5 converter they are kinda oddball the 11.5s are more common. I'd probably get the correct converter as it may be a little tough to find the correct flexplate.
Viperwolf1
electron whisperer
Definitely the wrong converter. Most likely it's a converter for a 157 tooth flexplate (also 10.5" bolt pattern). The 10.5" 164 tooth converter is as hard to find as the flexplates. The big difference between the 157 and 164 converter is the length. 157 tooth bellhousings are not as deep as 164 tooth. Using a 157 tooth converter in a 164 tooth bell will be a disaster for the pump.
joshua
joshua
do you have any part numbers i can take to the guy and tell him what he needs to get??
joshua
joshua
what i should aks you is do you think i just need the 11.5 converter correct
joshua
joshua
Viperwolf1
electron whisperer
Trans guy is an old timer and its just him at his shop. So i called him and hes gone on vacation for the next two weeks. (left a message) So viperwolf if you think this is the right one im goin to order it cuz i dont want to wait.
That's the one.
