Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 08/16/11, 11:05 AM   #1
gnsteam
gnsteam's Avatar
Fred
Lincoln NE
eBay: gnsteam
Oil pan removal
I have a leak and need to change the oil pan gasket. Can the pan be fully removed? I have a 76, 302 and C4.
Fred
gnsteam is offline
Old 08/16/11, 11:17 AM   #2
Chief Master Sergeant
Retired U.S. Air Force
Chief Master Sergeant's Avatar
The Green Machine
Spokane, Washington
With mine, I can put the frame on jack stands, remove the driver's front tire, and lower the axle almost to the floor. This gives me enough room to angle the pan out. At least that's how I remember doing it. Does that make sense?
1972, 302, NP435, 4x4x2 Rockcrawler Power Steering, Chevy Disk Power Front Brakes, WH 2 1/2" Suspension Lift, WH 2" Body Lift, Tub Lined w/Bullhide, 35s
1967, 289, Floor Shifter, 4x4x2 Rockcrawler Power Steering, WH 1" Body Lift, 33s, Chevy Disk Front Brakes, Hydroboost, WH 2 1/2" Suspension Lift
Chief Master Sergeant is offline
Old 08/16/11, 11:29 AM   #3
73stallion
BANNED
73stallion's Avatar
Don't look at me in that tone of voice!
Eugene, OR
when mine was stock height i could jack it up by the frame about 4" and it'd come out.
73stallion is offline
Old 08/16/11, 11:43 AM   #4
70_Steve
Old Guy
70_Steve's Avatar
If You're Going to Do It, Over-do It
Phoenix, AZ
Same as the other guys. Much easier if you jack up the frame to let the front differential hang down a bit.
The one piece gaskets are a little easier to install and seem to seal more reliably than the other gaskets. Still put a dab of RTV in the corners. If you buy a one-piece, make sure the kit includes the little clips to hold the gasket in place. I bought a FMS gasket and had to use little tie-wraps to hold the gasket in place until I got a couple bolts started.
'70 Sport, 351W EFI, NV4500, D20 w/Teralows, 4.56s Dana 44 w/Ox and 9" 31 spline Detroit, 35" KM2's, 3 1/2" lift, 2" body lift, 4x4x2 PS, some other stuff I forgot about...
"If it's got tits or tires it's gonna be a problem"
70_Steve is offline
Old 08/16/11, 11:44 AM   #5
thegreatjustino
Red Head Grease Monkey
thegreatjustino's Avatar
Vroom Vroom
Stockton, CA
Take the weight off the front springs by jacking it up, and you should be able to maneuver the pan out around the front differential. I was able to do it with a Dana 30 and 2-1/2" lift with a fair amount of room left over.
'When my Bronco is finished' is only a hypothetical statement.
thegreatjustino is offline
Old 08/16/11, 11:46 AM   #6
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
If you have a 3.5in lift it will come right out. other wise you may need to jack up the frame a little like the others said.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 08/16/11, 03:20 PM   #7
chadomatic
St Paul
Mine came right out 3 inch lift
chadomatic is offline
Old 08/16/11, 08:51 PM   #8
gnsteam
gnsteam's Avatar
Fred
Lincoln NE
eBay: gnsteam
Thanks everyone! I was hoping it would come completely out. And thanks 70 Steve for suggesting the one piece gaskets.
Fred
gnsteam is offline
Old 08/16/11, 10:03 PM   #9
red hot71
kent wash.
So you guy's had good luck with those one piece gaskets. The reason I'am asking is I assembled my new engine in March used a one piece gasket with RTV in the corners, filled oil filter +2 qts of oil then prime engine brought it home set it up on the engine stand while I got other things taken care of and it been seeping oil from between the timing cover and oil pan gasket ever sence. The part thats got me spoofed is there only 2qts in the pan,it can't even be close to that level.
red hot71 is offline
Thread Tools
Page generated in 0.31055 seconds with 58 queries
