Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 09/05/11, 08:31 AM   #1
LSUpete
LSUpete's Avatar
GEAUX Tigers
Windemere, FL
eBay: LSUpete
PS Pump - Serpentine Pulley alignment
Trying to finish up a 4-year project....and hoping to get some work done on Labor Day.
I have a 351w and I'm installing a serpentine pulley system that I got from Chcuk. The kit came with some extremely vague instructions, but I'm trying to work throught that. I have multiple issues, and questions, but the most important is the pulley alignment. I've installed the pulley onto my Saginaw pump, but as you can see, the angle of the PS pulley isn't the same as the angle on the crank shaft pulley.
How can I massage-straighten-fix this?
'76 Sport, Frame-off Restoration, modified '69 351w with Edlebrock intake and quadrajet carb, 2 1/2" lift, Hydratech hyroboost, Painless Harness with multiple adds, 33's on 15x8 wheels. http://classicbroncos.com/forums/showthread.php?t=88493
LSUpete is offline
Old 09/05/11, 09:19 AM   #2
ElkhartBronco
ElkhartBronco's Avatar
Insanely Fanatical about Broncos!
Cedar Bluff
The crank pulley looks to be facing downward. Is the center of the pulley bent? Not to sound alarming, but I wonder if the harmonic balancer might not be installed all the way (correctly) ?
(0===0)
.69 U14.
ElkhartBronco is offline
Old 09/05/11, 11:49 AM   #3
LSUpete
LSUpete's Avatar
GEAUX Tigers
Windemere, FL
eBay: LSUpete
I don't think the crank is facing downward. The PS pump bracket is noticeably off.
LSUpete is offline
Old 09/05/11, 05:36 PM   #4
ElkhartBronco
Cedar Bluff
Hmm...... these old eyes haven't been the same since I got bi-focals!
aside from returning the bracket, you could shim it out from the top using washers or bend it in a vise with a good sized crescent wrench
(0===0)
.69 U14.
Old 09/05/11, 10:30 PM   #5
nvrstuk
nvrstuk's Avatar
20 gears forward...no reverse!
WA
How about calling Chuck tomorrow am?
Strrroker powered... 418 cubes, 518 HP, SEFI, EDIS, Still 20+ forward gears...CB build:http://classicbroncos.com/forums/sho...d.php?t=278607 NWCB Stroker/SEFI/EDIS/4r70W/KluneV/TrueHi9 build: http://northwestclassicbroncos.com/s...n-to-SEFI-EDIS
nvrstuk is offline
Old 09/06/11, 09:03 PM   #6
LSUpete
LSUpete's Avatar
GEAUX Tigers
Windemere, FL
eBay: LSUpete
Wow.....wish I had thought of that.
LSUpete is offline
Old 09/06/11, 09:19 PM   #7
nvrstuk
nvrstuk's Avatar
WA
What'd he say?
nvrstuk is offline
Old 09/06/11, 10:34 PM   #8
plumbdoctor
plumbdoctor's Avatar
Golden
I have the 5.0 bracket from WH, and I had to add some washers w/ the provided spacers to line everthing up. Kinda a pain in the a$$
plumbdoctor is offline
Old 09/07/11, 12:08 AM   #9
DirtDonk's Avatar
San Jose, CA
Something else looks amiss too Pete. I don't know Chuck's system, but the pulley on the pump looks to be not on all the way. Is it possible to put it on backwards? If so, the offset is holding it out. If not, will it go on any farther?
Yes, the angle looks off too, but I'm thinking that it's both an angle issue, AND a depth issue.
Just from here anyway. Good luck.
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
www.wildhorses4x4.com
DirtDonk is offline
Old 09/07/11, 05:31 AM   #10
LSUpete
LSUpete's Avatar
GEAUX Tigers
Windemere, FL
eBay: LSUpete
I've sent photos to Chuck and we're emailing back and forth. He's surprised about that pump pulley angle.
I put the pulley on crrectly, with the flange/offset toward the grill. I tightened that thing about as much as I could, without REALLY hunkering down on it. And, the pump shaft is flush with the edge of the pulley housing.....and that is the way I was always taught. There is about 1/2" of the pump shaft exposed between the back of the pulley and the face of the pump. Did I do something wrong?
Check out the attached photo.
LSUpete is offline
Old 09/11/11, 10:40 AM   #11
LSUpete
LSUpete's Avatar
GEAUX Tigers
Windemere, FL
eBay: LSUpete
Here's a good view of the PS pump bracket. There is no way to resolve this with shims or spacers. The bracket is bent and will have to be beaten into shape, or replaced.
LSUpete is offline
Old 09/11/11, 10:42 AM   #12
LSUpete
LSUpete's Avatar
GEAUX Tigers
Windemere, FL
eBay: LSUpete
Another monster problem with this system of brackets is that it puts the alternator and the tensioning pulley through the hood.
Does anyone know of a better alternator bracket to use with a serpentine system?
LSUpete is offline
Old 09/11/11, 11:22 AM   #13
chuck
chuck's Avatar
Ingram, Texas
eBay: bcbroncos
The system is from a 89 mustang. If your hood hits it is the only one I have come across that would. I do not know why yours would or why your PS does not set right, I sent the 2 spacers that should be installed between the pump and bracket. If that does not fix the Pump alignment or if you are tired of messing with it send it back. I am sorry it doesn't fit for you and I can't see why from the pictures what is diff. Was the pump bracket bent when you received it? They are my design but I do not make them, we have them made by the 100 then powdercoated so I guess they could have been bent in shipping but they were made to be flat. As I told you we are out of stock right now.
Also, the hood raises up in the center.
BC Broncos, making Innovative ideas reality.
chuck is offline
Old 09/11/11, 02:08 PM   #14
DirtDonk's Avatar
San Jose, CA
I know this is off-the-wall Pete, but your motor looks tilted up farther than normal. Maybe it's just the height of the brackets throwing my perspective off, and I don't have one in mine right now to go out and compare to, but it all looks tilted farther than I remember.
Is that possible in your case? If other things have changed, maybe someone here could compare theirs to yours, say the valve cover angle to the fender, maybe that would tell the tale.
See? I said it was off-the-wall and a long-shot. Unless you put some odd type of trans and mount in there and it's too low, or there are some uber-tall engine mounts in it, I don't see what else would cause that (other than my crossed-eyes that is!).
Unless you don't have a trans in it at all yet? That would be too much to hope for, I'm sure, but it's worth a mention.
And back to the pump, obviously there's no way to get the pulley on wrong-way-round, so is it possible that there are pulleys with different offsets? This pulley came with the kit I presume, but maybe someone here with an '89 Mustang setup can compare.
You're correct about them (usually) being seated to the end of the shaft, but they usually don't have that much of a gap between the pump body and back of the pulley either. They can be pushed a bit past the end of the shaft in some cases (tools allowing), but I don't think there's enough there to be the answer.
With the P/S kits though, you sometimes have to space the pump back off the bracket to fit. There to too many different pumps that people can use (we've run afoul of that here many times!), so there is that to wonder about too. But here again, that's a lot of spacing, so not sure.
Which exact pump are you using, and why is not spacing it back an option? Will the tank hit the engine, or the tank inlets interfere with the fender? Kind'a looks that way from here, but the angle is not good to see that.
We had a bracket go out defective recently (documented here on CB) and had to replace it due to some incorrectly fabbed components.
It wasn't just bent (which is usually easy to fix) but had at least one, if not two, little tiny threaded bosses welded on completely crooked. Unfortunately for our customer, it wasn't caught at the manufacturer and got boxed up and sent out for him to discover when his pump didn't line up.
Not saying that should make you happy about yours, or make it any less of a hassle to deal with. Just that it has happened to us too.
Don't mean to muddy the waters, but I'm throwing out things that look to be possible help. I hope!
Good luck.
DirtDonk is offline
Old 09/11/11, 03:04 PM   #15
LSUpete
LSUpete's Avatar
GEAUX Tigers
Windemere, FL
eBay: LSUpete
Paul et al,
The motor does seem to sit high, but I don't know why that would be. It's a 1969 351w with stock motor mounts. The C4 transmission mounts are brand new from Jeff's (I believe) so I'm not sure how they could cause any unusual height.
The PS pump is a Saginaw unit and it's been modified to coordinate with a hydroboost braking system.
I pulled the pump bracket and it is definitely not flat. It curves a bit and I'll be sending that back to Chuck. Once he sends me the new one, I'll try the spacers and see if I can get it to work.
The alternator bracket just seems so ridiculously big for it's purpose. I would love to find some other bracket that works with this system.....without putting the tensioning pulley into the hood.
I really want this system to work, but if I can't get it to fit under the hood, I'll have two choices:
1. Install a body lift.
2. Go back to the stock V-belt system.
LSUpete is offline
Thread Tools
Page generated in 0.38656 seconds with 59 queries
