Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 10/03/11, 05:11 PM   #1
skifast
skifast's Avatar
Sandhills, NC
ZF rebuild
Anyone rebuilt their ZF transmission?
In neutral it makes a terrible rattling sound. It did not do this on initial startup after the replacement. Starts fine, shifts well but, just makes a racket.
Can anyone else take a stab at what I might have going on?
74 Bronco -EFI, ZF, Cage Arms, modified Bailie Bilt front and rear bumpers, 3.5" lift, Bilstein 7100 and 5150 shocks, BFG KM2 35's
1968 U14 going to become the wife's LUBER
skifast is offline
Old 10/03/11, 05:44 PM   #2
nik
nik's Avatar
elbow grease?.... hey this stuff works pretty good!
Corcoran, CA
Didn't rebuild mine, but mine makes the same racket in neutral like there's a marble bouncing around. From what I've heard this is fairly common for the ZF.
1969, 302 Terminator EFI, ZF5/BW1356 planetary box/np205(twinsticked), 4.88s, Full Widths HP44(locked) & Hi9"(ARB), 4.5 SL, custom arms, 1" BL, 35s, 1 ton steering w/4x4x2 box custom bumpers & cage, warn bellevue winch, York on-board air etc
nik is offline
Old 10/03/11, 06:11 PM   #3
Bronco Brian
Bronco Brian's Avatar
No Money / No Time
Ukiah
Throwout bearing ??? That's what mine sound like
Originally Posted by Wyflyer View Post
I bet you could pull a kitten through the axle tube with a rope and it would act much like swabbing your shotgun barrel with patches...
Bronco Brian is offline
Old 10/03/11, 06:26 PM   #4
Apogee
Apogee's Avatar
Cuz that's how I roll.
Tangent, OR
Input shaft bearing? My NV4500 started making a similar sound before I pulled it and that's what it looks like, but I have yet to tear it all down and rule everything else out.
Did you know that 95% of all statistics are made up on the spot?
Apogee is offline
Old 10/03/11, 06:57 PM   #5
siderbox
siderbox's Avatar
hold my beer, watch this
Gardner KS
Neutral rattle is a fairly common noise in a manual trans.
I'll back that up with 15 plus years as a tech.
Now with that said there are possibly for repairable noises, like the ones Apogee and BB have stated.
Do you know anyone else with a ZF?
Or someone else that you value there opinion close to ya?
Light travels faster than sound. That's why some people appear bright until you hear them speak.
66 HalfCab
siderbox is offline
Old 10/03/11, 07:07 PM   #6
hmh800
Eagle, CO
I've got one that could shift 3-4 better, and it vibrates a bit in 4th. I've been searching the web for writeups. There's a couple out there, if I can find the link I'll post it up. The rebuild kits seem to cost $350+, depending on what parts you need. Syncros seem like a weak link on high milers. I can't decide after reading what I've seen if it's something I want to tackle. I did my own R&P, and transfer case, but there's a lot more parts in a ZF. Let me look for those links...
hmh800 is offline
Old 10/03/11, 07:10 PM   #7
hmh800
Eagle, CO
Here's one:
http://www.ford-trucks.com/forums/58...ifficulty.html
hmh800 is offline
Old 10/03/11, 07:25 PM   #8
broncokak
broncokak's Avatar
I'm a Mainah
My ZF does the same thing and everyone said it if pretty common.
68 3.5" lift 5.0L 4R70W/Klune V/D20, 4.88, 35s, ARBs
Baby needs a new pair of shoes!
broncokak is offline
Old 10/03/11, 07:29 PM   #9
bigmuddy
bigmuddy's Avatar
Consensus is not science!
Marthasville MO
eBay: bjf68
They call it neutral rollover noise. Same reason that Ford did a recall and fixed it by sticking some heavy padding between the carpet and the tranny tunnel. My seems to be worse after driving all weekend in low low around the 4x4 park. Normally it's just mildly aggravating but I try to not let my bronco idle much.
Ben
75 EB, 35" tires, EFI 5.0 with Explorer stuff. ARB/ Aussie locker, ZF tranny, 4.56 gears, twin stick, 2.5 BC lift, Cage long arms and dual shock kit,Ghetto fab hydroboost with disc brakes,yada,yada,yada!
bigmuddy is offline
Old 10/03/11, 07:52 PM   #10
trtlsoup22
trtlsoup22's Avatar
GLASS BUSTER!!!
Clinton, MS
Mine sounds like it's got gravel in it while in neutral... It's been installed for about 4 years.. The ZF came from my paw-n-laws well used farm truck. All I have done to it is changed the fluid.
ZF Trans, Atlas Transfer, P/S, 9.00x16 CO-OP Grip Spurs or 37 Pit Bulls, Hydro brakes, 3.5" lift , 4.56 locked F/R with longarms, MM10500 hyd winch, EFI!!
trtlsoup22 is offline
Old 10/03/11, 08:21 PM   #11
hammer
hammer's Avatar
Broncos eh?
Abbotsford, B.C.
eBay: hmr_tym
Yup mine makes a bunch of noise in neutral. Same thing with the one I put in my f250 as well.
hammer is offline
Old 10/03/11, 09:56 PM   #12
Knifemaker
Knifemaker's Avatar
Work In Progress
Youngsville, La.
I use to have a 96 250 with the ZF and it made the rattle sound when in nuetral pretty much from new till I sold it with 150,000 miles never a bit of trouble with it.
75 EB, 96 351W roller, ZF Tranny, 4:11 gears, Twin Sticks, 3.5" Duff front lift, Duff long arms, 1" body lift, Dual Shocks, Explorer Serpintine , 35x12.5" BFG, 750 Quadrajet, painless harness, ARB front and rear locker,Tera low gears in dana 20 ,RCV Front axles, to be continued.
Knifemaker is offline
Old 10/04/11, 04:36 AM   #13
skifast
skifast's Avatar
Sandhills, NC
When I first installed it, there was a whirring sound. New input bearing, new clutch assembly, BC ZF install kit and junkyard 89 F-250 ZF S42, just the back story.
It sat for two months while I was doing body and cage work. Started it and now all the racket it is loud like the transmission is tearing itself apart. The wife even asked if there was something wrong with the Bronco. Although still seems to shift fine.
It seems all my co-workers are a new car crowd and not alot of older F-250's running around to compare the sound of their ZF noise.
A long time ago I drove an Army buddies truck with the ZF and you could hear the transmission but, it was nothing like this. Or so I remember.
I have the Haynes manual for the year model F-250 I pulled the trans from and it said " noisy in neutral engine running" Input shaft bearing worn, damaged main drive gear bearing, worn countershaft bearings, or worn or damaged countershaft endplay shims.
I hear the folks say just run it but, I think the noise it is making is a little more than transmission noise, maybe?
In the end I am not a mechanic and have made it through all of my Bronco repairs by reading the book on the fender as I am doing it.
So run it or rebuild it, I guess I could just pad the heck out of the trans tunnel and wear ear plugs!
skifast is offline
Old 10/04/11, 07:13 AM   #14
bigmuddy
bigmuddy's Avatar
Marthasville MO
eBay: bjf68
I hate to admit this, but right after I installed my ZF I forgot to add fluid and let it idle like that for about 30 min in neutral. Fluid for the tranny didn't make the punch list for start up for some reason? It made one helluva a racket and sounded like rocks in the tranny. I realize that the ZF takes a synthetic tranny lube but I have been succesful in adding a pint of lucas oil to the tranny to get it to be a bit quieter. Not saying you should do it, but it worked for me.
bigmuddy is offline
Old 10/04/11, 08:01 AM   #15
KyleQ
KyleQ's Avatar
1 Ton 74'
Twin Cities
It's very common for people to add a bit of extra fluid to quiet it down. Another thing to consider is that our Bronco's are like one big resonating speaker, that same transmission in a newer pickup with it's curvy steel with foam and carpet over it makes a big difference.
I would just add at least a quart of fluid to help quiet it down - the guys on OilBurners will even damn near fill it up and they are pulling heavy loads with them...
74' Bronco -Fi-Tech Injected 357W - Twisted Demon C4- AtlasII 3.8 - D60/D70 - PSC Full Hydro - 5.5" lift - Cage Arms, Coils and Shocks - F-O-A 2.5" Air Bumps - 43" TSL SX on H1 Double Beadlocks
74' Bronco Ranger - Street Build in Progress (351W/ZF5/NP205)
KyleQ is offline
Thread Tools
Page generated in 0.32443 seconds with 56 queries
