quikdrummer
Well finally got everything together to get started on tearing the bronco apart!
We ended up moving into our own place, and it has a separate 2 car garage in the back yard that is my combination bronco shop/band room now. So Im excited. I decided to spring for a welder too...
Altogether I have the suspension and axles, power steering, brake booster, rock sliders, possibly bumpers, and a few other things for this round of building. Pics of the suspension and axles are here
I started with the rear suspension yesterday, got the old axle and leafs out,
and started installing the new leafs.
Im on hold with the leafs tho, I decided after getting the shackles out that Im gonna go ahead and replace the shackles while Im in there.
So then my brother in law and I decided to use the new welder on an old pool railing, and make a skate/snowboard rail.
Up next I will be getting the rear axle ready to go on. It needs new leaf spring perches welded in place, the old ones removed, the old shock mounts removed, the sway bar removed, and a good ole cleanup. I'll try to post every time I make decent progress.
