Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 03/10/12, 06:30 PM   #1
Crazz
Lexington, KY
common Gas tank problems ? 76 bronco
well i got the old bronco running good finally after head gaskets and timing chain/gears. but now it isn't wanting to run on the rear tank. starts coughing and sputtering out. which to the front tank and give it a sec and it does pretty good. so my question is whats the common gas tank problems on a 1976 bronco 302
Rich
Crazz is offline
Old 03/10/12, 06:55 PM   #2
Bartonatl
Bartonatl's Avatar
Saving the world one Bronco at a time
Atlanta
The pick up line could be clogged. The valve could be clogged. When was the last time it ran well on the rear tank?
74 sport: Built 302, C4 w/ shift kit, hedman hedders, 2" body lift, twin sticks, 4-barrel holly, Boss Hogg Racing Cam, 35" Pro Comps, stone crusher steering. 4.11 gears, Hydroboost brakes. And I vow to never paint her!!
Bartonatl is offline
Old 03/10/12, 07:10 PM   #3
Crazz
Lexington, KY
well it ran good on it earlier this week. drove it around for a couple hours. but it has done this before. guess i need to drain it and pull the sending unit out. dont really want to drop the tank tho LOL all the rust
Crazz is offline
Old 03/10/12, 07:50 PM   #4
frenchy
frenchy's Avatar
Goshen,Indiana
Sending unit should come out without droping the tank I think. Have you crawled under it to see where it's at. There not on top of the tank like other vehicles.
frenchy is offline
Old 03/10/12, 09:28 PM   #5
half cab
equestrian patcher
half cab's Avatar
ride like the wind bullseye
ms
Take the line loose at the valve and remove gas cap and blow back through the line and see if it's clear or stopping up.
76 SPORT 351W C4 PDB
half cab is offline
Thread Tools
Page generated in 0.30812 seconds with 58 queries
