Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 03/11/12, 08:04 PM   #1
NGABronco
NGABronco's Avatar
"Ain't Life Grand" I got 4WD Low, with 3rd & 4th gears!!! And a hand throttle!!!
North Georgia/Now SC
Solenoid??? Fixed it!!!!
I'm eat up with solenoid problems!!! 77' EB 302, 3 sp. Cranks up, drives around the block, cut it off and 2 hrs later, won't do nothing, a grunt!!!
I take the starter & battery and have them checked!! Starter's good, battery needs a charge to test (12.2 V, needs 12.5 V to test), leave it. Come back 2 hours later, battery is good!! Buy a new solenoid, put all that back on and it cranks right up!!! Drive it around the block, come home, cut it off, 10 min. later I hit the switch and the solenoid hangs up, starter spinning, I slap the solenoid and it quits???
What am I missing or doing wrong????
It's only money, I hope the government sends me more tomorrow!!!
NGABronco is online now
Old 03/11/12, 09:17 PM   #2
DEEPWOODS
DEEPWOODS's Avatar
Fayetteville
Ben, my last parts store solenoid did the same thing I had to go back and get a replacement they said they had a heavy duty one for a couple bucks more so I got it and all is good so far
DEEPWOODS is online now
Old 03/11/12, 10:12 PM   #3
66Bronco
66Bronco's Avatar
'66 Broncos Rule!
Southern California
eBay: 66Bronco
I take the starter & battery and have them checked!! Starter's good, battery needs a charge to test (10.5 V, needs 12 V to test), leave it. Come back 2 hours later, battery is good!! Buy a new solenoid, put all that back on and it cranks right up!!! Drive it around the block, come home, cut it off, 10 min. later I hit the switch and the solenoid hangs up, starter spinning, I slap the solenoid and it quits???
Sounds like you're having a charging system problem if your battery needs to be charged. If your alternator is working get a new battery. If your battery cables are suspect I'd recommend changing them too with quality replacements.
-Terry
66Bronco is offline
Old 03/12/12, 07:38 AM   #4
phred
phred's Avatar
"can't you say something righteous and hopeful for a change"
atlanta
eBay: brizance
Ben,
The solenoids are not constant duty. If they have constant power to them on the run position they will over heat and burn out. I'm wonderiing if the PO's rewire has a constant hot going to the start side of the solenoid. I can come throw more parts at it if you want.
phred is offline
Old 03/12/12, 11:16 AM   #5
NGABronco
NGABronco's Avatar
Thanks Keith, I'm gonna try another, parts folks said no problem returning.
Terry, thanks, that battery has been somewhat abused, without being properly charged (long story), all the wires are new, clean & tight??? Maybe I just got a bad solenoid, hope so!!! At least all this is happening in the yard!!!
Noooooo phred!!! I don't want you to throw any new parts at it!!!!! Unless you're buying!!!LOL
Old 03/12/12, 11:22 AM   #6
66Bronco
66Bronco's Avatar
'66 Broncos Rule!
Southern California
eBay: 66Bronco
OK Ben. I've seen batteries cause weird electrical issues when they start to go bad. Over all of the years I've had a Bronco (since '85), I've only had one solenoid go bad (it was on the Bronco when I bought it). I've had good performance from the Standard Motor Products I've purchased.
Good Luck!
-Terry
66Bronco is offline
Old 03/12/12, 11:48 AM   #7
bmc69
bmc69's Avatar
Maryland
eBay: ford_bill
From what I read above..I see nothing but a competely shot battery in the mix, causing most if not all of the problems observed. Maybe combined with the charging system also not up and working?
10.5 means not only is the battery dead..it usually means its 'beyond dead' with a bad cell too. 11.8-12.0 volts is 'just dead'.
'69 retro Bronco. Supercharged MPFI 8BA 239 V-8, C-4/D-20. Hydroboost. 5" lift.
bmc69 is online now
Old 03/12/12, 12:08 PM   #8
dave67fd
dave67fd's Avatar
The "67" refers to my utha Ford
Southeast NH
A fully charged battery in good state should be 12.6-12.8 V, No load. (2.1V per cell)
So if guns kill people, I guess pencils misspell words, cars drive drunk, and spoons make people fat!
My build:http://classicbroncos.com/forums/sho...d.php?t=196003
dave67fd is offline
Old 03/12/12, 12:18 PM   #9
Rustytruck
Rustytruck's Avatar
honest the bolder ran under me
El Monte CA
With the key off I would check to see if you have power going to The small terminals on the starter solonoid. there should not be any power with the key off. Also check the large terminal going to the starter there should not be any power going there when the key is off. Check your ground at the engine block.
Rustytruck is online now
Old 03/12/12, 12:58 PM   #10
BUCKNBRONK
fresno
Have u load tested the battery? I have seen more than one battery in my life that will show 12 volts(no load) and drop down to 0 as soon as the starer is engaged.. In fact I just had a optima in my diesel do it last month, I was about ready to replace the starter because I thought no way the battery was bad.
'72, 5.5" DUFF LIFT, 5.0, CHP 9",AOD, TERRA LOW TWIN STICK D-20, HYDROBOOST, ROCK CRUSHER STEERING, HIGH STRENGTH AXLES, LOCKED FRONT & REAR W/ 4.88'S, WARN 8274. ALL SITTING ON 37" PITBULL ROCKERS, SANDEN OBA SYSTEM & 3G ALT
BUCKNBRONK is offline
Old 03/12/12, 02:37 PM   #11
NGABronco
NGABronco's Avatar
Hey guys, I am "SORRY", I lied to ya'll about the battery!!! Didn't mean to, I just went back and looked at the before & after reports. Initially 12.2 V, needs to be above 12.5 to test, came up to 12.88 after a 30 min. charge. It's only six months old, just never used much.
The 10.5 volts was on one of the Yellow Tops in the Horse that I replaced 2 weeks ago.
Thanks for the advice & tips, I'm getting the meter and gonna go play with it some more!!
Old 03/13/12, 05:49 PM   #12
NGABronco
NGABronco's Avatar
I said I was gonna leave the EB's alone for a few day, but I couldn't stand it!!I took the solenoid back and got a new one, put it on and it's cranked 6-8 time no problem!!!DUH!!! Deepwoods, you win the prize!!!!
Thanks for everyone help!!
Old 04/19/12, 08:24 AM   #13
Bay0726
Bay0726's Avatar
Woodstock GA
eBay: bay0726
Napa makes a hd solenoid that won't hang up, or go buy one from ford. All the aftermarket cheap crap ones will eventually hang up. I actually had one melt and catch fire on the cougar.
Bay0726 is offline
Thread Tools
Page generated in 0.32413 seconds with 55 queries
