 Bronco FAQ New
 Vendor Forum New
Bronco Auctions
Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 04/07/12, 08:47 PM   #1
Chief Master Sergeant
Chief Master Sergeant's Avatar
The Green Machine
Cibolo, Texas
Does someone make a Bronco push in dipstick tube like this?
Just trying to find something that will help stop the leak from this style tube. Really just want one with the raised part to help plug the hole in the pan.
Click image for larger version
1972, 302, Floor Shifter, 4x4x2 Rockcrawler Power Steering, Chevy Disk Power Front Brakes, WH 2 1/2" Suspension Lift, WH 2" Body Lift, Tub Lined w/Bullhide, 35s
1967, 289, Floor Shifter, 4x4x2 Rockcrawler Power Steering, WH 1" Body Lift, 33s, Chevy Disk Front Brakes, WH 2 1/2" Suspension Lift
Chief Master Sergeant is online now   Reply With Quote
Old 04/07/12, 09:13 PM   #2
73stallion
Doctor of Broncology
73stallion's Avatar
Don't look at me in that tone of voice!
San Juan Capistrano
i really don't think the flange on the tube pushes into the pan, it's more like a stopper. why not something like this that has O-ring seals on it?
http://www.summitracing.com/parts/LOK-ED-5013/
'73, 302, NV3550, 2.5" lift, 1" BL, bilsteins, 33's, 4.10's, tube doors, ps, hydro, discs, blackout, swiss cheese body...
So Cal Mobile Bronco Mechanic http://www.facebook.com/home.php?#/p...50&ref=profile K6EZN
73stallion is offline   Reply With Quote
Old 04/07/12, 09:31 PM   #3
bronco t
bronco t's Avatar
Desert Dog Racing
Encinitas CA
Is there a tool that can make the bubble flair... Aka raised part?
1977, cut, 302, C4, D20, D44, 9" 3.5 TBP lift, BFG 32s, ProtoFab, Bestop.
"I don't suffer from insanity; I enjoy every minute of it".
bronco t is offline   Reply With Quote
Old 04/07/12, 09:47 PM   #4
fordtrucksrule
fordtrucksrule's Avatar
SoCal Highland
What i found that was leaking on my stock oil pan was the flange to the oil pan side was leaking causing a lot of headaches. what i did was i got a lokar dipstick that was the pan push in type and i took my pan off then i drilled out the old rivets and took it all apart then cleaned everything up and reassembled using black rtv and 10-32 screws and leak fixed.
351w with a rv cam. pumping 300ft./lb torque at 2000 rpm and 160 hp at 3500 rpm to the ground with 4.11 and 35" tires ZF Transmission and a StAk 3 speed t case 133:1 crawl, full family cage, rhino lined tub.
fordtrucksrule is offline   Reply With Quote
Old 04/08/12, 05:36 AM   #5
The Green Machine
Cibolo, Texas
I know that this particular pan was leaking around the rivets, so I drilled them out and welded this thing inside and out. It's not pretty, but I know she won't leak from the plates. I could swear I've seen a Bronco dipstick tube with that sort of flange. It serves just like someone said, as a stopper for the hole in the pan and I believe there was some sort of rubber gasket below it to help seal things. Anyone? Maybe I've lost my mind.
Old 04/08/12, 02:02 PM   #6
shamu
Lucky as the day is long.
shamu's Avatar
Richardson,Tx
Is this what you are looking for?
Name:	Oil pan 001.jpg
Hopper
shamu is online now   Reply With Quote
Old 04/08/12, 06:39 PM   #7
The Green Machine
Cibolo, Texas
No brother, I have one of these on my 72. I'm just trying to find a better push in tube for the 67. Thanks though.
Old 04/08/12, 07:32 PM   #8
chuck
chuck's Avatar
Ingram, Texas
eBay: bcbroncos
I do about the same thing except I use the stock parts and 1/4-20 nuts and bolts. Never had one leak.
BC Broncos, making Innovative ideas reality.
chuck is offline   Reply With Quote
Old 04/08/12, 08:12 PM   #9
deltarat
deltarat's Avatar
Drew,Ms
What do you use to seal the push in tube?
It's OK to give out, but NEVER give up.
deltarat is offline   Reply With Quote
Old 04/09/12, 01:08 PM   #10
chuck
chuck's Avatar
Ingram, Texas
eBay: bcbroncos
I use a little of the RTV that I use to seal the cup in. Just a thin film around the tube just before I push it in.
Old 04/09/12, 01:33 PM   #11
The Green Machine
Cibolo, Texas
I'll try some of the RTV when I put the new pan in. Thanks Chuck and Fordtrucksrule!
Old 04/09/12, 06:42 PM   #12
Bullitt94
Bullitt94's Avatar
Somewhere in that pile of rust over there is my Bronco...
De Pere, WI
That's what I do, too.
1970, Dana 44 w/ Discs, Front & Rear Mini Spool, 302 w/ Holley 4bbl & Edelbrock Intake, 2.5in lift, 35in Tires, Rust
Bullitt94 is offline   Reply With Quote
Bulletin Board Software by: vB ulletin
Copyright ©2000 - 2013, Jel soft Enter prises Ltd.
Copyright © 1996-2013 All rights reserved. Privacy Statement
