Go Back   ClassicBroncos.com Forums > Archives > Bronco Chat - Archives
Thread Tools
Old 04/25/12, 01:34 PM   #1
Brian B
Brian B's Avatar
Guntersville, AL
Brake Master Cylinder
Does anyone know if there is a difference in a master cylinder for a 1975 and a 1976 Bronco? My Bronco is a 75 with a 76 front end. Of course I have disc brakes on the front and drum's on the rear. Any help is appreciated.
Brian B is offline
Old 04/25/12, 02:33 PM   #2
Greg_B
Greg_B's Avatar
I ain't as good as I once was....
Cohutta, GA
Do you have power assist disc brakes like a 76 model? A 76 booster maybe?
Greg
BCB 3.5" lift, WH 1" body lift, 93 Mustang 5.0 EFI, F150 knuckles and steering linkage, Yukon 31 Spline axles, Custom full cage, ARB rear, Tru Trac front, 4:56 gears, 12.50 x 35 Cooper SST Pros, Centerline HT II wheels, Steel Horse Super Seats front, fold and tumble rear.
Greg_B is offline
Old 04/25/12, 02:49 PM   #3
Cooter_76
Cooter_76's Avatar
Austin, TX
Aside from being setup for disc/drum application, I think the '76 MC will have ports on the passenger side, which will interfere with the throttle linkage unless you have power brakes. The non-power drum/drum MC I took off my '73 had ports on the driver side.
73 - 302 & C4, 2.5" lift, 32" BFG KM2's, Ch*vy disc brakes, Duraspark, twin sticks, Rampage Soft Top, Holley Sniper EFI.
Cooter_76 is offline
Old 04/25/12, 03:03 PM   #4
Brian B
Brian B's Avatar
Guntersville, AL
Greg
Forgive me if this is a stupid question but what is the difference in the power assist disc brakes and standard disc brakes. I have the factory front disc setup a 1976 would have.
Brian B is offline
Old 04/25/12, 03:13 PM   #5
half cab
equestrian patcher
half cab's Avatar
ride like the wind bullseye
ms
Big round booster that the mc is mounted to... and will angle out over the dr side inner fender..
76 SPORT 351W C4 PDB
half cab is offline
Old 04/25/12, 08:57 PM   #6
cjcargo
Newbie
cjcargo's Avatar
Baltimore
Yes there is. Besides the differance from which side the lines connect on the MC's. There is a differance in the thread connections also, size wise didn't match the brake hoses from the 74' to 76' MC's. Adapters are available in any auto parts store. I first switched from a single reservoir MC on my 66' to a MC from the 74' with power assist. Now have also gone to disc/drum with the 76 MC.
cjcargo is offline
Old 04/28/12, 12:51 PM   #7
DirtDonk's Avatar
San Jose, CA
Like mentioned, all power-assist EB masters had the ports on the right, while manual masters had them on the left. I think you could special-order manual brakes even in the last couple of model years, but not sure if I've ever seen one first-hand.
Nobody brought it up yet, but in case you were wondering about it, I'm pretty sure that the master cylinder's piston bore was the same size for both power and non-power, disc and non-disc Early Broncos. So no problem there.
Reservoir size for the dual-reservior types was virtually the same for all years too.
Another "possible" difference is that the port for the front brakes on a manual master might have come with a residual pressure check valve behind the brass cone seat.
While I would think that all the original ones were so equipped, not all aftermarket ones have the valve. Either way though, you'd want to check, and if there is one, take it out for use with disc brakes.
I used mine for awhile that way, with no ill effects. However, the potential for dragging brakes is there, so I'd remove any RP check valves present.
Basically then, you'd usually end up using the master that was appropriate for your body (power or manual) and/or for whatever hoses you're using from the master cylinder to the frame.
Only needing to remove any check valves (disc side only) and make sure you plumb the front disc brakes to the rear (larger) reservoir's port.
A lot of us are running Ford disc brakes with the orginal masters with no assist. Works fine for me with up to 33" tires at least.
Good luck.
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
www.wildhorses4x4.com
DirtDonk is online now
Thread Tools
Page generated in 0.27803 seconds with 56 queries
