Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 05/19/12, 04:22 PM   #1
Gweiner
Gweiner's Avatar
Charlotte
Rear shoulder belt conversion?
Anyonyone know how I might be able to put shoulder belts in the rear of my 74 Bronco? Was trying to figure out how I might upgrade belts without adding a full roll cage.
My first post - Appreciate any help!
Glenn
Gweiner is offline
Old 05/19/12, 04:27 PM   #2
Chief Master Sergeant
Retired U.S. Air Force
Chief Master Sergeant's Avatar
The Green Machine
Spokane, Washington
I don't think it's possible.
1972, 302, NP435, 4x4x2 Rockcrawler Power Steering, Chevy Disk Power Front Brakes, WH 2 1/2" Suspension Lift, WH 2" Body Lift, Tub Lined w/Bullhide, 35s
1967, 289, Floor Shifter, 4x4x2 Rockcrawler Power Steering, WH 1" Body Lift, 33s, Chevy Disk Front Brakes, Hydroboost, WH 2 1/2" Suspension Lift
Chief Master Sergeant is offline
Old 05/19/12, 09:34 PM   #3
Gweiner
Gweiner's Avatar
Charlotte
Can I mount shoulder belts to a roll bar behind rear bench? Has anyone seen that set up?
Gweiner is offline
Old 05/20/12, 06:32 AM   #4
kaw550
kaw550's Avatar
MA
Didn't the Geo Tracker had a small hoop type roll bar that went behind the back seat.
I think it was for mounting seat belts. It ws too low to help in a rollover.
You could also look for seats that have the seat belts built in but I guessing most would be too wide.
72 Bronco, 302, C4, Astroboost, 33", 2.5" lift, rust
kaw550 is offline
Old 05/20/12, 10:26 AM   #5
TAC71
Every Bronco needs TLC Truck Loads of Cash
port coquitlam BC
I generally run a bikini top and tonneau cover. I built a custom rear seat which the seat back will fold down and the shoulder belt mount will fold down. So when the tonneau is on its almost flat and when the seat is in use the belt mount folds up and two pins hold it up. It almost looks like a set of bull horns when up and just the belt upper mounts are attached to it. The rest of the seat belt mechanism is mounted to the seat main frame. I could take and post some pics if you want.
Gary
71 Bronco, fully custom, daily driver
69 Torino, being built
TAC71 is offline
Old 05/20/12, 10:38 AM   #6
Bajabrewer
Bajabrewer's Avatar
Bronco Guru Wannabe
Lake Orion
Tac71 I would like to see pics because I am also trying to solve this problem in my Bronco. I want the safety of shoulder belts but don't want to alter the Baja rollbar.
If it ain't Broke - Try it in 4 Lo
Bajabrewer is offline
Old 05/20/12, 11:08 AM   #7
TAC71
port coquitlam BC
Photos of seat and belts......
Gary
TAC71 is offline
Old 06/02/12, 06:36 PM   #8
Gweiner
Gweiner's Avatar
Charlotte
thanks for posting. that looks great!
Gweiner is offline
Old 06/04/12, 06:51 PM   #9
Steve83
Steve83's Avatar
Fullsize Bronco Guru
Memphis, TN, USA
eBay: untod
The stock wagon top isn't nearly strong enough for shoulder belts. And the tubing TAC71 used doesn't look thick enough for the kind of load it would get in a collision. I'd start with a family cage, and then weld in bungs for shoulder belt bolts, similar to this:
http://www.supermotors.net/getfile/7...oulderbelt.jpg
Steve83 is offline
Old 06/04/12, 07:08 PM   #10
DonaldDouchebag
DonaldDouchebag's Avatar
Nordeast Minneapolis
Get a family cage. What's the point of keeping passengers in their seats if they get crushed when you roll?
'64 Sears Allstate Scooter
125cc, 4spd, 6 Horsepower
DonaldDouchebag is offline
Old 06/04/12, 07:15 PM   #11
Jeff76
Jeff76's Avatar
We are shaped by our thoughts, we become what we think...and do.
Alpharetta GA
This sounds right to me. I've got an original with just a '70s style roll bar for the sake of history, but I'll never have another regularly driven Bronco without a full cage. Think of the original top as a sheetmetal soft top.
Jeff76 is offline
Old 07/31/12, 07:31 PM   #12
quikdrummer
quikdrummer's Avatar
Chino Valley, AZ
I just pulled a bench and seatbelt assembly from a tracker! Your right, there's a weird little hoop that mounts a shoulder belt. As soon as I get my family cage in they are going in
Another Beer, Another Rock!
'66, 289, 3 spd, 37's, bulletproof 5.5", deaver springs
My backyard build thread
quikdrummer is offline
Old 08/01/12, 06:01 AM   #13
xcntrk
xcntrk's Avatar
NOVA
I can build something like that... Who wants to be a guinea pig?
No Bronco
xcntrk is offline
Old 08/01/12, 10:27 AM   #14
Jerseydevil
Jerseydevil's Avatar
Keep on rockin in the free world
West Chester PA
Cani see a couple pics of that tracker seat?
Jerseydevil is offline
Old 08/01/12, 10:33 AM   #15
quikdrummer
Chino Valley, AZ
http://classicbroncos.com/forums/sho...59#post2149759
here you go. dont have the belts installed yet, cuz my cage doesnt extend over the seat yet
Tags
seat belts, shoulder belts
Thread Tools
Page generated in 0.30978 seconds with 55 queries
