Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 06/18/12, 02:01 PM   #1
G's Baja Bronco
G's Baja Bronco's Avatar
after 2 years.... ITS ALIVE!!!!!!
Sunny SO CAL
Cool Front bumper
Now that I finished my rear bumper (tire carrier to continue) I want to make the front bumper!
I went to IMS (ind Meta Supply) and got light tabs, gussets and 10 lbs of e7014 3/32 rod, also 5 more grinder cutting wheels.
central to the design will be a 2 x 6 x 3/16's rectangular tube.
please post any pictures of something similar! I would like to get my creative juices flowing!
as a reference I leave you with my rear bumper!!
EFI 5.0 HO GT40p, 4Rw/AOD, NP205, Aluminum radiator/oil cooler/mark viii fan, explorer belt drive, SupaDirt HB 4 wheel disc,23 gallon tank, 33" BFG KM2's w 4.10 gears, black leather, TWoods drive shaft dont Buy...Build!!!!
G's Baja Bronco is offline
Old 06/18/12, 05:53 PM   #2
G's Baja Bronco
Sunny SO CAL
I am leaning towards a 2x4 on the front, not the same as the rear 2x6, but I will add a skid plate on the bottom and a hoop for protecting my lights on the top. also the rear is intended to tow!
Old 06/18/12, 07:22 PM   #3
G's Baja Bronco
Sunny SO CAL
wow, 115 views and NO comments! amazing!
I measured the front and have decided to go with 2x6 after all. I will go buy the material in the am, and as my body recovers from the weekend, I will start the creation!
Old 06/18/12, 07:42 PM   #4
tcjones76
tcjones76's Avatar
Tyngsboro, Ma
Are you planning for a winch mount on the front? That will really set the style for the rest of the bumper.
I have Warn 8274 and used the 2x4 extensions to the frame rails, a piece of 3/16" plate and an vertical mount from Warn mounted to the plate. I angled back some 2x4 pieces off the frame extensions. I still need to add a lower piece to protect the bottom of the radiator. Its kind of massive but it works.
76 Explorer, 302-2V, C4, D44 Detroit, 9" Lock-Rite, 2.5 lift, 33X12.5R15s on 15X8s Warn 8274.
tcjones76 is offline
Old 06/18/12, 08:26 PM   #5
hucklburry rev2
G, I don't think your shackles are gonna hold real well. Seriously though, nice job.
hucklburry rev2 is offline
Old 06/18/12, 09:04 PM   #6
G's Baja Bronco
Sunny SO CAL
jajaja, thanks, I tried duper glue but no luck.
in all seriousness, I ran out of drill bits, I got 3 new ones today. for the front I am going to ask the metal place if they can drill them for me. a real PITA, I am afraid to kill my drill, wish I had a drill press!
Thanks for the kudos.
Old 06/18/12, 09:05 PM   #7
G's Baja Bronco
Sunny SO CAL
no winch plans, all I do is desert wheeling and Tijuana pot holes! no need around here.
Old 06/18/12, 09:23 PM   #8
73stallion
BANNED
73stallion's Avatar
Don't look at me in that tone of voice!
Eugene, OR
good choice on the 2x6, even on my samurai 2x4 looked real dinky.
73stallion is offline
Old 06/18/12, 10:03 PM   #9
G's Baja Bronco
Sunny SO CAL
yup, I agree, lets see if I get the piece in the AM, before work, a little sore and drained!
Old 06/19/12, 07:56 AM   #10
bsquared
bsquared's Avatar
Houston
Can't help with the front bumper, but the attached might give some ideas for the tire carrier. If you have AutoCAD, you'll be able to do much better than I did with PowerPoint. (my AutoCAD seminar starts in Aug) I followed a design posted here by Mark.
http://classicbroncos.com/forums/sho...=143886&page=7
1970 uncut, 96 Exploder 5.0L, ZF, NP205, Q-Jet, 2" BL, 2.5 SL, Dana 44 w/ 76 Bronco discs
bsquared is offline
Old 06/19/12, 08:05 AM   #11
lowbush
Summerland Key, FL
Love the Bronco license plate you must have owned that thing (or another one) for quite a while to score that custom tag.
lowbush is offline
Old 06/19/12, 08:12 AM   #12
Justafordguy
Justafordguy's Avatar
Tallahassee, Fl
Your rear bumper turned out nice. I used the 2x6 for my front bumper but it's made for a winch so may not be what you're looking for.
77 Bronco, 302, 4bbl, Hei, C4, PS, PB, BCB-A/C, 33" KM2s, D44/Lock-Right Chromo axles, 9"/Grizzly locker Yukon axles, Tom Woods driveshafts, 2.5" sl, 1" bl, Bilstein shocks, 1 ton steering, JB-fab twin stick, D20,
2017 F350 CC LB KR FX4
2005 F250 CC FX4
2016 Edge Sport V6 EcoBoost AWD
Justafordguy is offline
Old 06/19/12, 10:53 AM   #13
G's Baja Bronco
Sunny SO CAL
Cool thanks!!!!
LOOKS AWESOME, THANKS, I will definitely borrow from your design. is that a front spindle of some kind?? I like the bearing idea!!
Old 06/19/12, 10:55 AM   #14
G's Baja Bronco
Sunny SO CAL
Cool Wow
Originally Posted by Justafordguy View Post
You rear bumper turned out nice. I used the 2x6 for my front bumper but it's made for a winch so may not be what you're looking for.
that looks beefy, I like it!
I bought the 2x6 tube and had them punch the 2 gusset holes on the 1x2 bar. I also bought a 2'x2' of 3/16 plate to make a skid plate!
I will borrow some from you design definitely.
Old 06/19/12, 11:02 AM   #15
G's Baja Bronco
Sunny SO CAL
Cool Autocad
BTW, I Am and Autodesk certified instructor of both Autocad and Inventor! I worked for a reseller for 5 years and got certified as an "Expert" on both and Data management!
my creative artistic side comes out when I work on my Bronco! I had to make the bumpers simply as a conversational starter and for bragging rights! I like the idea of building not buying! JMHO
Let me know if you need any help on Autocad, I recommend you skip it and go directly to Inventor for mechanical design.
Thread Tools
Page generated in 0.33252 seconds with 59 queries
