Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 06/27/12, 11:09 AM   #1
DonsBolt
DonsBolt's Avatar
Chestnut Hill, Mass
Question School me on bellhousings, and clutch forks
Hey guys looks like I got to pull my trans due to a throwout bearing thats making noises
My current setupwith my nv3550 and Ford racing 5 liter uses the older style bail wire clutch fork. I know there is a clip style clutch fork, and I can buy one of them along twith the clip for it. which is what I may end up doing.
Though I also saw a totally different setup at a speed shop the other day. I think it was from a late model mustang, as it had a ford stamping on the bellhousing. This one had a ball style pivot on the clutch fork, on the right side of the bellhousing and looks like a lot better design.
So here are my questions
If I convert my bellhousing to a clip style clutch fork, what all is involved, and do the holes for the bracket for the wire type line up.
Also I am wondering if a later model F150 4x4 say from the late 80's with a 5 liter and a standard trans would have the other type of clutch fork, and if it will work with the stock bronco clutch linkage, or do I have to go with a haydrolic slave cylinder??
I have a feeling my issue is due to the wire type clutch fork, and thinking the clip type or a later model setup my solve my issues
any feedback is appreciated
1977 Bronco Ford Racing 5 Liter NV3550 456 Gears - 3.5 Suspension 35's
2011 RoushCharged Mustang GT 5.0 675RWHP 10.028@139mph
[COLOR="silver"]
DonsBolt is offline
Old 06/27/12, 07:13 PM   #2
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
The late model mustang bellhousing most likely tilts the transmission and I believe the transmission bolt pattern is a little different as well. probably wont work with your 3550 adapter plate.
Any the other bellhousings you mentioned will work the mid 80's truck type may have hydraulic slave cylinder but you can still use stock bronco linkage might have to fab up a bracket for the equalizer bar but it shouldnt be a issue. truck bellhousings from the 300 6cyl 302 and 351W will all interchange.
as for other 302 bellhousings well just make sure its the large bellhousing so your 164tooth flywheel and 11in clutch will fit. A lot of cars had the 157 tooth bellhousings a lot of them tned to be aluminum.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Thread Tools
Page generated in 0.33500 seconds with 54 queries
