Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 08/02/12, 01:10 PM   #1
matt w
matt w's Avatar
Long Live Long Dirt Rides !
Antelope Valley, CA
To Cut or Not.. Front Inner Fenders???
My truck runs NOT HOT 95% of the time!
It gets hot only in two settings.
#1) On hot days when climbing slow grades, i.e. The back way to Big Bear from Lucern Valley.
#2) On slow trail runs with other people on hot days. I.e., Climbing up Gold Mountain with 10 plus other people. You know how it goes, everyone stops, and then starts and so on, no air flow at all.
I have changed themostats. I have installed a new radiator, I have installed a new water pump.
I am thinking of cutting the front inner fenders to allow more air flow.
What are the negative reasons why I "should not" do this?
I live in dry Southern California and do not do mud runs,,,so what is the downside to this?
LONG LIVE LONG DIRT RIDES
Press On !
Galatians 5:6-b...niv
matt w is offline
Old 08/02/12, 02:53 PM   #2
70_Steve
Old Guy
70_Steve's Avatar
If You're Going to Do It, Over-do It
Phoenix, AZ
Might want to try some other remedies first.
I've been fortunate that I've never had cooling problems. Got my stock radiator recored with a 4-tube core 15 years ago, and been good ever since. I do, or did, run all the stock stuff (7 blade Ford fan, shroud, water pump, pullies, etc) with the original 302 and the 351. I did replace the stock shroud with a sheet metal one, and did install a Flowcooler waterpump when I rebuilt the engine and added the EFI.
A few years ago I did install a RAD. That thing that covers the space from the top of the grill to the top of the core support? I think I noticed maybe a 5 change in temp when I did that. But it might be worth a try. Since you live in such a dry climate, you could test it out with some cardboard and duct tape.
I looked in your Gallery but couldn't tell what fan you're running...
'70 Sport, 351W EFI, NV4500, D20 w/Teralows, 4.56s Dana 44 w/Ox and 9" 31 spline Detroit, 35" KM2's, 3 1/2" lift, 2" body lift, 4x4x2 PS, some other stuff I forgot about...
"If it's got tits or tires it's gonna be a problem"
70_Steve is offline
Old 08/02/12, 02:55 PM   #3
rtj731
rtj731's Avatar
Fayetteville
check out Baile built web page for a inner fender mod, or use a floor hvac vent from the local hardware store. Not really cutting out the inner fender but allowing additional air flow, seen racers out in Vegas with this type of setup.
http://broncobumpersandcages.com/sto...2Ejpg&Size=400
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, totally worn out, and loudly proclaiming WOW... What a ride!"
[Author Unknown]
rtj731 is offline
Old 08/02/12, 03:36 PM   #4
68rockcrawler
68rockcrawler's Avatar
Erie, PA
Matt, I am about to cut my inner fenders and add perforated panels back in to keep rocks and junk out. I ran for years without overheating. This year for some reason I started overheating on slow trail runs where there is no airflow. I would say that something like the Bailie Built panels couldn't hurt.
'68 with 5.0 efi, T-18, 39.5" Iroks, Dana 60, 14 bolt, 1-ton build
68rockcrawler is offline
Old 08/02/12, 04:24 PM   #5
matt w
matt w's Avatar
Antelope Valley, CA
well to all....I cut the passenger side and am going for the drivers now!....
Press On !
matt w is offline
Old 08/02/12, 07:08 PM   #6
HoldMyPocket
HoldMyPocket's Avatar
Norfolk, VA
I haven't had inner fenders at all for nearly a year now with no issues. I have some that I can bolt in but have never found a reason to.
HoldMyPocket is offline
Old 08/02/12, 08:20 PM   #7
u10072
u10072's Avatar
Arizona/North Dakota
Follow the pinch weld...awesome modification that's basically free.
Vintage Iron Fabworks
Phoenix, Arizona
602-502-8945
www.vintageironfabworks.com
u10072 is offline
Old 08/02/12, 09:07 PM   #8
matt w
matt w's Avatar
Antelope Valley, CA
It's all done!.....Wuuuuwhooooo!
Press On !
matt w is offline
Old 08/02/12, 09:19 PM   #9
u10072
u10072's Avatar
Now you can actually get to all those things in the engine bay that normally are a total hassle! Resist the cutesy inserts
Phoenix, Arizona
602-502-8945
u10072 is offline
Old 08/02/12, 09:30 PM   #10
matt w
matt w's Avatar
Antelope Valley, CA
.......YOU ARE SO RIGHT! I was staring at it in unbelief,,,Thinking WOW I can now get to stuff so easily!
As far as inserts.....I will make my own our of 1/8 or 1/4 inch hardware cloth with a few pop rivets.....I doubt I will do anything though until I find if I have a problem..if no problem...no hardware cloth!
Press On !
matt w is offline
Old 08/03/12, 10:11 AM   #11
BIG_UGLY75
problem= money money= upgrades
baytown
Run water only....
The world is a vampire.....
BIG_UGLY75 is offline
Old 08/03/12, 12:59 PM   #12
Justafordguy
Justafordguy's Avatar
Tallahassee, Fl
X3 on easier access to everything, I could change my plugs without opening the hood.
I'm glad I cut mine out but my truck still runs hot.
77 Bronco, 302, 4bbl, Hei, C4, PS, PB, BCB-A/C, 33" KM2s, D44/Lock-Right Chromo axles, 9"/Grizzly locker Yukon axles, Tom Woods driveshafts, 2.5" sl, 1" bl, Bilstein shocks, 1 ton steering, JB-fab twin stick, D20,
2017 F350 CC LB KR FX4
2005 F250 CC FX4
2016 Edge Sport V6 EcoBoost AWD
Justafordguy is offline
Old 08/03/12, 01:30 PM   #13
u10072
u10072's Avatar
If your 302 runs hot I have to believe in all honesty you need a multi prong approach-- decrud your engines water jackets a couple times, replace the waterpump, replace the radiator or get it professionally done, and run a coolant mix to protect from cold weather on the minimun side-- water is best for cooling--distilled is the best route and fairly cheap. Run a fan shroud (go metal) and mechanical fan. If all that doesnt fix it you have a mechanical issue like a small head gasket leak or something. The 302 shouldn't ever run hot and if it doesnt run hot in AZ it wont anywhere else.
Worst part about cutting the inner fenders now is you notice the engine more and it makes you want to make it sexier looking-- but thats a good thing :-)
Phoenix, Arizona
602-502-8945
u10072 is offline
Thread Tools
Page generated in 0.36414 seconds with 56 queries
