Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 09/17/12, 11:08 PM   #1
roparsons
carb squirting gas?
I am posting a picture of the carb on my 75 Bronco. There is a small hole directly under the lever mechanism that squirts out gas every time I push the gas pedal??? I poured some gas in the carb to try and start it since it has been sitting for a long time...could I have flooded it??
http://i295.photobucket.com/albums/m...1212/photo.jpg
roparsons is offline
Old 09/17/12, 11:38 PM   #2
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
Accelerator pump diaphragm is bad. engine is probably not flooded as a inop accelerator pump can make starting hard as the extra shot of gas needed to richen up the mixture is not there.
73 Ranger 2 1/2 lift 302 TFS heads NP435,PS,PDB, tierod over, 33x10.50x15 BFG M/T
71 Sport 63,000 miles all orginal except for cut fenders 302 3sp 4.11's D44/BBTrac lok rear
broncnaz is offline
Old 09/18/12, 07:37 AM   #3
Bronco Junkie
So Cal Broncos
Bronco Junkie's Avatar
Los Angeles
X2 on accelerator pump.
"Life is tough, but it's tougher if you're stupid."
"Don't piss down my back and tell me it's raining."
Bronco Junkie is offline
Old 09/18/12, 11:25 AM   #4
jms5580
jms5580's Avatar
Bozeman, MT
x3 on the pump
'75 302 Qjet on Edelbrock Performer chebby TR over/front disc 2.5" SL/1" BL 35" Pro comp MT
jms5580 is offline
Old 09/18/12, 11:43 AM   #5
Timmy390
Timmy390's Avatar
Conway, AR
The failure of these seems to be getting worse. I go throught them often (every 2 years or so). I've trued up the housing which is about all you can do to help the issue.
I'm convinced these failures are due to the new blends of gas (ethanol) or at least contributing them them. I'll have to admit, my rig sits for a month now and then without being used and I'm sure that doesn't help either.
Has anyone tried the new "green" gaskets that Holley (and maybe some others) produce for alcohol ? I read that Holley is now including them in their rebuild kits due to the ethanol. Have not seen it just read it.
Not trying to hijack or start a he said she said about ethanol in gas now days just wonder if anyone is running the greens with success.
Tim
74 Half Cab 351w 3 speed, SN95 Mustang EFI, 2 1/2 SL, 1 inch BL, 33's, 4.09/4.11's P/S (Delphi box), All Ford disc conversion, Factory bench seat
Coming Soon, Ford ZF or NV3550 and grafted rear quarters
Timmy390 is offline
Old 09/18/12, 02:07 PM   #6
Bronco Junkie
So Cal Broncos
Los Angeles
Crappy gas and crappy China parts ='s things failing way more often!
Old 09/18/12, 05:41 PM   #7
roparsons
If I am replacing the diaphragm, should I buy a rebuild kit and do the whole carb at the same time? Any tricks along the way you guys suggest to make things roll smooth? Thank you!!
Old 09/18/12, 05:59 PM   #8
Justafordguy
Justafordguy's Avatar
Tallahassee, Fl
yes, rebuild.careful with the float level, the 2100 is real picky about the float level.
77 Bronco, 302, 4bbl, Hei, C4, PS, PB, BCB-A/C, 33" KM2s, D44/Lock-Right Chromo axles, 9"/Grizzly locker Yukon axles, Tom Woods driveshafts, 2.5" sl, 1" bl, Bilstein shocks, 1 ton steering, JB-fab twin stick, D20,
2017 F350 CC LB KR FX4
2005 F250 CC FX4
2016 Edge Sport V6 EcoBoost AWD
Justafordguy is offline
Old 09/18/12, 06:02 PM   #9
broncnaz
I.Y.A.A.Y.A.S.
Thatcher, AZ
X2 just get a rebuild kit it will work out cheaper in the end and your whole carb will be rebuilt.
I think the failures are due to cheaper made parts nowadays
broncnaz is offline
Old 09/18/12, 06:17 PM   #10
Bronco Junkie
So Cal Broncos
Los Angeles
Well....in my opinion "if it ain't broke...don't fix it."
Thread Tools
Page generated in 0.41575 seconds with 58 queries
