Go Back   ClassicBroncos.com Forums > Archives > Bronco Tech - Archives
Thread Tools
Old 12/01/12, 06:48 AM   #1
lasadoor
lasadoor's Avatar
slow and steady, slow and steady
San Diego
eliminate auxillary fuel tank
i would like to remove the aux tank and run a new line from main tank to fuel pump. I'm on the fence about replacing aux tank in future so I plan to keep any decent looking parts. Are there any parts I should leave in place or can I run one line from tank to pump? And what size fuel line should I use (stock tank, mechanical pump)? what about holding the line to the frame?
Beauty is in the eye of the Bronco owner
lasadoor is offline
Old 12/01/12, 06:58 AM   #2
half cab
equestrian patcher
half cab's Avatar
ride like the wind bullseye
ms
I would just plug off the aux line and leave everything in place(keep valve switched to main) sence you may replace the aux tank in the future.What ever you do don't plug off the evap/charcoal can. line or you will be sitting at the gas pump along time trying to fill up.
76 SPORT 351W C4 PDB
half cab is online now
Old 12/01/12, 07:04 AM   #3
OX1
Jackson, NJ
If your not sure that you might put it back, just leave stock line and don't switch valve to aux position. If you are pulling all the lines out no matter what, I'd use 3/8 steel (or aluminum) line with short rubber connections at fuel tank and pump. Also acceptable to put a short rubber section in center of fuel line (somewhere well protected against abrasion, especially if you wheel it), only if you have to, to get it to fit.
See this thread also, as many have used some form of plastic line (this thread also details suggestions for frame clips).
http://classicbroncos.com/forums/sho...d.php?t=206372
70 Sport 302/T-18/D20-T, BB 31 spl LS 9" w/ yukons, MK VII rear disks, disk D44 w/ lockrite, 3.5" CAGE/Deaver lift, full length headers/duals, 78 col/steer box, stang HB
79 400/C6/205, Mog 404's, 43 SX stickies...
OX1 is offline
Old 12/01/12, 07:23 AM   #4
bronconut73
bronconut73's Avatar
How did you do that?
Orlando
3/8 to 1/2 inch insulated clamps screwed to the frame with self tappers holding Earls stainless steel braided -6 AN fuel line from tank to pump.
'73, 3.5" sl, XL RS9's, F-250 mounts, Duff Long Arms, 1" bl, 35" MTZ's, C-4, twin sticked, P.S., built 351W, F&R Detroits, 4.11's, chromo axles, 11 leaf packs, SuperJoints, Chevy front disc, BC rear disc, BC Vintage a/c, Scat Procar 2K seats, 3G, Alpine/Pioneer, Bear, Cobra 148 GTL/Texas Star.
bronconut73 is offline
Old 12/01/12, 08:03 AM   #5
lasadoor
lasadoor's Avatar
San Diego
frame clips was my next question. thanks for the responses
lasadoor is offline
Old 12/01/12, 12:07 PM   #6
75junebug
75junebug's Avatar
Whoops, did I do that?
NW Houston Tx
BC broncos has a 3/8 fuel line kit with frame fasteners and all. I would bypass the whole fuel selector due to possible air/fuel leaks. Keep the components for the aux tank. Consider getting a 23 gal tank for the rear, and maybe use the aux tank as an emergency transfer tank. You could do this by simply routing a switched electric fuel pump and line back to a return line/ventline found on the 23 gal aftermarket tanks.
75 Bronco 351 Q-jet, HEI dizzy 435 tranny 3.5WH lift, 2"body lift 35" BFG KM 2's, 4.11 gearing, twin stick, Power disc front conversion,
75junebug is offline
Old 12/01/12, 12:20 PM   #7
TBS-POPS
TBS-POPS's Avatar
ALL my drinking buddies have a severe bronco problem!!
valley springs, ca
The evap/char system has nothing to do with venting the tank to aid in fuel fill ups. Thats what the 1/2'' vent line is for comming out of the later tanks was for. The early tanks had a prob because this vent hose was absent. The 1/8'' spaghetti lines for the evap system would not flow enough air to vent the tank upon fill up.
Run 3/8'' line if you can then you dont have to worry about any fuel supply problems in the future. Rubber dipped clamps and self tappers to frame hold nice.
WWW.NORCALBRONCOS.COM 72, TBI 302, 435,20,FW44&9,4.56 w/pl&arb,2" & 5.5" on 37's.SOLD Broncoless for now
Broncos are like BOOBS, There always better after they've been worked on..
TBS-POPS is offline
Old 12/01/12, 02:48 PM   #8
half cab
equestrian patcher
half cab's Avatar
ms
I'm only speaking from my own experence....
My cannister line on my '76 got blocked just under the pass floor where it crosses over and up the frame to the firewall...Hardly would fill up at the station....check the filler neck return and it was ok...unstopped the charcoal can line and all was well???
I don't know...like I said"speaking from my own experences"
Also I have over filled before and had gas spill just past the T where they (aux/main/evap) lines meet cause of bad hose9cracked),but would gas go up this far in the cannister line?
Old 12/01/12, 11:15 PM   #9
patterdale
patterdale's Avatar
The avatar reflects light tan color and name of bronco.
Bemidji
Why would you want to limit your range so much? Unless you replace the main with a 23 gallon tank you can only go about 150 miles. If money is a problem in replacing the tank just pull it and plug the lines untill you replace it. I would give my left arm for and Aux tank as Elmer is an original stock 12? gallon tank with no auxillary.
One of my favorite bumper stickers:"If you don't stop tailgating me I'll whip a booger on your windshield" There's room for all God's creatures-On my plate, right next to the mashed potatoes and gravy.
patterdale is offline
Thread Tools
Page generated in 0.31606 seconds with 54 queries
