Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 02/10/13, 09:08 PM   #1
68rockcrawler
68rockcrawler's Avatar
Erie, PA
68rockcrawler 1-ton build
I am starting to put a 14 bolt and Dana 60 under my Bronco and finally have enough pictures to make it worth starting my build thread. My plan is to keep it leaf sprung in the rear and do a 3-link in the front with Johny Joints. I got a deal on a used set of 39.5" Iroks and 15" beadlocks. The 15's are very close to the brake calipers, but I got a deal on the set and as long as there is a little clearance I'm not going to complain.
I got my link kit from Barnes 4wd. Their brackets are top notch and I would definitely recommend buying from them.
The 14 bolt was pretty much a direct bolt in. It will require a set of shims to get the pinion where I want it. I am gaining several inches of width with the 14 bolt and a couple more inches with the 60 over the width of the stock axles.
Here are a couple of pictures of the axles and tires, and the rear axle sitting in place. Since this picture was taken I put on the u-bolts. I was able to re-use my Wildhorses extreme duty U-bolt top plate, even though the axle tubes are a 1/4" larger.
Click image for larger version
ID:	288325   Click image for larger version
ID:	288326   Click image for larger version
ID:	288327   Click image for larger version
'68 with 5.0 efi, T-18, 39.5" Iroks, Dana 60, 14 bolt, 1-ton build
68rockcrawler is offline   Reply With Quote
Old 02/10/13, 09:36 PM   #2
broncosbybart
broncosbybart's Avatar
Is it 5 YET???
Charlotte NC
Nice! Looks like someone already added some good stuff to those axles. Hope the swap goes easily (well, at least as easy as it can).
Brad Barnes is the man! I got the 14 bolt shave diff cover kit from him along with the disc brackets and all that. Planning a D60/14b on one of mine down the road.
I've got a good bit of his stuff on the racer. Shipping is pretty much next day for me. Can't beat that.
Carolina Broncos Member- www.cb4x4.com
broncosbybart is offline   Reply With Quote
Old 02/11/13, 11:14 AM   #3
68rockcrawler
Erie, PA
The axles were already geared and had the Chevy 1-ton steering, HD dif covers, discs, etc when I bought them.
I'm following your build thread on mtfit's old Bronco. Looks like a lot of work.
Old 02/11/13, 11:29 AM   #4
broncosbybart
Is it 5 YET???
Charlotte NC
Cool. I assume you know Bill and his old rig. I will be going the other way with it. Back to a more streetable type rig. I do have a set of 1 tons that I plan to put under a cummins 4bt project. That one won't be started for a while...
Looks like you are going to knock the axle swap out in short order.
Old 02/11/13, 11:38 AM   #5
68rockcrawler
Erie, PA
Yes, I know Bill and have wheeled with him in that truck quite a few times.
Old 02/11/13, 02:23 PM   #6
MarkH@Wildhorse
MarkH@Wildhorse's Avatar
Stockton, CA
Props for doing it all on gravel floor too!
When I poured a floor in the barn all my friends told me I went soft.
E-mail - Mark@Wildhorses4x4.com
71' Bronco - Coilover's / 42 inch tires / other stuff I didn't need.
MarkH@Wildhorse is offline   Reply With Quote
Old 02/11/13, 09:00 PM   #7
68rockcrawler
Erie, PA
Mark - I'm sure a concrete floor would make things a lot easier, but all that concrete would take money out of the Bronco budget! I built the whole Bronco on gravel, so I'm used to it.
Old 02/12/13, 04:19 AM   #8
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
Nice man, Good luck w/the build.... "subsribed"
sprdv1 is offline   Reply With Quote
Old 02/12/13, 05:15 AM   #9
mtfit
mtfit's Avatar
pa
Looks good Drew, looking forward to wheelin again soon!
71, Ford lighting motor, Atlas, King coilovers, 700r, 42 MTRs.
mtfit is offline   Reply With Quote
Old 02/14/13, 01:29 PM   #10
68rockcrawler
Erie, PA
Yeah Bill, hopefully I'll be out this spring, and definitely in time for the Roundup in June.
I have been trying to find time to post some more pics. Here are a couple. I got all the brackets cut off last weekend. I figured I would have had to destroy the coil bucket to get them off, because I plan to re-use them. But after I cut the weld along the bottom of the frame then was able to break the welds at the top of the frame and they came off pretty easily.
Now I am at a standstill until I get my lower coil brackets in the mail and pick up my link material from my local steel shop.
ID:	288658   Click image for larger version
ID:	288659   Click image for larger version
Old 02/14/13, 01:56 PM   #11
tobinj
tobinj's Avatar
Do what
Martinsburg, WV
Looking good man..........subscribing to this one since I wanna toss some tonnage under mine one day
tobinj is offline   Reply With Quote
Old 02/14/13, 05:59 PM   #12
SC74
SC74's Avatar
Greenville, SC
Love 1 ton builds - keep the pics rolling! Great progress so far.
'74 Grocery Getter, '73 Buggy Project
My Build Thread
SC74 is offline   Reply With Quote
Old 02/27/13, 09:01 PM   #13
68rockcrawler
Erie, PA
After several weeks away from the garage I have finally made some progress. The cross member in front of the engine is now laying on the floor! It was in the way of the tie rod and will either get re-used or scrapped in favor of a new smaller cross member.
ID:	290152   Click image for larger version
Old 02/28/13, 11:28 AM   #14
SC74
SC74's Avatar
Greenville, SC
Good call on the front cross member. I ended up cutting the bottom half out of mine and boxing it in for the same reasons. If I had foreseen this problem earlier it would have been replaced with tube - like I did the rear.
My Build Thread
Old 02/28/13, 12:59 PM   #15
blwngsket
blwngsket's Avatar
Built with spare change
Novato
Had to do the same to mine as well. Used some tube and plated the frame with 3/8" plate at the same time. Here's a link to the pic's.
http://www.norcalbroncos.com/forum/s...&postcount=425
I'm collecting the parts for the 14 Bolt/D60 swap now. Almost have it all. Let the fun begin.
1970 w/ 89 5.0, 5.5 WH, ext arms, 4 linked rear, 4 wheel hydro disc brakes, tilt column, Hydro assist steering, 456, 435, 203/205 doubler, 39.5 Pitbulls on H1 dbl Beadlocks.
Build thread http://www.norcalbroncos.com/forum/s...ead.php?t=2202
blwngsket is offline   Reply With Quote
Page generated in 0.33409 seconds with 59 queries
