Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 03/15/13, 10:38 AM   #1
Cpenfold
Newbie
Denair, CA
460 BBF vacuum or hydroboost
>>moved question to the chat forum...guess it was probably supposed to go here.
Hey guys, I recently purchased a 75 bronco. The PO put in a carb'd 460, c6 tranny, np205, 9" rear and hp 44 front on an f-150 frame. Currently, my bronco has power steering but no power brakes. I'm wondering your guys' thoughts on vacuum vs hydro. I have disk front and drum rear. My mechanic stated a vacuum system would be fine and would be less modification (I assume less cost). It seems like the guys on this forum like the hydro however. Please let me know your thoughts. Also wondering if my big block factors into your opinion and why. I'm planning on running 35" tires.
'75 EB, 460 BBF, C6, np205, 9inch and 44.
Cpenfold is offline   Reply With Quote
Old 03/15/13, 12:16 PM   #2
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
Hard to say. each 460 swap is completely unique. that is I have never seen two that were done the same. So no idea what clearance issues you really have or don't have.
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
“How hard can it be?”-Clarksonius 4th century BC.
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is offline   Reply With Quote
Old 03/15/13, 12:31 PM   #3
Cpenfold
Newbie
Denair, CA
Thanks broncobowsher. But if I don't have clearance issues, what would you prefer?
Old 03/15/13, 12:48 PM   #4
bmc69
bmc69's Avatar
Maryland
eBay: ford_bill
I always prefer hydroboost in anything but a light and mostly stock rig. It's so much more powerfull and effective.
'69 retro Bronco. Supercharged MPFI 8BA 239 V-8, C-4/D-20. Hydroboost. 5" lift.
bmc69 is offline   Reply With Quote
Old 03/15/13, 01:55 PM   #5
Adapt and overcome
Maricopa, AZ
Broncos really like hydroboost.
Old 03/15/13, 02:36 PM   #6
rjrobin2002
rjrobin2002's Avatar
75 bronco, 5.0 mass air, C4, 4.5" lift, 35" General X3s, 4.56 gears
Elm Grove, LA
Post a picture for the current master cylinder on the firewall. If you have room for a master cylinder, you almost have room for a astro hydroboost.
rjrobin2002 is offline   Reply With Quote
Old 03/15/13, 03:08 PM   #7
Cpenfold
Newbie
Denair, CA
Will do on. Monday, it's in the shop right now and I'm out til next week.
What are your guys' thoughts on the cost difference on the two types of boosters?
Old 03/15/13, 03:49 PM   #8
Adapt and overcome
Maricopa, AZ
Hydroboost can usually be done for less money then vacuum.
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.28037 seconds with 58 queries
