Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Tech
Thread Tools
Old 04/13/13, 07:06 PM   #1
Lohman
Newbie
Full width rear axle offset question.
I'm doing the full width swap with 77 f-150 axles, To get the wheels centered under the Bronco the driveshaft will run at a little angle to the right. The pinion will sit about 2 inches to the passenger side compared to the original axle. Has this caused any vibration problems for those that has done this swap? This is the rear axle.
Lohman is offline   Reply With Quote
Old 04/13/13, 07:30 PM   #2
GRN_MEANIE
GRN_MEANIE's Avatar
BREAK IT THEN BUILD IT
Weyers Cave, VA
Nope, no problems
67' 5.0L, 700r4, 3.8 Atlas II, F/W D60 & 9", 37's
GRN_MEANIE is offline   Reply With Quote
Old 04/13/13, 07:42 PM   #3
nik
nik's Avatar
elbow grease?.... hey this stuff works pretty good!
Corcoran, CA
Originally Posted by GRN_MEANIE View Post
Nope, no problems
No problems here either
1969, 302 Terminator EFI, ZF5/BW1356 planetary box/np205(twinsticked), 4.88s, Full Widths HP44(locked) & Hi9"(ARB), 4.5 SL, custom arms, 1" BL, 35s, 1 ton steering w/4x4x2 box custom bumpers & cage, warn bellevue winch, York on-board air etc
nik is offline   Reply With Quote
Old 04/13/13, 08:38 PM   #4
TBS-POPS
TBS-POPS's Avatar
ALL my drinking buddies have a severe bronco problem!!
valley springs, ca
X3!!!! no probs here
WWW.NORCALBRONCOS.COM 72, TBI 302, 435,20,FW44&9,4.56 w/pl&arb,2" & 5.5" on 37's.SOLD Broncoless for now
Broncos are like BOOBS, There always better after they've been worked on..
TBS-POPS is offline   Reply With Quote
Old 04/14/13, 04:37 AM   #5
GRN_MEANIE
GRN_MEANIE's Avatar
Weyers Cave, VA
The side angle isn't as bad as the down angle. No biggie
Old 04/15/13, 12:10 AM   #6
Rymadd
Rymadd's Avatar
Portland, Oregon
Haha I did the swap about a month ago. Welded it all up and got my pinion pointed exactly 1 degree down from straight. Just went out and looked at it and realized that your right it does have an angle to the side. I have taken it up to 85 (on uhh private roads) without any vibrations at all.
Rymadd is offline   Reply With Quote
Old 04/15/13, 09:24 AM   #7
WILDHORSES
WILDHORSES's Avatar
Lodi CA
I wasted some $ and had a full width made that centered the driveshaft. I'll file it under the live and learn category.
1. Cost more
2. It's not necessary
3. Had to have custom axles built. Which if I have breakage these won't be on the shelf anywhere.
just my .2
WILDHORSES is offline   Reply With Quote
Old 04/17/13, 09:54 PM   #8
Steve83
Steve83's Avatar
Fullsize Bronco Guru
Memphis, TN, USA
eBay: untod
Study this diagram & its caption for everything Ford says about custom driveshafts:
Steve83 is offline   Reply With Quote
Thread Tools
Page generated in 0.31895 seconds with 54 queries
