Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Tech
Thread Tools
Old 04/16/13, 03:25 PM   #1
allen
GFY
Warwick
Steering box rebuild-quick ratio or not?
I need to have my steering box rebuilt but was told by the rebuilder that they didn't know when they would get the quick ratio kits in, 6 days, weeks or months, no idea.
As my box is already out of the bronco I don't know what ratio it is, I know it wasn't quick, that's all.
My question is does it really make a difference? Should I wait? It's mainly a street bronco and light offroad.
-Allen
allen is offline   Reply With Quote
Old 04/16/13, 03:44 PM   #2
allenfahey
allenfahey's Avatar
Hanover
The quick ratio uses a Astro 2wd. non-variable steering box for the guts that swap to the Bronco box. If I were you I would swap to a 4x4x2 box. You will get a stronger box and 4 turn box as a bonus. Very easy to do yourself too. http://www.wcb4x4.com/tech/diyrockcrawler.shtml
From what I understand PSC has the parts to do the Bronco box to a 4 turn box.
73 fiberglass, D60's f&r with ARB's, 5.5 lift, 435/203/D20, Cage SAS arms, Astro hydro boost, H1 re-centered rims, ect...
allenfahey is offline   Reply With Quote
Old 04/16/13, 03:57 PM   #3
allen
GFY
Warwick
Neither PSC or West Texas off road have the quick ratio kits as of now, they don't know when they will have them
Old 04/16/13, 04:32 PM   #4
Broncobowsher's Avatar
Adapt and overcome
Maricopa, AZ
How quick is quick? The 4-turn box is usually best. 6-turn is slow. 3-turn tends to be a little too fast. Are you looking at the 4-turn or 3-turn for quick ratio?
"She's built like a steakhouse but she handles like a bistro"-Zapp Brannigan
“How hard can it be?”-Clarksonius 4th century BC.
Full throttle, it either solves the problem or ends the suspense.
Broncobowsher is online now   Reply With Quote
Old 04/16/13, 04:40 PM   #5
wesleydax
wesleydax's Avatar
Cleveland, TN
i went from a stock box to a quick steer. i dont offroad any mainly on road and gravel to light trails. i dont notice a big differance i just thought it would be the thing to do.
wesleydax is offline   Reply With Quote
Old 04/16/13, 05:15 PM   #6
motoman
motoman's Avatar
Greg aka Motoman
Phoenix, AZ
For the most part I really enjoy the quick turn box.... going from 7 turn lock to lock to 3 1/2 turn was great.... the only time I don't like it is long slow turns at 60 mph on the freeway.... little twitchy. Off road it makes for an extremely responsive vehicle!
motoman is offline   Reply With Quote
Old 04/16/13, 05:45 PM   #7
AZ73
AZ73's Avatar
Barn Find
Scottsdale
I had a 3.5 turn box built, but had the tension increased. 4 turns is probably fine, but I'm used to faster turning boxes on my other cars. People say at speed a 3.5-4 turn box is too fast for a small wheelbase Bronco, but that's what current jeeps (as well as F150s, but they're longer) have so I don't see what the problem is.
Barn Find 73 going through a nut and bolt Restoration/Upgrade. Follow along at:
http://classicbroncos.com/forums/sho...d.php?t=217635
"If you don't stand for something, you'll fall for anything"
AZ73 is online now   Reply With Quote
Old 04/16/13, 06:04 PM   #8
allen
GFY
Warwick
Not sure if West Texas Offroad quick turn kit is 4,3 or 3.25 turn. I'll only assume mine is a 6, like I said its off the truck right now
Old 04/16/13, 11:11 PM   #9
bigjhoov
nobody
bigjhoov's Avatar
Rockwall, TX
eBay: bigjhoov
Well it's easy to tell how many turns it is off the truck. Grab the input shaft lightly with a set of vise grips, turn it either way until it stops, count the rotations it takes to turn the other way until it stops. It's that simple. I think the 4-turn 76-77 box is just about perfect for a driver, but anything is better than a manual box if you have big meats on it.
bigjhoov is offline   Reply With Quote
Old 04/17/13, 02:56 PM   #10
allen
GFY
Warwick
Well it's 5.5 turns, stop to stop. I just don't know whether I should wait or not.
Old 04/17/13, 03:53 PM   #11
xcntrk
xcntrk's Avatar
NOVA
That's the same response I got from WTO and why I went with Lee Power Steering. Unlike WTO, Lee invests in the expensive gear required to do the conversion by purchasing in bulk in order to always have them available. From what I gathered, WTO won't do that and only comes about the needed gear as they get old/salvage boxes in which have them hence the "no idea".
I went with 3.5:1, drive like a modern day ratio...
No Bronco
xcntrk is offline   Reply With Quote
Thread Tools
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.27456 seconds with 54 queries
